2006 M3 Convertible amps missing (HK speakers with nav) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 05-01-2017, 06:02 PM   #1
kozi
My Ride: 2006 M3 Convertible
About a year ago I bought a 2006 M3 Convertible and noticed in the trunk the liner had been cut away and there were some wires capped off. I assumed (naively) that the previous owner had an aftermarket audio system/sub box that they kept there and took out when they went to sell the car. Now in preparation for summer time and blasting tunes with the top down I've been doing some research and it looks like I'm missing an amp and a sub that should've been with the car. The only thing that's still back there is the bluetooth module.
I've got the HK system with navigation upgrade and I've been looking around for a factory component list or wiring layout or something to go through and see what's missing and what I've got to start replacing but I've come up short. RealOEM shows multiple amps for that year/model so I don't know if there's just one amp I'm missing or two (one for speakers, one for sub). I know I definitely need this one.
At the moment I'm looking to just replace what's missing vs spending a bunch of money to upgrade to all new stuff as the used amps and sub can be bought pretty cheaply on Ebay. The rest of the speakers work fine with the exception of the passenger midbass which buzzes quite a bit with the bass turned up so it should probably be replaced. But if you guys have some cheap replacement suggestions I'm open to checking them out._a_
ID:	654323   Click image for larger version
ID:	654324   Click image for larger version
ID:	654325   Click image for larger version
kozi is offline   Reply With Quote
Old 05-02-2017, 11:03 AM   #2
intensity
My Ride: 318CI
i have HK system and i dont have anything like this , maybe it is an aftermarket install ?
intensity is offline   Reply With Quote
Old 05-02-2017, 01:26 PM   #3
kozi
Is yours a Euro model? From what I've read the Euro version is different from the US and yours has the amp behind the driver side rear speaker panel. In the US model the amp is in the trunk attached to the back of the seat.
The HK upgrade for the convertible has a sub between the ski pass through like shown here
Sponsored Links
Advertisement
Old 05-03-2017, 04:06 AM   #4
intensity
My Ride: 318CI
yes mine is EU version i leave in france , i have the amplifier behind the driver side rear panel
Old 05-03-2017, 02:23 PM   #5
steveintheburgh
My Ride: 2004 330Ci
Kozi
The amp is on the rear drivers side- below the armrest. US.
If your amp was actually gone, you'd have no sound coming from any of your speakers, as that amp drives them all.
Tons and tons of DIYs on this both here and in the BAV Audio forum
steveintheburgh is offline   Reply With Quote
Old 05-03-2017, 02:25 PM   #6
steveintheburgh
My Ride: 2004 330Ci
https://forum.e46fanatics.com/showthread.php?t=1126761
SEARCH - this is 10 threads down on this forum
Old 05-03-2017, 05:07 PM   #7
kozi
That is for the non-HK upgrade or nav upgrade. Total opposite of the system I have.
Assuming that the amp locations are the same for all configs, the main question I have is is that the only amp or is there a 2nd amp I need to power the sub that comes with the convertible version?
Old 05-04-2017, 12:29 AM   #8
steveintheburgh
My Ride: 2004 330Ci
I have HK and Nav...in a convertible
It's below the rear armrest drivers side. The same spot as in the above post.
The wire diagram going in to the amp is in this post.
https://forum.e46fanatics.com/showthr...769&highlight=
I guarantee everything else you'll need is in this forum
https://forum.e46fanatics.com/forumdisplay.php?f=22
It's one Amp.
If you are putting in your own sub, you should plan on a sub specific amp.
Again - SEARCH. Both here and on the thing called the world wide web.
amplifier, audio, convertible, harman kardon, speakers
