Engine Smell and Smoke ONLY on Startup (N42 318Ci) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-01-2016, 01:34 PM   #1
Jakob1427
My Ride: 2001 BMW 318Ci
So this issue has been happening for maybe the last 6 months or so, so definitely not a sudden thing. But I thought I'd finally ask for an answer.
On a cold startup, about 3-4mins after the engine has been running (so the temp needle is just lifting off the blue) the engine starts to smoke a little and produces a smell. This lasts only about 1-2mins and once the engine is fully warm it doesn't happen again and everything runs fine.
Other than that the car runs perfectly (for now) and has 91k miles on the clock (2001 E46 N42B20 318Ci).
Can anybody shed light on what this might be (and why it's only happening when it's happening)?!
Here's a video of it after about 4mins of idle when it happens (where I'm pointing the camera is where the smoke seems to be coming from):
Jakob1427 is offline   Reply With Quote
Old 03-03-2017, 02:04 PM   #2
radduu
My Ride: 2002 BMW E46 318i
I had the same problem but no answer
radduu is offline   Reply With Quote
Old 03-03-2017, 02:11 PM   #3
TMW_E46
My Ride: 2003 330XI Auto
If it smells like oil, could be the seals expanding with the heat and leaking for a moment before reaching full temp.
Have you found any leaks? My exhaust shields had a stain from the vcg leak which made finding it easy.
TMW_E46 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-03-2017, 02:39 PM   #4
radduu
It's only on cold engine, first time when I start the engine. Yes it smells like burned oil.
I have a oil leak at the Oil Pan Gasket, but did not cheked for other leaks.
Old 03-04-2017, 04:06 AM   #5
radduu
Today I went to the car and saw oneCCV hose covered with a lot of oil (Im sure this is the part nr. 11157513903 of the hose full of oil on it). This explain the oil under the car, but it could also explain the smoke on the right side of the engine? (how you look to the engine from the front of the car)
Old 03-11-2017, 05:35 AM   #6
radduu
How to remove a broken vacuum pump nut? It's ok if it holds in just 2 nuts?
Old 03-11-2017, 06:29 AM   #7
radduu
done it...
Old 03-11-2017, 08:53 AM   #8
radduu
I've changed the two o-rings of the vacuum pump, but it stils leaking oil. I put a picture where is leaking. Shoud I put some sealant on the exterior vacuum pump for a better seal ?
Old 03-12-2017, 04:11 AM   #9
radduu
Where the oil spots are.
318ci, n42, oil, smoke, startup
