The Permanent M54 CCV Delete - Page 11 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 02-19-2018, 04:42 PM   #201
Sneuf
My Ride: 2003 325xi
I scored a m56 valve cover from my local parts pull. I also grabbed the wiring harness. The smaller adapter on the new harness does NOT fit into the electronics box.
I have the push-on coils (Ď03 325xi) so I swapped the smaller connector from my current harness with the new one; same flat adapter but the tab is in on the wrong side. Anyway, now the car wonít start.(engine turns over). I installed new coil pack and plugs since I had to take them out. Iíve double checked they are installed right.
I thought I have to use the new harness. Did I make a mistake in swapping it out or can anyone think of something else I should double check?
Thanks!
Sneuf is offline   Reply With Quote
Old 02-19-2018, 06:38 PM   #202
kensic
My Ride: 325iT
Thanks!
if you have 03 model car *cars with push in coilover) you do not to swap over the wire harness. you don't even touch it.
kensic is offline   Reply With Quote
Old 02-19-2018, 11:56 PM   #203
Sneuf
My Ride: 2003 325xi
Kensic, thanks.
I removed the new harness and saw the wire config to the block connector was different than my original harness. I ended up de-pinning the new harness block to match mine. That worked.
I thought about just reverting the smaller connector back to my harness and using that, but then wondered about the 2 wires on the new harness that connect to the body (mine has only one).
Also, the PO said he had to replace the engine so the fact the block connectors had different color wire config seemed significant. Iím going to have to figure out exactly what model engine I have. I assumed M54 because of the push-on coils but my understanding is that those have the round power/ ground plug and mine was flat.
Anyway, just took it for a test drive and no issues.
Due to lack of time (been working on the car for the past 5 days) I connected the M56 valve cover to the CCV instead of the intake manifold. Other than 2 CCVs arenít needed, will i run into problems if i leave it this way for another 300 miles or so?
Sponsored Links
Advertisement
Old 04-10-2018, 11:22 PM   #204
ottoborden
My Ride: 2003 325i
Hey All,
I'm prepping to do this swap in a few weekends. I'm unsure about something and looking for a definitive answer regarding the line from the M56 valve cover to the M54 intake distributor. Can anyone confirm for me that I can simply run M56 hose (# 11157513756) from the VC and plug directly on the the M54 stock intake distributor? From the OP it looks like I can but just want to confirm that no modifications were made to the line and that was indeed the M54 intake distributor.
Thanks to anyone who can help.
ottoborden is offline   Reply With Quote
Old 04-10-2018, 11:23 PM   #205
ottoborden
My Ride: 2003 325i
Mistaken double post, please delete
Old 04-11-2018, 02:04 PM   #206
evogroup
My Ride: 2002tii, 325xi, X5
Ottoborden, I'm gathering parts and info for this swap myself.
From what I understand you need to cut the connector from the M56 vent tube (11157513756) and fabricate a connection to the M54 air distributor manifold which has a different style connector and two ports vs one on the M56.
evogroup is offline   Reply With Quote
Old 04-16-2018, 09:48 AM   #207
Weste46
My Ride: Has 280k mi.
Year: 2001
Model: 330ci
Transmission: ZF320
Have we discussed in any further detail the ground strap (12421437633)? I don't have one, I'm currently running the car, I don't know if I need one.
Thanks!
Suspension: Ultimo front coils, Swift 10k rear, Rob43 9-way shocks, TMS ARB's, Meyle FCA's, 95A FCA, 75D subframe, 95A RTA, 95A RUICA
Drivetrain: LTW FW, MFactory gear LSD, S65 mounts, 95A 5sp, 88A diff, SSK, intake, headers, x-pipe, open-loop EU2 tune
Brakes: Hawk DTC60/StopTech309, ECS front lines, DIY ducts
Interior: Corbeau FX1 Pro & CR1, Jaffster knob, suede wheel
Exterior: Custom CF sunroof delete
Wheels: 17x8.5 M68, 245 RS3
Weste46 is offline   Reply With Quote
Old 04-16-2018, 09:48 AM   #208
Weste46
Year: 2001
Model: 330ci
Transmission: ZF320
Thanks!
Old 04-17-2018, 04:49 PM   #209
Weste46
Year: 2001
Model: 330ci
Transmission: ZF320
Uhhhh so this is happening. I bought this cap new like 2 years ago. Hopefully that is where the oil smell is coming from....
Sent from my XT1080 using Tapatalk
Old 05-05-2018, 10:42 PM   #210
trentcdrums
My Ride: BMW 323i Sedan
15k miles doing just fine. Make sure you have a good I'll cover gasket
Sent from my [device_name] using E46Fanatics mobile app
Old 05-21-2018, 01:08 PM   #211
89five3five
My Ride: 2001 325i, 1989 535i
Sorry for bumping such an old thread.
I gather for cars with bolt-on coils, this would not work? Or can I switch to push on coils?
Also, if this is such a popular mod.... has anyone made wire harness adapters for cars with bolt on coils? I'm not great at cutting and splicing critical wires.
89five3five is offline   Reply With Quote
Old 05-21-2018, 01:08 PM   #212
89five3five
Also, if this is such a popular mod.... has anyone made wire harness adapters for cars with bolt on coils? Iím not great at cutting and splicing critical wires.
Old 05-21-2018, 01:20 PM   #213
WilloCO
My Ride: '05 330xi 6 speed
Actually, if you get another harness you can swap out the coil section pretty easily. It has it's own connector at the ECU and goes directly from the ECU to the coils. I'll go look at my spare harness in a minute and tell you if you need to cut anything.
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Old 05-21-2018, 01:22 PM   #214
Weste46
Year: 2001
Model: 330ci
Transmission: ZF320
There is no aftermarket plug-and-play solution that I know of. You can use push-style coils on a car with factory bolt-on coils with a new wiring harness and valve cover.
Old 05-21-2018, 01:24 PM   #215
WilloCO
Yeah it's a single harness section with connectors. The only concern I have is if the pinout is the same from your car to another car. I suggest getting your hands on a coil harness and comparing them. If you get a harness from an XI, those are all MS43 ECUs. The other cars changed to MS45 later on.
05 330xi 6 speed
Old 07-02-2019, 04:47 PM   #216
330shawn
My Ride: 2004 330i
Year: 2004
Model: 330i
Transmission: 6sp
Anyone knows how to get the plastic diaphragm cover and the spring? Got mine from E-bay and it didnt have the spring in it!
330shawn is offline   Reply With Quote
Old 07-02-2019, 09:20 PM   #217
ZHPizza
My Ride: 2005 ZHP Coupe
Anyone else checked the port on the valve cover and found oil? I'm hoping that's just pooled vapors
ZHPizza is offline   Reply With Quote
Old 07-03-2019, 09:19 AM   #218
330shawn
My Ride: 2004 330i
Year: 2004
Model: 330i
Transmission: 6sp
Can someone please measure the free length, outer diameter, and wire diameter of the spring?
I can find a vendor that sells a generic spring matching that spec and anyone else in the future can use the same spring! I think that would be very helpful!
Old 07-04-2019, 02:25 PM   #219
WilloCO
It's a good bet that the spring is the same as the one from the old PCV system, just gut it.
05 330xi 6 speed
Old 10-05-2019, 09:57 PM   #220
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
Originally Posted by XavierBK View Post
very nice .. thanks for the idea to powder coat!
wfx32 is offline   Reply With Quote
