My new 2002 M3 6 Speed. My Build. - Page 8 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 04-24-2019, 01:34 AM   #141
Aussigazza
My Ride: E46 330i and M3
Year: 1999
Model: Now 330i
Transmission: 6 Speed M3
My First Ever Track Day!!!!
Video to come.
Gearing is not suited to the track, but lots of fun.
First time ever, but hit 160kmh on the straight eventually.
Front left tyre took a hammering.
Garry
Aussigazza is offline   Reply With Quote
Old 04-24-2019, 05:39 AM   #142
AndyMac
My Ride: Carbon Swartz E46 M3
Nice work.
Wakefield will always punish the left front.
Great to see another E46 M3 out on track. Look up the BMW NSW Drivers Club for future events too Garry. We're at Wakefield, Marulan and Winton each year.
I see nothing...
AndyMac is offline   Reply With Quote
Old 04-24-2019, 05:55 AM   #143
Aussigazza
Year: 1999
Model: Now 330i
Originally Posted by AndyMac View Post
Nice work.
I will look the club up. Video hopefully:
http://sendvid.com/y20bsjer
Garry
Old 04-25-2019, 06:49 AM   #144
Aussigazza
Year: 1999
Model: Now 330i
Better Link.
Put it on YouTube.
Garry
Old 05-02-2019, 03:11 AM   #145
Aussigazza
Year: 1999
Model: Now 330i
Upgrading diff!
Booked in for 17 May for Difflab upgrade:
Complete differential assembly and blueprinting. E46 M3 4.10 35% LSD.
Strip, clean and inspect E46 M3 original differential. Supply and install genuine BMW Motorsport 4.10 ring and pinion. Supply and install 35% 2-way LSD unit. Supply and install symmetrical output shafts. Supply and install genuine rebuild kit. Blueprint differential and check meshing pattern. Deliver to partner workshop in Brisbane. Environmentally friendly oil disposal.
Seeking street/strip performance.
Garry
Old 05-17-2019, 12:23 AM   #146
Aussigazza
Year: 1999
Model: Now 330i
New Diff is In
Pic of old diff:
New 4.1 diff has raised rpm by about 300 rpm at 100 km/h.
Big difference in ‘punch’ under accel.
35% lock up both ways is interesting when tight reverse turning.
Garry
Old 05-23-2019, 03:40 AM   #147
Aussigazza
Year: 1999
Model: Now 330i
More Minor Fixes
Big recommendation for Brisbane Motor Works who did my diff exchange.
They looked over the car and gave me a list of problems.
Replaced left front strut today that was leaking. Had oem spare.
Spring was clocked wrong on rhs. Easy fix when you have shorter springs as you can manhandle them into place when on the hoist.
They picked up an oil leak. Was me overfilling power steering.
Pointed out that whoever did the rear subframe reinforcement should have used spacers to reduce stress where no reinforcement was needed. They only use Turner kits.
Pointed out a stress crack in the exhaust pipe that I will weld up.
Pointed out cracked left fog light. Got hit by a lot of gravel on trip. Bloody trucks.
I need to replace rear upper shock mounts.
Planning on a track day with instructor mid June.
Garry
Old 06-11-2019, 03:13 AM   #148
Aussigazza
Year: 1999
Model: Now 330i
6 Pot Calipers.
6 pots from ecs on doorstep... Now on car!
Had to bend backing plate in on the top and bottom, and also a bit more at one of the plate mounts.
My 18in rims will need a spacer to fit. 19in csl rims are perfect fit. Not sure about std 19in M3 rims.
last pic is of 18in rim to show its offset (I hope).
Colour match is VERY close to Phoenix Yellow.
More to come as I have carbon fibre wings for bottom of front bumper and also rear shocks to replace.
Garry
Old 06-12-2019, 01:45 AM   #149
Aussigazza
Year: 1999
Model: Now 330i
Carbon Fibre Canards? Splitters?
Double sided taped on.
Garry
Old 06-15-2019, 03:53 AM   #150
Aussigazza
Year: 1999
Model: Now 330i
New Rear Shocks
Bilstein B6 and new mounts and bump stops etc.
Garry
Old 06-18-2019, 02:44 AM   #151
Aussigazza
Year: 1999
Model: Now 330i
Porsche Rear 4 Pots
Sand blasted, primed and first coat.
Burkhart adaptors and hoses.
‘BMW Performance’ vinyl labels on way. Clear coat over top.
Garry
Old 06-19-2019, 01:19 AM   #152
Aussigazza
Year: 1999
Model: Now 330i
Caliper Test Fit
986 calipers need to have the supplied spacers between the adaptor and the car. Easier to mount adaptor first. Rotors are under the 18.4mm minimum, so need new ones.
Garry
Old 06-19-2019, 03:18 AM   #153
Aussigazza
Year: 1999
Model: Now 330i
Started Mounting Brakes
Will put labels and clear coat later.
Found that the new hose does not have the metal ring to go on the middle-mount. First grommet I found in my stash was perfect. Cut slot and took mid-mount off to sand blast and paint black.
Garry
Old 06-20-2019, 12:56 AM   #154
Aussigazza
Year: 1999
Model: Now 330i
All Done bar the Label
Joined the wear detectors so Porsche works with BMW. 2 wires to 2 wires.
Drilled holes in the bottom of the hose’s mid-mounts so I could add on zip ties for insurance. The ring around the hose is meant to be metal so the wedge can clamp on.
Enormous increase in pedal feel and less travel.
Garry
Old 06-26-2019, 12:18 AM   #155
Aussigazza
Year: 1999
Model: Now 330i
Needs a Spacer
Needs 5mm minimum spacer to fit 18" rims on top of the 6 pots.
Update. Wobble at speed. Needs hub centric spacer. Minimum I have found is 10mm. Just ordered some. Thinking of attaching them to the wheels by drilling and tapping.
Garry
Old 06-29-2019, 03:38 AM   #156
Aussigazza
Year: 1999
Model: Now 330i
Rebuilding Rear Calipers
Decided to sandblast and rebuild the rear calipers.
Will sell them soon. Will be black like fronts and will sell front and rears with skimmed front rotors when done.
Pads on front are bembos (near new) and rears will be new HELLA Pagid Brake Pad Set Rear T1117.
Garry
Old 07-01-2019, 01:05 AM   #157
Aussigazza
Year: 1999
Model: Now 330i
New E Brake Springs
New StopTech rotors here tomorrow. Took opportunity to replace my stretched and bent (by me..) springs.
Garry
Old 07-03-2019, 11:50 PM   #158
Aussigazza
Year: 1999
Model: Now 330i
10mm Centric Spacers Do Not Fit
Tested on my M3 and also a 318i rear end.
About 13mm needed to bottom out on both these hubs.
Only get 10mm on these ones.
Talking with eBay vendor to check if 15mm ones will fit OK.
Wanted for track days.
Update: Seller disowns that they do not fit. Be careful and ensure that the allowance for the hub boss is about 13mm.
Garry
Old 07-08-2019, 03:21 AM   #159
Aussigazza
Year: 1999
Model: Now 330i
More Brake Work
Put high temp labels on rears, and also rebuilt the old rears for sale with my old fronts. Awaiting new braided rear hoses prior to sale.
Old fronts:
Garry
Old 07-18-2019, 01:39 AM   #160
Aussigazza
Year: 1999
Model: Now 330i
Replacing Auto Fold Mirror
Finally found an affordable one. Black.
Had a painted shell, so decided to depin and move internals to new shell.
Sandblasted base and painting it yellow.
Update,
Was sent a manual fold...
Missing 2 wires. Talking to seller...
Garry
