Oil Drain Plug Stripped - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-19-2019, 03:25 PM   #1
asm123
My Ride: 2005 M3 6spd
Tried to get my oil changed the other day on 05 M3. The drain plugged is stripped, however, and we didn't proceed with the change as we didn't know if the bolt would securely fit back in. I called dealer who said that the whole pan would have to be replaced which is over 2k....
Anybody have experience with this or know mechanics in the Philly area that have experience with this? I was under the assumption that just the bolt could be replaced, but I guess not.
Anything helps. Thanks
asm123 is offline   Reply With Quote
Old 03-19-2019, 03:32 PM   #2
RBMW
My Ride: 03 M3, 96 M3
Go with a used oil pan. Itís not a hard job. Any competent mechanic can handle.
RBMW is offline   Reply With Quote
Old 03-19-2019, 03:48 PM   #3
Effduration
My Ride: '05 330CiC
There is a used S54 oil pan on Ebay for $500 (seems a little pricey, but there is only one)
Here is a DIY on dropping the pan on an M3...need to lower the subframe.
http://www.m3forum.net/m3forum/showthread.php?t=414678
Effduration is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-19-2019, 03:50 PM   #4
Archbid
My Ride: 330ci Convertible
Year: 03
Model: 330cic
Transmission: 5-Speed Manual
Call a BMW disassembler. There has to be one somewhere near you. Buy a used pan and gasket. It is not fun, but not hard.
Archbid is offline   Reply With Quote
Old 03-19-2019, 03:53 PM   #5
RBMW
You can fix your pan. I have fixed many this way. Get an aluminum nut that fits your drain plug and have it tig welded on the inside of the pan. It wonít leak and itís cheap. A new gasket and the nut and a good welder to weld it unless you have a tig welder.
Old 03-19-2019, 03:56 PM   #6
thyde
My Ride: 2000 328i, 1994 YJ
Or you could always tap the next size up.
thyde is offline   Reply With Quote
Old 03-19-2019, 08:48 PM   #7
docnabimmer
My Ride: 2004 325XIT
Year: 2004
Model: 325XIT
Transmission: standard
Do you mean the Allen where you put the bit into to turn the plug or the plug threads that actually mates with the oil pan is stripped?...I'm reading the statement wrong...LOL
Sent from my LG-K371 using E46Fanatics mobile app
docnabimmer is offline   Reply With Quote
Old 03-19-2019, 10:25 PM   #8
Ettinger
My Ride: 4 doors, 3 pedals
Tap or replace pan & refresh gasket while you're there.
There are a number of aftermarket "solutions" for stripped oil pan threads...can't speak to their efficacy.
Ettinger is offline   Reply With Quote
Old 03-19-2019, 10:30 PM   #9
C3trevor
My Ride: 325i
Year: 2002
Model: 325i
Transmission: Manual
That happened to mine too. Just tap it, new drain plug. Cheap and fast and effective.
C3trevor is offline   Reply With Quote
Old 03-19-2019, 11:12 PM   #10
asm123
Hahah should have clarified...the allen where you put the bit into
Old 03-19-2019, 11:44 PM   #11
IdahoDoug
My Ride: Quattro 20V
I've heard of threads stripping on aluminum pans, but there are further threads unused and deeper up in the pan. Just a thought, but those were handled merely by purchasing an extra deep drain plug that Mercedes sells which provided the necessary clamping force to be leak free. For the OP, you'd need to drain the oil and take a look if there are threads deeper in, unless someone is able to tell you with authority that all the oil pan's threads are used with the factory BMW drain plug.
1984 Porsche 944, 1987 Toyota Supra 5M Targa (project), 1987 VW Vanagon, 1988 Mitsubishi Van Wagon, 1990 Audi 90 Quattro 20V 5M, 1992 Lexus LS400, 1993 Toyota LandCruiser full spec, 1997 Toyota LandCruiser full spec, 2018 Subaru Outback, 2002 325Xi sedan full spec, 5M (soon)
IdahoDoug is offline   Reply With Quote
Old 03-20-2019, 12:39 AM   #12
RangerDave
My Ride: '00 328i ZSP w/ 257k
Year: 2000
Model: 328i
Transmission: 5MT
I rarely even use the oil drain plug. I bought one of those vacuum pumps almost 10 years ago so I could do oil changes without getting under the car. $80 for the pump vs $2k for a new pan. You should consider this.
RangerDave is offline   Reply With Quote
Old 03-20-2019, 12:49 AM   #13
dck8267
My Ride: 2003 325ci M56
I had same thing happen and got a new bolt plus a bit of locktite on bolt and it does not leak at all where as before it dropped quite alot, worth a shot.
Sent from my SM-G955U using E46Fanatics mobile app
dck8267 is offline   Reply With Quote
Old 03-20-2019, 12:51 AM   #14
jmo69
My Ride: 03 325xi 98 328is
Isn't that for when you break the plug off in the pan so you can extract it.?
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 03-20-2019, 01:54 AM   #15
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
^This. No need ro replace the oil pan. Itís very easy to drill and tap to a larger size plug.
Old 03-20-2019, 12:17 PM   #16
asm123
Thanks everyone! Was able to get the old plug out and replace with a 13mm socket plug for future. Successful oil change
Old 03-20-2019, 01:01 PM   #17
Ettinger
asm123: FCP Euro's Lifetime Warranty includes oil! Why pay more than return shipping costs?
Snapped stud (?) off w/bolt for oil level sender...amateur mistake. This will be the last time I opt to leave the torque wrench on the asphalt...
Remaining two bolts are all set. Not the slightest leak observed after some time - yet this bothers me the same. Recommendations?
Old 03-20-2019, 01:31 PM   #18
dmax
dmax's Avatar
My Ride: '16 340i xD 6-spd
Year: 16
Model: 340i
Transmission: 6-spd
Wherever you went to change your oil might not be a place to return to. They got frightened and didn't either try hard enough, or didn't think to just vacuum out the oil.
Glad you got this sorted!
See Facebook for upcoming shows...and listen to my podcast!
Old 03-20-2019, 02:32 PM   #19
Alex323Ci
My Ride: M3 & 323Ci (sold)
people without an M3 donít understand we have a different oil drain bolt. itís an internal Allen that strips, not a bolt head. first buy a new one or better yet the upgrade is the M5 oil pan nut.
to remove old one there are a couple of tricks. Everything from vice grips to taking a torx head and forcing a tight fit, to a chisel on edges of nut to turn it to jb weld a screw head inside the Allen opening.
Old 03-20-2019, 03:30 PM   #20
74123
Guest
My Ride: 320i SE Coupe
So what's the condition of the plug at the moment? Is it in and leaking or out and won't go back in?
74123 is offline   Reply With Quote
oil, oil drain plug, oil pan stripped, stripped
Similar Threads
Thread Thread Starter Forum Replies Last Post
E46 330ci oil o-ring help bayarea_rolln General E46 Forum 10 10-26-2016 09:20 AM
Low oil level and ticking valves... ari00 General E46 Forum 2 12-02-2008 09:55 PM
ESS TS2 S/C Oil Change Question paraklas Forced Induction Forum 6 12-01-2008 05:31 PM
What are the typical reasons for losing oil? ninsei General E46 Forum 7 11-22-2008 04:08 PM
Need help with an oil leak... trig General E46 Forum 14 11-21-2008 09:54 PM
