Help with AUX IN setup - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Mobile Electronics Forum
Old 02-19-2017, 02:51 PM   #1
naemdx
My Ride: E46 318i
Hi,
Could someone help me with identifying whether my Business CD unit supports AUX IN? Based on threads I've run into here it should be OK, but I couldn't get one cable I ordered online work. The unit has a MODE button, and at the back there are two free slots for 10-pin cables.
Here are the details in text format (see also pic attached):
6512 6916047-02
108788 10
Germany
11-02
RADIO BUSINESS CD RDS
PH806021041767
2DC806/23
9022 218 06239
WA00 0247
Software Version: SV 47-02 510
I have a 3-series 318i, and the first registration date is 12/2002. Seems like the business cd unit has been manufactured in 11/2002.
Any help much appreciated!!
naemdx is offline   Reply With Quote
Old 02-19-2017, 05:52 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
My point of reference is the '05 X5. I pulled my display (the MK4 Nav system) and there was a wire harness behind it wrapped with the fabric-tape that they use to hold the wire harnesses together. Inside of the wrap was an empty 2-wire connector, this is where the Aux is plugged in. I bought the Aux connector, but got the wrong one (different shape of the connector), so it was returned and exchanged. The correct Aux cable plugged in and immediately began to produce the input selection on the display. My display has a button marked MODE that when pressed walks through the available inputs to the radio. Aux became available as son as the Aux cable was connected.
Your car might be outside of the production range for this option, I do not know one way or the other. If you remove the radio display, there should be a wire harness behind it that may or may not have a connector covered up by the fabric wrapping that holds the wires together. You should not have to remove more than about an inch of the wrapping to expose the hidden connector, but if there is a connector, you should be able to feel it. The connector comes in two configurations, large and small. Both are 2-wire. If you have the connector, then you can connect the Aux cable and use your phone to bring music services to your car. I plug in my phone and use Pandora almost every time I get into my wife's X5.
Old 02-19-2017, 06:00 PM   #3
hibeemer
My Ride: 2002 330i
Hope this helps.
Alpine, Model CD53, Part Number 65. 12-6 916 241 (July 2001) iPod Data Capable
Alpine, Model CD53, Part Number 65. 12-6 915 711 (Sep 2001) Ipod Data Capable
Alpine, Model CD53, Part Number 65. 12-6 919 072 (Dec 2001-Jun 2002)iPod Data, Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 921 963 (July 2002-Jan 2003)iPod Data, Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 927 902 (Feb 2003-Aug 2003)iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 10-6 927 903 (RMFD thru Dec 2006) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 941 505 (Jan 2004 - Sept 2004) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 941 506 (RMFD thru Dec 2007) iPod Data, Aux and Sirius Capable
Alpine, Model CD53, Part Number 65. 12-6 943 429 (Oct 2004 -Sept 2005) iPod Data, Aux, Sirius and MP3 Capable
Alpine, Model CD53, Part Number 65. 12-6 943 430 (RMFD thru 2008) iPod Data, Aux, Sirius and MP3 Capable
Alpine, Model CD53, Part Number 65. 12-6 961 215 (Dec 2005-May 2006) iPod Data, Aux, Sirius and MP3 Capable
hibeemer is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-21-2017, 01:43 AM   #4
ZZen330
My Ride: 2002 330Ci
That part number list in not totally accurate. CD53's are AUX capable starting in MY 2003 cars. Model year 2003 E46 started in Sept 2002. So a CD53 radio with a date on it of Sept 2002 (maybe even Aug 2002, but Sept to be safe) and up should be AUX capable.
The only thing I'm not sure of is if this holds true outside North America.
ZZen330 is offline   Reply With Quote
Old 02-21-2017, 10:05 PM   #5
TheRocketSurgeon
My Ride: 330i
If it isn't capable of aux input out of the box I can recommend a company called Quidzel. Its a one man shop that makes aux input work arounds for older BMWs. The sound quality is superb and the customer service was impeccable.
http://quidzel.com/
TheRocketSurgeon is offline   Reply With Quote
Old 03-10-2017, 03:40 PM   #6
rwall
My Ride: 2004 325ci
You have to turn on the device (iPod, iPhone, etc.) before the head unit will recognize that a device is hooked up. Only then will you get Aux when you press the Mode button.
rwall is offline   Reply With Quote
Old 03-12-2017, 01:27 AM   #7
Onizukachan
My Ride: F31d Msport
Year: 15
Model: F31
This is incorrect if you have a correct aux cable.
This is only the case when you buy the knockoff cables that don't follow the correct specs and lack the resistor pack required for the cable to show correctly
If I were to give my
a first name, I'd probably name it "Alan".
Mostly because I like puns.
Onizukachan is offline   Reply With Quote
Old 03-12-2017, 08:05 PM   #8
sroberts
My Ride: 2000 323ci
If you wire your own AUX cable (or use a knockoff) and employ a ground loop isolator (which you would likely need anyway), your AUX input always show even when your audio device is not connected.
sroberts is offline   Reply With Quote
Old 03-29-2017, 05:49 AM   #9
naemdx
My Ride: E46 318i
Thanks everyone for your input. I was able to resolve the problem by ordering an expensive (75 euros!) OEM retrokit that my local dealer assured would work (if it didn't, I would be able to return the cable).
The first cable I ordered from Hong Kong had something wrong I suppose...
Old 03-29-2017, 11:17 AM   #10
Alibs555
My Ride: 2000 BMW 328ci
^ Have you only ordered it...? Or have you ordered it and installed already? What is the unit and where did you order it from?
I installed an "AnyCar" unit, a little pricier, but has Bluetooth phone/streaming, USB, AUX and works with the steering wheel controls. Also from Europe (Germany to be exact) via eBay... CA$120 with shipping (US$100??).
I'm very pleased with it.
ID:	652587   Click image for larger version
-Alibs555
...on the beautiful North Shore of Vancouver, BC Canada
Alibs555 is offline   Reply With Quote
Old 03-29-2017, 11:34 AM   #11
naemdx
My Ride: E46 318i
I already installed it. Wish I would've known about the "AnyCar" solution as it works with the steering wheel controls as well, nice! Maybe at some point I'll sell my cable and get that one because the next step would have been to get a bluetooth dongle to connect to the aux in. I suppose I wasn't dreaming big enough from the very beginning because I was so worried my business CD wouldn't be compatible. Many thanks for the tip!
I ordered my unit through local BMW dealership. It came from Sweden and the part name/number was: "Retrofit kit Auxiliary connector 65 12 0 153 501"
Old 04-08-2017, 09:03 PM   #12
Onizukachan
Year: 15
Model: F31
You can fix your Hong Kong cable by installing the missing capacitors and resistor so the head unit detects the cable.
318i, audio, aux
