MS45 xdf creation... - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-07-2017, 04:10 PM   #21
Jokerr
My Ride: BMW 325
Originally Posted by armenh7 View Post
What did you use to read the maps?
you mean reading from ECU ?
bdm 100 - full reading
kess - partial...
found
Target Coolant Temp without A/C
Target Coolant Temp with A/C
not so many, but I`m working on this)
searching for injection maps
Jokerr is offline   Reply With Quote
Old 11-07-2017, 05:24 PM   #22
E46Envyy
My Ride: 2004 330ci
Transmission: Automatic
Sub'd
Make choices; don't look back
E46Envyy is offline   Reply With Quote
Old 11-07-2017, 05:56 PM   #23
armenh7
My Ride: 2002 325i
kess - partial...
found
Yup, that's what I mean. Did you get the bdm 100 from eBay?
For partial read can we use galetto?
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-07-2017, 07:12 PM   #24
Jokerr
My Ride: BMW 325
Yes
Galetto 1260 doesn't read/write ms45 ((((
but I think that is possible to read/write partial with d-can
at least Winkfp can write it.
Old 11-07-2017, 07:22 PM   #25
armenh7
My Ride: 2002 325i
Yes
Ah okay. Thanks for the info
Old 11-07-2017, 08:02 PM   #26
rkneeshaw
My Ride: 330i ZHP
I've used PASoft to do a 1024 byte read from the MS45.1 over OBDII, but it is VERY slow. Took me about 1.5hrs to do a full read (using read mode 02)
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread: https://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i ZHP
rkneeshaw is offline   Reply With Quote
Old 11-07-2017, 08:03 PM   #27
armenh7
My Ride: 2002 325i
Pa soft seems like it's very powerful. I never knew it could do that. So this means we don't need bdm for a full read? Can it write?
Old 11-07-2017, 08:03 PM   #28
Jokerr
My Ride: BMW 325
can You upload the file here ?
Old 11-07-2017, 08:06 PM   #29
Jokerr
My Ride: BMW 325
I want to compare the files from BDM & PA-soft, if they are identical - it`s would be great.
Old 11-07-2017, 08:09 PM   #30
armenh7
My Ride: 2002 325i
Yup. But how much quicker is bdm?
Old 11-07-2017, 09:56 PM   #31
m54e30t
My Ride: e30
would be interesting to know whether the ms45.0 (euro) can be updated to run ms45.1 simply through software, and add the the required pins for the WBO2 sensors if all else is pinned the same.
Similar to how all MS41.x DMEs are the same DME hardware with just a different software version.
m54e30t is offline   Reply With Quote
Old 11-07-2017, 10:18 PM   #32
Jokerr
My Ride: BMW 325
not possible, I've been trying to put full flash into ms45.0 from ms45.1 with BDM... it's not even started.
Old 11-07-2017, 11:19 PM   #33
armenh7
My Ride: 2002 325i
Quick question, does anybody know a working bench setup for obd2? Since we now know that pa soft can read it, what pins are needed to make a bench?
Old 11-08-2017, 12:08 AM   #34
Jokerr
My Ride: BMW 325
32 pin x60004 - k-line
26 pin x60004 - ign
7 pin x60001 +
4 pin x60001 - GND
Old 11-08-2017, 12:09 AM   #35
armenh7
My Ride: 2002 325i
Old 11-14-2017, 05:26 PM   #36
e60fan
My Ride: 525i
Main problem running MS45 mafless aka alpha-n revs go down slow. Going crazy developing solution.
e60fan is offline   Reply With Quote
Old 06-04-2018, 06:40 PM   #37
armenh7
My Ride: 2002 325i
Hey guys I finally got my bdm pins aligned and read the full flash off of the DME. Here is the file https://www.sendspace.com/file/kw21rm.
The DME is from a M56 SULEV but that shouldn't make a difference.
Hardware number 5WK93017 Index 02
Part number 7533652
VIN: WBAAZ33474KP85361
Old 06-05-2018, 06:46 AM   #38
rkneeshaw
My Ride: 330i ZHP
Part number 7533652
Hmm, that's not quite what I was expecting, I was thinking this would either be a 1024kb full read, or the 128k data section, but this file is like 513k. I was curious to see what software and configuration version is loaded on this DME.
2003 BMW 330i ZHP
Old 06-05-2018, 09:22 AM   #39
armenh7
My Ride: 2002 325i
Maybe I switched around the bdm pins? I'll try again with them switched around. The program read the full flash within a minute or two
Old 06-05-2018, 11:38 PM   #40
hassmaschine
My Ride: '91 325ix
The full read is compressed. You need to use the BDM software to extract the bins from the compressed file. On the PPC based computers they often have multiple files (internal, external, serial eeprom) so when you do a full read or write it includes all of them in one file.
Late to the party but we factored the private key a couple years ago now (cool to see JimC is still active though! He's a legend!). Its not even that hard for a 512bit key on a modern PC, it just took a couple weeks (unfortunately a 1024 bit key is still impossible). All of our MS45 files are signed like they were stock - and yes, including all the checksums, even the "hidden" ones.
hassmaschine is offline   Reply With Quote
