My plagued front brakes - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 04-25-2019, 01:07 AM   #1
Chase.bandz
My Ride: 2002 325i Manual
I am stumped on this issue and need some input. I've had me e46 for 3 years now and me and my front brakes have always had issues. Here is the order of issues I've had.
Feb 2017-replaced front pads and rotors
July 2017-front caliper seize, replaced with re-man. New lines as well
Feb 2018-replaced rotors due to vibrations
Jan 2019-front caliper seize, front calipers rotors and pads replaced
April 2019-vibrations again-going to have to replace rotors and clean pads again
My fluid has been flushed by me and my good guy BMW mechanic that I trust with my life. I feel as if it is weird that the calipers have froze twice in two years and I also keep coming into vibration issues.
Any input would be very very valuable
-Thanks!!
Chase.bandz is offline   Reply With Quote
Old 04-25-2019, 01:45 AM   #2
Sapote
My Ride: 2000 323i auto wagon
Vibrations under what conditions? Hard braking? You're sure ABS not kicked in causing the vibration?
Sapote is offline   Reply With Quote
Old 04-25-2019, 01:50 AM   #3
Chase.bandz
Yeah no 100% sure it's not ABS it's bumps on the rotors. It's the basic symptoms-vibrations increase at higher speeds, feel in wheel and brake pedal, light breaking.
Sponsored Links
Advertisement
Old 04-25-2019, 06:22 AM   #4
markusmarkus
My Ride: 2018 M240i
What brands of brake parts have been installed?
Old 04-25-2019, 07:25 AM   #5
dmax
dmax's Avatar
My Ride: '99 328i 1.569 mu
Year: 99
Model: 328i
Transmission: 5-spd
Vibrations only when braking? It could be the wheels being off-balance...and when you clamp onto them in braking, it attenuates their off-balance.
Also, consider the control arms/bushings.
See Facebook for upcoming shows...and listen to my podcast!
Old 04-25-2019, 09:19 AM   #6
Chase.bandz
Good thought but again Iím sticking with warped rotors. Just because I know how they feel on this car and the vibrations are worsening.
Control arms are not even 6 months old and brand new struts on aswell!
Old 04-25-2019, 07:13 PM   #7
armenh7
My Ride: 2002 325i
If you think it's your brakes, the last piece of the system is the master cylinder. I think it's a suspension issue. Have you swapped the front and rear wheels?
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 04-26-2019, 01:05 AM   #8
Chase.bandz
I did have a suspension issue until recently. One of my front struts pretty much busted and the car liked to bounce a lot on the highway and shake real bad for a couple weeks. I replaced both front struts so that's done now but could that be a cause?
Also I'm running the same 17' wheels that came with the car. Do you mean rotate them to see if it's the wheel or the rotor?
Old 04-26-2019, 01:10 AM   #9
armenh7
My Ride: 2002 325i
Yes.
Similar Threads
Thread Thread Starter Forum Replies Last Post
My adventures in fixing my front end clunk/vibration. hi its me alec General E46 Forum 28 05-18-2010 06:26 AM
How long do your front brakes last? thefreeze General E46 Forum 30 04-21-2010 10:13 PM
cool details of S54 330indy ///M3 Forum 32 02-11-2010 05:22 PM
E46 M3 stock suspension rear end front suspension and brakes + more Gorzun Suspension and Braking 10 11-05-2009 10:22 AM
help with front brakes? ViNNiE_G DIY: Do It Yourself 3 08-19-2009 01:55 AM
