I'm here to "ruin" an E46: A rallyx build. - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 01-16-2019, 01:19 PM   #41
TheNorm
My Ride: 323i
offseason upgrades. I've been waiting for the ice to freeze so i can go ice racing, but the events keep getting canceled, not cold enough
in the meantime, I put in a version of the vince bar.
ours is a little simpler to fab than his as we werernt trying to hide it under the floor. a 2x2 box section. moved forward an inch, so that we could just drill right through it to bolt it in. and end plates welded to the chassis.
the bolts needed the most work. i bought m12 x1.5 x 160mm 10.9. https://www.belmetric.com/12x15-fine...09-p-2499.html
but needed the threads to be extended. I used carbide die, but I dulled it horribly. take my advice and find someone who knows how to thread on a lathe. an alternate, no fab, option would be to use threaded rod, and just put nuts on each end.
another interesting tidbit, many lug nuts are 12x1.5 thread, so I flattened the conical part of some extra open lug nuts i had, and used those to "bolt" the bar down. its still threaded into the original subframe mount, this is supplemental clamping force.
hoping this will reduce the chance of us tearing out our subframe mount repairs we previously did.
total cost of the project was ~$30 plus some welding supplies.
TheNorm is offline   Reply With Quote
Old 02-15-2019, 05:04 PM   #42
TheNorm
My Ride: 323i
so, planned on driving to an ice race event. didn't even get to my friends house to pick him up before i got the low coolant light. Never seen that one before, and I had just topped up the coolant, so we quickly swapped to his car to race. Good thing it died where it did, else we might have got stuck on the side of the road hours away form anywhere (it was a 3.5 hr drive to the lake). Anyways FWD with shitty winter tires is not as much fun as RWD on studded hakkapelitas.
post race dissection found a cracked radiator end cap, at the nipple where the large hose from the water pump connects. you can see the wet spot.
anyways, new radiator being shipper, and it should be good to go for the next race. In the meantime, there is a race this weekend, and I'll co-drive another friends Subie STI on brand new hakka 9s. should be good.
Old 02-21-2019, 03:18 PM   #43
TheNorm
My Ride: 323i
car was still not ready to race.
so I codrove a friends STI on new hakka 9 studded tires at an ice time-attack
won the 4wd studded class.
twas fun
Old 03-08-2019, 10:43 AM   #44
Tate325xi
My Ride: 428i cabrio
God that looks fun
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 04-10-2019, 02:59 PM   #45
TheNorm
My Ride: 323i
so, fiexed the radiator, and after a little trouble bleeding the cooling system took it ice racing.
there we found a car that was very difficult to control. ultimate diagnosis was a torn trailing arm bushing. the sudden changes in toe would make the rear of the car very loose and suddenly crabwalk a few feet to the side.
Anyways, made my own bushing limiters with some plastic sheet and a hole saws. they may not be pretty, but they were free, and took up all the slop.
going to a dirt rallyx this weekend so we'll see what the improvement is.
