I want Iphone Music - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-14-2015, 02:00 PM   #21
jfoj
My Ride: 330CiC, M5, X5, E93
If you have a hard wired Aux solution, you pretty much have to run a PAC or similar ground loop isolator to eliminate noise.
If you are streaming via A2DP over Bluetooth you can usually get away without a ground loop isolator.
Using the PAC ground loop isolator:
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
And this dash mountable interface cable is a good way to go with all plug and play:
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Old 10-14-2015, 03:49 PM   #22
TLM
My Ride: 2001 325i Touring
The USA-Spec PA-12 is also an option at about $120 on Amazon. Used ones are readily available too. Been using it with an old iphone (3gs) for a number of years. It's okay. Sound quality wise, it's not CD quality so you have to turn up the volume more to hear the music. It's clearly not for critical listening, more for convenience.
If the Dension or other interface provides better sound quality, I'd upgrade to that.
'01 325iT - Ti Silver / Tannin Red 5 speed manual - The Daily
TLM is offline   Reply With Quote
Old 10-14-2015, 04:05 PM   #23
kbeaud
My Ride: 2002 330Ci
Originally Posted by lllRazorlll View Post
Get one of the Dice units. No need to make sure your headunit is updated, no wires sticking out of the front, etc. Route the wire from the CD changer in the trunk to the cigarette ash tray in the front and attach a bluetooth receiver onto it. Voila, anyone can play music now while the setup is clean and no one will ever know.
Which one exactly? Mediabridge? Silverline DUO?
kbeaud is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-14-2015, 08:12 PM   #24
lllRazorlll
lllRazorlll's Avatar
My Ride: Accord Coupe
Doesn't matter. As long as you have one of those, you will get a long cable that is routed from the trunk of the car all the way up to the front. I bought the basic $100 Dice kit and hooked it up in no time
I just realized that I purchased a similar thing from Bavsound. Here is a link to the one I purchased. It is the $160 one, up from $120 from when I bought mine in February 2013 and it now looks like they have cables for lightning connectors, but that will be $200.
http://www.bavsound.com/Device-Integration/Buy-Now/
Get the $160 one and then buy this bluetooth receiver:
http://www.amazon.com/gp/product/B00...=sr_1_1&sr=8-1
That way, if you switch phones or if anyone who doesn't have a 30-pin Apple device (let's face it, who still does at this point?) wants to play music, they can. I have been using this device for over 2 years now and it's excellent
lllRazorlll is offline   Reply With Quote
Old 10-15-2015, 09:56 AM   #25
rsyed07
My Ride: E92 335is, E46 330i
Just get the quidzel kit. No wires to run from the trunk to the head unit and it works for pre 2003 models. Did I menton $50? Not $100. It runs on your factory wires set up for your CD changer so the wiring work is done there for you. No static, pops, or whines. Just clear music.
330i ZSP | ZPP | ZCW
rsyed07 is offline   Reply With Quote
audio, audio upgrade, iphone, music
