Possible failing rear differential or transfer case? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 07-09-2019, 10:49 PM   #1
Yuh
I opened a thread recently regarding vibrations coming from the rear of my car. I replaced the guibo and center support bearing thinking it was the driveshaft. That ended up not fixing it. The U joint didnít feel bad either so Iím not thinking itís the driveshaft.
Upon doing more research I think it may be the differential seeing as how the vibration goes away when I step on the gas.
Potentially could be the transfer case or a rear axle but is far as I have read it seems more likely to be the differential. I replaced my differential fluid and transfer case fluid today, the differential fluid didnít seem dark at all so it may have been a waste of time. The transfer case fluid was actually very dark. I was kind of expecting the differential fluid to be dark if it was going bad. But maybe it doesnít necessarily have to be dark in order for something to fail?
Anyhow just wondering if anyone has went through this as well and if anyone has an opinion regarding this. my main symptoms are vibrations from the rear of the car starting around 30 miles an hour mainly felt upon deceleration. The vibration gets worse when coming to a stop and really rattles before fully stopping. Really running out of time to troubleshoot this, wondering if anyone has insight. Sorry for the lengthy post!
Thank you guys
Yuh is offline   Reply With Quote
Old 07-10-2019, 10:28 AM   #2
77'911
You might check:
1) rear rotors for true, caliper bushings
2) rear trailing arm bushings & diff carrier bushings
While in there you might check for a broken coil spring or loose shock(IE mount shot). We had a vibration (higher speed) when braking, but at the front. Turned out to be lower control arms, ball joints, and bushings. It took a bit to track it down as so much needed doing on our car.
Regards
77'911 is offline   Reply With Quote
Old 07-16-2019, 02:38 PM   #3
jmo69
My Ride: 03 325xi 98 328is
Have you checked the rear wheel bearings. My e36 had a bad one but it was more noise than vibration.
Sent from my SM-G950U using Tapatalk
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
