Official thread for people with non-working Launch Control - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-20-2016, 07:43 AM   #21
thecos
My Ride: 2002 325i Sedan
Daniel, after flashing the latest file and pulling the 64kb flash from it TunerPro shows weird values under Launch Control, when using the LC XDF.
255 for LC Configuration
8160 for Max RPM
etc.
Do you know why that is?
thecos is offline   Reply With Quote
Old 03-20-2016, 08:22 AM   #22
daniel_f.
My Ride: 330iC
Yes, in the case of THAT particular file those values are no longer important. Just leave the file as it is, flash it onto DME, take the engine for a short ride and test if RPM is limited at ~3000rpm when clutch is pressed and that the normal rpm limiter for neutral gear is working when clutch pedal is not pressed.
I simply changed the code to switch between manual gearbox rpm limiter and auto gearbox rpm limiter, Itīll behave like a LC and its tuneable like to other version.
I just need to change the xdf for that particular software to remove that glitch and make it easy to tune. Unfortunally i can only do so if this tweak does the job for all of you, so its crucial that i get feedback...
No feedback, no progress
Current licensing status:
Security implementation *done*
Implementing Flex Fuel
Siemens MS43 wiki!
Old 03-20-2016, 10:22 AM   #23
thecos
Works as advertised now. New file holds rpm at 3k even smoother, almost no bounce, only when clutch is depressed. I will keep testing but it seems to be working.
Sponsored Links
Advertisement
Old 03-20-2016, 11:01 AM   #24
daniel_f.
My Ride: 330iC
Please keep it testing for actual launch control behaviour
You can raise c_vs_min_gear_1 if the launch control goes out to early
Siemens MS43 wiki!
Old 03-20-2016, 02:13 PM   #25
thecos
Did more driving. It's holding the RPM at 3k for as long as I keep the pedal floored. I will keep testing.
Old 03-21-2016, 10:20 AM   #26
daniel_f.
My Ride: 330iC
I edited the first post and added a modified version of the 64kb fxdf so you guys with LC problems can tune it almost like the "real" LC.
Siemens MS43 wiki!
Old 11-09-2016, 12:40 PM   #27
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Transmission: 5 spd manual
for M54B30 without clutch switch exist such a setting to simulate LC?
scorpionreptyle is offline   Reply With Quote
Old 11-09-2016, 12:48 PM   #28
daniel_f.
My Ride: 330iC
No, without a clutch switch it wonīt work.
If you have a solution in mind, let me know.
Siemens MS43 wiki!
Old 11-09-2016, 01:16 PM   #29
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
something like a speed based limiter..
Old 11-09-2016, 06:49 PM   #30
matt270avian
Banned User
My Ride: 2002 325XI
Daniel, the file hosting site says it no longer has the xdf. Can you re host it please?
matt270avian is offline   Reply With Quote
Old 01-01-2017, 08:10 PM   #31
fipse
My Ride: e46 330ci
Hi there,,
LC isn't working on my 330 as it supposed to do (clutch switch is working fine)
1. what exact file did you flash -- MS430056_M54B30_Logger_EWSsignature_CHK5off_LC.bin
2. what exact xdf are you using -- XDF_MS430056_64kb_Eng_Level_Launch.rar.xdf
3. did you modify anything on the tune before or after flashing -- Exhaust Popping, the vanos tweak, different throttle map, LC rpm to 2464,LC_Vmax to 8kmh, PVSmin to 52°
4. what engine are you running -- m54b30
5. what gearbox does the car have -- 6Speed manual
6. what diff are you using -- stock
7. whats the behaviour of the launch control passing launch rpm -- bouncing once at 3k once, then to redline*
8. upload your latest full flash file where LC does not work and drop me a PM with the link - pn box full :p
*lc works when i'm in neutral, when i put in first gear it does as described above
Could it be, that it has something to do with temperature? it currently -11°C outside and my interior heating is not working (heater valve died 2 days ago) :/
fipse is offline   Reply With Quote
Old 01-02-2017, 12:03 AM   #32
daniel_f.
My Ride: 330iC
Its a common problem that 6speed manuals tend to donīt like the implementation of LC. Why is that? I have no idea, honestly.
Siemens MS43 wiki!
Old 01-02-2017, 02:01 PM   #33
fipse
My Ride: e46 330ci
Could it be, that it has something to do with the gear setting? There are always gear 0-5 in the xdf and in the a2l. How do the dme know if i'm currently in the 6th gear if G0 is neutral and what tables it is using?
What is if we enable LC for G0-5 and remove one gear by another to try if we get the right one...
>>just an idea, don't know if it makes sense
-f
Old 04-03-2017, 08:14 PM   #34
Operator62
My Ride: M30B35
I don't have the option for adjusting hysteresis on mine. It has the "on/off" switch. What is that even supposed to be? What is it supposed to be set to?
Operator62 is offline   Reply With Quote
Old 04-07-2017, 11:29 AM   #35
fipse
My Ride: e46 330ci
Set it to 1 for LC
Old 05-01-2017, 01:25 PM   #36
Ms42E46
My Ride: E46
Can some1 help me out fixing Launch control and popcorn limiter in ms42 320tu dual vanos 150hp
Im downgraded to sw version 0110AD
Im able to read and write full flash
Im able to sync ews
Ms42E46 is offline   Reply With Quote
Old 05-04-2017, 07:26 PM   #37
Mariosanchez55
My Ride: 2002 330ci
what about m54b30?
Mariosanchez55 is offline   Reply With Quote
Old 05-05-2017, 01:07 AM   #38
sda2
My Ride: BMW E46 330i Touring
Originally Posted by Mariosanchez55 View Post
what about m54b30?
3 liter, inline six, 24 valve engine
Need more info?
sda2 is offline   Reply With Quote
Old 05-05-2017, 03:36 AM   #39
daniel_f.
My Ride: 330iC
Need more info?
Probably asking because most people in this thread have problems with the M54B25.
Next iteration should remove all problems.
Siemens MS43 wiki!
Old 05-05-2017, 10:45 AM   #40
Mariosanchez55
My Ride: 2002 330ci
I know that... i was asking because the attached file is for an m54b25 only. Daniel_f stated so in the first post
