More M54B30 Turbo for the Masses - Page 8 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-16-2019, 11:18 AM   #141
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
I removed the factory plastic hose across the top of the manifold for vacuum distribution. The F connector goes into one end that hose was on, as seen behind the strut brace
Turbo Build Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 03-16-2019, 11:20 AM   #142
d_cleverzz
My Ride: Manual 2001 330ci
Year: 2001
Model: 330CI
Transmission: 5 Speed Manual
This way it never sees boost?
IN SEARCH OF
CONVERTIBLE INTERIOR CARBON FIBER OR PIANO BLACK TRIM
ORIENT BLUE M3 VERT FRONT BUMPER
ORIENT BLUE VERT PRE-FACELIFT FRONT FENDERS
d_cleverzz is offline   Reply With Quote
Old 03-16-2019, 11:21 AM   #143
armenh7
My Ride: 2002 325i
Thanks for the picture. What about the icv?
armenh7 is offline   Reply With Quote
Old 03-22-2019, 08:46 PM   #144
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
So my smoking on cold start is getting worse. Big plumes at idle. Blue. And after a few minutes of driving it's gone. Where should I look?
Turbo Build Thread
Old 03-22-2019, 10:37 PM   #145
cwarel
My Ride: 330ci coupe
Oil piston rings ,or oil drain for turbo isnt straight enough , Untill I drille a hole in the block I kept getting oil going past seal on a turbo , now its good ,because at the oil pan or timing cover there was too many bends . But could be oil rings if u never did them .
cwarel is offline   Reply With Quote
Old 03-24-2019, 11:00 AM   #146
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Do you think trying a heavier oil could help the cold start issues? I understand it's not really a solution, but 10w40 or something could help
Turbo Build Thread
Old 03-25-2019, 07:54 AM   #147
cwarel
Actually heavy oil might make it worse , my friends car did the same thing, we tried to clean it with seafoam thinking maybe too much carbon buildup in between rings or something , once we did that it started smoking oil so much worse and it was burning it quite a lot , untill he drove it for a while and it stopped.
Old 04-01-2019, 01:30 AM   #148
Davo705
My Ride: e46330ci/ e30M54b30t
Good stuff man, is your catch can full??
When under boost and with the ccv valve in place you have to think about where the 'pressure' inside the valve cover goes.
And when you go from boost to vacuum it may just be sucking in all that blowby stuff??
What type of smoke did you see on dyno? oil smoke or maybe just rich fuel smoke??
Oil feed to turbo can cause smoke too, do you have a restrictor in the feed line? 1-1.5mm? And turbo drain too but NO restrictions. I had a RB30det where the oil actually sloshed up the drain which blocked the draining oil from turbo and smoked terribly from the exhaust.
just some thoughts...
Davo705 is offline   Reply With Quote
Old 04-01-2019, 09:57 PM   #149
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Updated Post 2 with cost breakdown of every part I can think of
Turbo Build Thread
Old 04-02-2019, 12:31 PM   #150
d_cleverzz
Year: 2001
Model: 330CI
Did you gap your new spark plugs or no?
Would you be able to add some link to some of the generic eBay stuff that you successfully used?
Great build
IN SEARCH OF
Old 04-02-2019, 12:32 PM   #151
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
I did gap the plugs to 26. I can update tonight with some links, it just gets messy with all the small parts
Turbo Build Thread
Old 04-02-2019, 12:33 PM   #152
d_cleverzz
Year: 2001
Model: 330CI
Perfect thanks.
Was the gap you decided to use specific to your setup?
IN SEARCH OF
Old 04-02-2019, 12:34 PM   #153
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
I didn't have much to go on. I found a few people using something like that supercharged at similar boost level
Turbo Build Thread
Old 04-10-2019, 03:05 PM   #154
MalibuMafiaV
My Ride: E60 M5 & 335i ST
Good thread bro. Looking forward to seeing it next month in person!
TheMalibuMafia.com
Instagram
BMW E60 M5 - Daily
Way too many to list
MalibuMafiaV is offline   Reply With Quote
Old 04-21-2019, 01:19 PM   #155
cwarel
Do you have issues with boost creep? 1 to 2 nd gear its spring pressure butin third it goes to 15 psi where spring is 7 psi spring. I think Im gonna relocate wastegate position on this manifold
Old 04-21-2019, 01:33 PM   #156
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
It's creeping but I'm not sure if it's a controller issue. I'm going to move the controller feed from the manifold direct to turbo outlet. Hits 7 quick but only gets to 10 at redline. 12% duty cycle. AEM truboost
Turbo Build Thread
Old 04-21-2019, 05:07 PM   #157
cwarel
Yeah thats how I have my boost controller set up from manifold. I have SCG 1 innvovate. I even put a bigger waste gate , that never used to happen to me before. always at 10 psi.
Old 04-21-2019, 05:18 PM   #158
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
It's not over boost, it just isn't linear boost. The wastegate still cracks at 7psi which is about 5 at the manifold, and then it rises to 10 at redline. With boost controller off it doesn't rise
Turbo Build Thread
Old 05-22-2019, 11:32 PM   #159
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Boost irregularities were fixed by moving the vacuum lines for the wastegate to come directly from the turbo. Pressure drop across the intercooler was doing weird things. AN oil drain and M56 cover going on soon
Turbo Build Thread
Old 06-26-2019, 10:26 AM   #160
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Bump. M56 cover done and AN oil drain done. Had to completely retune since I guess we always had air leaks.
Turbo Build Thread
