Biggest MS43 tuning thread ever! Incl software... - Page 360 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 4.97 average. Display Modes
Old 06-17-2019, 09:13 AM   #7181
Pov06
My Ride: 325
Originally Posted by CarbonZHP View Post
Anyone know where the value that controls when the o2 sensor activation is? Currently fighting to keep the car alive on cold start until the o2 begins compensating.
Fixing the symptoms and not the root cause is not the right way to solve this
Pov06 is offline   Reply With Quote
Old 06-17-2019, 10:58 AM   #7182
donBogi
My Ride: 325i
Why are we retarding the cams at high rpm and load again?
Gesendet von iPhone mit Tapatalk
donBogi is offline   Reply With Quote
Old 06-19-2019, 08:56 AM   #7183
10le
My Ride: e46 325Ci
Year: 2002
Model: E46
Transmission: MT
Gas dynamics reasons (retarded exhaust cam--> max overlap; retarded intakecam--> max time for the sonic wave to came back and push air into the cylinder, small over pressure (1.02bar). The old race engines run max. overlapping (advanced intake cam & retarded exhaust cam). Modern engines run retarded exhaust and intake cam,
but M54B25 do not react to this.
Tried both, but no positive feedback of the engine.
All I explained is for max power (high rpm and full load) for all other points it is different!!
Sent from my SM-G965F using Tapatalk
10le is online now   Reply With Quote
Old 06-20-2019, 10:28 AM   #7184
donBogi
My Ride: 325i
That was also my problem, it reacts best at default values. Very unsatisfying
Old 06-20-2019, 11:05 AM   #7185
loliipop1337
My Ride: Bmw E46 320CI
Year: 2002
Transmission: Manual
Does anyone know what the map "id_pvs_fl__n" does? My guess is limiting the full load tps value, but why? None of the values are 81 or what the max value is for the throttle body.
And what is the difference between the maps "c_ti_ad_(max/min)_cyl_lam" and "c_ti_(max/min)_cyl_lam". Wondering since im trying to get the fault codes 202/203 and 227/228 to only come on when it acually is "off-limits".
loliipop1337 is offline   Reply With Quote
Old 06-20-2019, 11:11 AM   #7186
loliipop1337
Year: 2002
Found the first question on the wiki, read past it first. But the second question still stands.
Old 06-20-2019, 03:13 PM   #7187
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Transmission: 5 spd manual
2.5 engines are the most maxed out on top of its power, to feel positive effects you need a gain of at least 20 hp ,..gain that is not software achievable. 2.5 guys should focus on midrange improvements,rather than top. For top, better,higher flow is required,and that implies hardware changes.
scorpionreptyle is offline   Reply With Quote
Old 06-21-2019, 04:48 AM   #7188
Blu302
My Ride: '98 E46 323i
I would believe you if my stock hardware 2.5 X3 didn't keep up with Toyota Sportivo or ZR6(V6) after only software mods.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 06-21-2019, 05:34 AM   #7189
donBogi
My Ride: 325i
Any hints which way to go with vanos, especially with the b30 intake cam?
Old 06-21-2019, 09:25 AM   #7190
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
there are lots of "192hp" BMWs that keep up and even beats cars, disregarding power/weight ratio.
With stock parts in mind,i dont see anything on the software side that can make a serious difference on top power. Vanos intake is optimised for full retard early enough, exhaust do nothing on top with stock manifold, injection will be corrected by post lambdas, ignition give minimal improvement - for some perform worse than stock. Without proper scavenging those engines wont increase their volume and wont make enough power to push you harder enough to perceive a change for "before and after".
If you find the spot of improvement for stock toys... let them try out!
..i did not spend enough time on 2.5 /2.8 to be 100% certain of what i say , i`m based mostly by the way the maps look like.
Old 06-22-2019, 03:47 AM   #7191
Masterchief83
My Ride: 2003 E46 325i Sedan
Year: 2003
Model: E46 325i Sedan
Transmission: MT
Hi Guys,
can anyone explain that dashpot stuff to me, i don't get it, i want to use the engine Brake at it's fullest strength down to around 2k Rpm, i found those two tables (descripted as "throttle daspot factor" ip_pvs_dif_neg_fac__pvs_max__n and "throttle dashpot decay factor" ip_pvs_dif_cr_neg__pvs_max__n).
How should i change values? How do they work? Should i zero them out?
I Already played a bit around with the values but there was no noticable effect, so what am i doing wrong?
Masterchief83 is offline   Reply With Quote
Old 06-22-2019, 03:47 AM   #7192
Masterchief83
Year: 2003
Transmission: MT
double Post
Old 06-22-2019, 06:27 AM   #7193
10le
My Ride: e46 325Ci
Year: 2002
Model: E46
Transmission: MT
Did install headers on M54B25. At part load I have (currently) all disadvantages (increased fuel consumption, reduced torque) because of not modified VANOS- setup. But I think to see advantages at high rev and high loads.
Old 06-22-2019, 06:48 AM   #7194
Blu302
I must be doing something right as the DME(MS45.0) is reporting up to 288NM at 4700rpm and 265NM at 3000-3500rpm using Testo for logging.
Much better than the stock 245NM max it reported across the whole range.
I will post a screen shot of my cam settings soon after I have have the fuel sorted better.
Old 06-22-2019, 06:58 AM   #7195
10le
My Ride: e46 325Ci
Year: 2002
Model: E46
Transmission: MT
Can you give me your secrets??
If I read your post, I feel like an idiot.
It is good to have someone better in the group.
Old 06-22-2019, 08:13 AM   #7196
donBogi
My Ride: 325i
Thanks! Kind of you.
I started doing small steps through the vanos maps to check for power. The hardest part is to find time analyzing and testdriving. Now we have insane temperatures in Germany which donít really allow serious setup testing
Old 06-22-2019, 11:14 AM   #7197
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
i think you misunderstand me. i repeat myself : B25 engines is maxed out on TOP of its powerband, there is almost nothing to do to improve performance in a manner that you can feel it (on stock form/parts). B25 guys should FOCUS ON MIDRANGE improvements.
You say you did something that contradicts me ,but you do that on midrange.
Top range i refer at, lies around peak hp range 5.7k ~ 6.5k+
Old 06-22-2019, 11:49 AM   #7198
cwarel
My Ride: 330ci coupe
My friends 2.5 is going out ( gonna do 3.0 swap) ,so we decided to blow it , just threw 6 degrees of timing eveywhere did some vanos adjustemnt , some more fuel and sent it. Since there is no gauges on the car I left 1 precat sensor to do the work I guess. And ofcourse pop exhaust cuz why not >> From exhaust pop the muffler exploaded like a bomb)))) Stock exhaust sytsem and got ebay headers on it. Right now he driving the car he says it got a lot more responsive and faster "butt dyno". So next another 4 degrees maybe ?)))
cwarel is offline   Reply With Quote
Old 06-22-2019, 12:46 PM   #7199
10le
My Ride: e46 325Ci
Year: 2002
Model: E46
Transmission: MT
Next German!
Old 06-22-2019, 05:07 PM   #7200
Masterchief83
Year: 2003
Transmission: MT
Maybe you get some support with fuel sorting if you share the actual stand where you are, i'm open for some test runs across upcoming week and i think i am not the only one.(Could do 2 Test runs per day, 1 in colder morning and 1 at top themperature)
Regarding upcoming themperatures of around 38 degrees celsius here that could get interesting.
