Oil leaking at oil filter housing no matter what I do. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.88 average. Display Modes
Old 01-27-2015, 01:34 AM   #1
ZANIESXD
My Ride: 2002 325i Sedan
Hello fellow fanatics!
So, I seem to have been losing oil for the past year or so. Every 200 miles I'm having to throw a quart in! There is no dripping on my driveway. Sometimes I can visibly see oil dripping from my oil filter housing. It seems that no matter what I do the o ring comes out of place. Originally thought it was my ccv but I noticed a large amount of oil dripping from the housing and I think that's the problem. I've bought new oil filters several times trying to get the oring to fit snugly, what am I doing wrong here? I don't see excess amounts of oil on the housing itself since I cleaned it off and re-tightened the lid about 50 miles ago but now It looks loose (it's lopsided hanging out). Check out the attached picture and please don't hesitate to tell me what I could be doing wrong!
Thanks so much for your assistance!
ZANIESXD is offline   Reply With Quote
Old 01-27-2015, 02:18 AM   #2
TerryH
My Ride: '99 328i
It's important to lubricate it well with clean motor oil before installation. Make sure the groove is clean where it rests and be careful not to stretch it putting it on. Other than that, I can't imagine what else is causing it to extrude.
TerryH is offline   Reply With Quote
Old 01-27-2015, 02:52 AM   #3
Megalocnus
My Ride: 05 330i ZHP/MT
Perhaps its' just the photo, but it looks as if there is a crack on the top of the housing neck where the filter cap screws in, exactly where you circled the sealing O-ring... If this is a crack, you'll need a new oil filter housing.
In case there is no crack:
The cap looks like it has taken some beating, possibly from using tools other than a 36-mm socket to remove and install.
Since the cap is cheap, I'd just buy a brand new one from BMW along with all associated O-rings. Use a proper 36-mm socket on the new one. Tighten the cap by hand until it's going in nice and easy, then use a wrench, but don't over torque. The speck is 25 N-m (18 ft-lbs).
Next, a quart every 200 miles is a lot of oil. You may not see drops on your driveway since it will leak only when the engine is running. As soon as you shut it down the oil will settle into the oil pan. But there should be a plenty of engine oil smeared on the driver side of the engine and underside of both engine and transmission. Did you have a chance to inspect these areas?
If you don't have a lot of oil down there, you should consider that the leak is not the only way you are losing oil...
Megalocnus is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-27-2015, 03:28 AM   #4
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
See if you have an extra old o-ring stuck in there. I had the same problem as you and it was just that.
Old 01-27-2015, 06:08 AM   #5
Yewzer B Lewzer
My Ride: 2003 325i
You are putting the o-ring in the wrong place. In the groove not on the shoulder.
Window Regulator Help:
Axle Shaft Replacement:
Red Oil Light!!:
MrPhilidelphia’s Temperature Gauge Improvements:
Yewzer B Lewzer is offline   Reply With Quote
Old 01-27-2015, 08:10 AM   #6
ChuckyVee
My Ride: 2000 323i, '99 328is
Yep...I'm betting that the oring is not seated in the correct groove.
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 01-27-2015, 03:15 PM   #7
ZANIESXD
Thanks for the advice!
I will reseat the oring in the proper groove...that's probably it, and get back to you! Will inspect for a crack as well.
Does anyone have the part number for the housing cap handy?
Thanks again for your time!
Old 01-27-2015, 09:32 PM   #8
LeMansteve
My Ride: sold - '04 330i
Yeah OP, that o-ring is on the wrong place. Looks pinched between the filter cap and the metal housing. It belongs in the groove as mentioned earlier.
Old 01-28-2015, 06:19 PM   #9
ZANIESXD
Okay so I lubed up the o ring and put it on the notch as suggested but it still began to flare out (see pic) after I drove it. It's driving me NUTS. I'm about to buy a new housing cover as this seems like the only other option. I just don't get it. Is it too loose or too tight? Before I buy a new part I'll try and torque it to 18ft lbs with a 36mm socket. It seems that when I tighten it it just ignores the notch. Is the O ring visible on y'all's e46 after tightening? If anyone's had a similar problem I'd really appreciate any input. My engine bay is wreaked with oil everywhere from this leak and I even had my alternator go bad from the oil dripping on it so I had to buy a new one. I'm not even driving at this point it's so bad. Please, any other advice would be greatly appreciated and I'll even make a video showing the process I'm using to put it on if necessary.
Thanks again for y'all's time!
Old 01-28-2015, 06:43 PM   #10
My325XI
My Ride: 03 325XI Sprt Prem
Year: 2003
Model: 325XI
Transmission: Manual
As suggested in a prior post, there is most likely an old o-ring stuck in the groove and your doubling up on the o-ring forcing it to move and slide when you tighten the cap down. Get in that groove with a pick type tool and see if you can dig out an old 0-ring.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-28-2015, 06:49 PM   #11
Blisssss
My Ride: 2003 330i ZPP/ZSP
On a side note, does anybody know where the oil/coolant leak ultimate guide is at? I cannot seem to locate it!
Blisssss is offline   Reply With Quote
Old 01-28-2015, 07:26 PM   #12
VMRWheels
Past Site Sponsor
VMRWheels's Avatar
My Ride: Anything with VMRs!
The groove is pretty thick and should be able to seat a new o-ring easily within the oil filter housing. Once you get that cleaned out, just make sure its seating correctly as you're torquing the cap down.
Old 01-28-2015, 08:48 PM   #13
Yewzer B Lewzer
My Ride: 2003 325i
I'm starting to think this is right.
If the o-ring is truly in the groove there is no way it can become extruded as you are seeing. The o-ring slides all the way into the aluminum housing and the shoulder of the cap tightens against the aluminum. No, the o-ring is not visible at all after correct installation.
Red Oil Light!!:
Old 01-28-2015, 08:53 PM   #14
Yewzer B Lewzer
My Ride: 2003 325i
Originally Posted by yewzer b lewzer View Post
i'm starting to think this is right.
Red Oil Light!!:
Old 01-29-2015, 12:23 AM   #15
Antti
My Ride: 330CI / 316 1.8i
Year: 2005
Model: 330CI M-Sport II
Transmission: Automatic
Remove oil filter cap and post photo here.. interesting.
BMW E46 330CI M-Sport II 2005 Individual Black Sapphire metallic /Showroom
BMW E46 316 1.8i Sport 2005 Mysticblau metallic /Showroom
Renault Clio RS197 2007 Ultra Red
Antti is offline   Reply With Quote
Old 01-29-2015, 12:29 AM   #16
ZANIESXD
I checked and didn't see another oring last time I put it together but I'll look closer and see if ones stuck in there and report back. I figured it would be easily visible but will be more thorough this time.
I appreciate your advice!
Old 01-29-2015, 02:12 AM   #17
ZANIESXD
Welp.
Y'all were right! There was an old ring stuck in there that appeared to be flush with the threads as it's flattened with age. I feel so stupid
Pretty sure I've been changing my oil wrong for the last year. Only one way to learn I suppose. I hope if anyone else is having this issue they find this thread.
I really appreciate your prompt advice and will contribute more on this site because of folks like you!
Thanks again guys! I am so psyched, that's one less thing to worry about!
Old 01-29-2015, 02:33 AM   #18
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Originally Posted by ZANIESXD View Post
Welp.
Called it, in post #4!
Old 01-29-2015, 03:13 AM   #19
Antti
Year: 2005
Great you got this sorted
Old 01-29-2015, 08:17 AM   #20
My325XI
Year: 2003
Model: 325XI
Excellent!!
filter, gasket, housing, leak, oil
