***BMW ECU programming solution*** OPEN DISCUSSION inside please - Page 24 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 107 votes, 4.92 average. Display Modes
Old 02-24-2014, 10:59 PM   #461
diablorojo
My Ride: Supercharged 330i
I called ProEfi and they were not to sure on the MS45 over the phone. Has it worked for you, and how well? Have you used E85? How does it work with the CANbus. Is it near stock?
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 02-24-2014, 11:00 PM   #462
mdrobnak
My Ride: 04 330i SMG TT STG1
You should look at my thread.
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 02-24-2014, 11:54 PM   #463
diablorojo
read it....right, that's what I am trying to avoid, lol. Great build, I'm more of a hardware guy, software is my weak point. I need a plug and play system. And a system simple enough that a tuner could manipulate the values efficiently. Maybe you can market once you get this sorted, Ill be first in line
Ill check Motec...
Sponsored Links
Advertisement
Old 02-25-2014, 12:02 AM   #464
diablorojo
AEM infinity ...universal kit...would this be an option?
Old 05-26-2014, 12:56 PM   #465
wjnelson72
My Ride: 2002 bmw 325i
ecu
Hi, I need advice on this topic. Im replacing my 2002 325i engine with a 2002 330i engine
as I was able to get low mileage and fairly cheap. How can I update my software to to utilize
the 330i engine? Thanks
wjnelson72 is offline   Reply With Quote
Old 05-26-2014, 03:00 PM   #466
jony787
My Ride: 318ti M52tu SWAP
Do you have any programming cables??
jony787 is offline   Reply With Quote
Old 05-26-2014, 03:07 PM   #467
wjnelson72
Im not sure which programming cables to get or device or software. Im not gona tune the car (just yet) just want it to work for now.
Old 05-26-2014, 03:11 PM   #468
jony787
It doesnt matter if you are tune it or not, you want your DME with 325i setting (tuning parameters) to work with your 3.0 engine. You have two options. WINKFP or galletto 1260, if you have no idea of what im talking about, pm me.
Old 11-15-2014, 10:07 PM   #469
diablorojo
HELP!!!
Just completed the ms43 swap. No codes. TS3 tune. The car runs lean with MAF connected 19.5 and rich when not ..10.5
Don't see a boost leak. Should there be such a huge difference?
Old 11-15-2014, 10:08 PM   #470
diablorojo
HELP!!!
Old 11-17-2014, 01:15 AM   #471
daniel_f.
My Ride: 330iC
The MAF you´re using is M54B30 MS43 one? Can you check its not damaged by changing to another one? Your stage3 is generating so much power, the stock maf can´t recognize all that air blown through it.
No further development on MS4x from me.
Old 11-17-2014, 01:09 PM   #472
diablorojo
I will try. So is there another MAF that can be used? Yes ms43 MAF
Old 11-17-2014, 01:14 PM   #473
diablorojo
What are the MAF options? Mustang? Bmw 540? I'm thinking a v8. Or is it scaling? I was under the impression that you could not scale them because they don't physically read that high.
Old 11-17-2014, 01:19 PM   #474
daniel_f.
My Ride: 330iC
Well, one could scale them by using resistors but i wouldn´t use that option. As ESS seems to use the stock maf, i tend to think they changed to Alpha/n. The stock maf is just not capable of recognizing that amount of airflow.
Is there everything like it should be when using a stock MS43 car?
Old 11-17-2014, 08:15 PM   #475
diablorojo
New MAF worked better, no shudder at 2500rpms...idle is better without MAF but drivability is better with.
Here are my codes per pa soft however my check engine light isn't on.
The car drives fine and starts (tho AFR isn't optimal) so I'm surprised at these codes.
Old 11-17-2014, 08:38 PM   #476
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Check that the ignition coil grounds are properly connected. There are a couple on the cylinder head itself, held down with 8mm nuts.
Old 11-17-2014, 08:49 PM   #477
diablorojo
I have researched and it appears to be a grounding issue...
Old 11-17-2014, 08:50 PM   #478
diablorojo
Lol thanks
Old 11-17-2014, 09:17 PM   #479
diablorojo
Hmmm... the 2 nuts are secure on the ground wires....
What else ya got?
I checked the ground pin from the plug to ECU and it looks ok too...
Old 11-19-2014, 10:09 AM   #480
daniel_f.
My Ride: 330iC
I know its not the best idea, but one could turn off those diagnostics
custom tuning, dme tuning, flashing, kwp2000
