Engine oil for M54B30 in the blazing Middle East? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-09-2018, 01:14 PM   #1
AbdullaJaafari
My Ride: E46 330ci
Hi,
Time to change my oil and need some advice.
Last oil I have used was the Liqui Moly Molygen 5W40.
Should I stick to that? Or should I go for Red Line 15w15?
I currently have a couple of leaks: Main seal and valve cover (again for the third time 14 months).
-2002 BMW E46 330Ci
AbdullaJaafari is offline   Reply With Quote
Old 07-09-2018, 01:38 PM   #2
lyssword
My Ride: 04 330ci gmauto 145k
something "heavy", the reason e46 m3 uses 10w-60 is because it can handle much higher temperatures and won't lose oil pressure. 40w maybe even 10w-60 (up from 30w stock) should b ok tho with high temps, never heard of ppl using 15 -15. Conversely, don't ever try to run 10w-60 in freezing temperatures
lyssword is offline   Reply With Quote
Old 07-09-2018, 01:40 PM   #3
armenh7
My Ride: 2002 325i
If your valve cover gasket is leaking, make sure your valve cover isn't warped. Other than that, only buy a genuine BMW gasket. The aftermarket ones don't last
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-09-2018, 01:44 PM   #4
AbdullaJaafari
My Ride: E46 330ci
I have a feeling the valve cover is warped, because that's the only reason which makes sense .. I replaced the gasket with Reinz gaskets, and also the rubber grommets too .. problem is, a new valve cover would be expensive and not worth changing..
-2002 BMW E46 330Ci
Old 07-09-2018, 01:45 PM   #5
armenh7
My Ride: 2002 325i
I see the issue. Victor reinz makes the WORST vcg
Old 07-09-2018, 01:45 PM   #6
AbdullaJaafari
My Ride: E46 330ci
Living in Dubai, the lowest temperature we get is around 27 degrees celsius in winter..
So you recommend going for 10w60 in the M54? any disadvantages?
-2002 BMW E46 330Ci
Old 07-09-2018, 01:45 PM   #7
DBecker
My Ride: e30,e34,z3,e39
If the cooling system is working correctly, the ambient temperature has little effect on the engine operating temperature. There isn't any special oil requirement for hot weather.
DBecker is offline   Reply With Quote
Old 07-09-2018, 01:47 PM   #8
AbdullaJaafari
My Ride: E46 330ci
I see .. I got them with the vanos rebuild kit I installed ..
I guess I'll go ahead and seek new OEM VCG..
Any solutions to a potentially warped valve cover?
-2002 BMW E46 330Ci
Old 07-09-2018, 01:48 PM   #9
AbdullaJaafari
My Ride: E46 330ci
Never had any engine heating issues, so I believe cooling is fine (The AC not so much on the other hand)
Still on clutch fan as the weather here is too hot for just one electric fan
-2002 BMW E46 330Ci
Old 07-09-2018, 01:50 PM   #10
armenh7
My Ride: 2002 325i
I've only heard about getting a replacement off ebay or a junkyard but you never know if it'll be warped
Old 07-09-2018, 02:13 PM   #11
CylonRed
My Ride: '01 E46 330i sport
Find a M56 valve cover - it is metal but some plumbing will change a bit.
Elring Klinger VCG is what my local indy BMW shop uses - the only one they will use.
CylonRed is offline   Reply With Quote
Old 07-09-2018, 02:33 PM   #12
AbdullaJaafari
My Ride: E46 330ci
I was looking that up but unfortunately the M56 engine was never sold around here so there's no way I can find it in the UAE or this region
-2002 BMW E46 330Ci
Old 07-09-2018, 03:36 PM   #13
LeverThis
My Ride: 2004 325i automagic
Hi,
Just curious, does the vcg leak at the same spot everytime?
Also, is it losing much oil between changes? Is that why you want a thicker oil?
LeverThis is offline   Reply With Quote
Old 07-09-2018, 03:39 PM   #14
AbdullaJaafari
My Ride: E46 330ci
Yep from the same spot just near the exhaust manifold.
I did almost 5K miles (8000 Kms), I didn't measure how much oil I had to add, but the oil indicator on the dipstick was at minimum and I filled it to full.
-2002 BMW E46 330Ci
Old 07-09-2018, 07:13 PM   #15
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Official oil list.
https://forum.e46fanatics.com/showthread.php?t=1203793
Old 07-10-2018, 10:42 AM   #16
markusmarkus
My Ride: 2018 M240i
LiquiMoly makes great oil. The base stock is type 4 stock while most “consumer” oil is made of type 3 base stock. The difference is that type 3 base stock is made of Dino oil that’s broken down into small polymer chains. Technically its synthetic. Type 4 base stock is made from man made polymer chains. It’s a true synthetic. Fyi, Redline oil is made from type 5 base stock.
I run LiquiMoly 5W30 in my 2018 M240i even when I track it. Stick with LiquiMoly.
markusmarkus is online now   Reply With Quote
Old 07-10-2018, 12:12 PM   #17
Knight
My Ride: SL63 | SHO | E46
Liqui Moly is top shelf. I would also trust Mobil 1 0W-40. Factory fill for AMG and if you knew what kind of extreme testing those lunatics subject engines to, you'd be comfortable running their oil of choice in any climate.
Knight is offline   Reply With Quote
Old 07-10-2018, 03:37 PM   #18
Quadcammer
My Ride: 2000 328i
0w40 is fine. You could run a 5w50 but its not necessary for regular street driving
Quadcammer is offline   Reply With Quote
engine, m54b30, oil
