bmw e46 Control Panel with ShiftLight - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-14-2018, 12:41 PM   #41
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Pretty cool device. I like that it actually has car control
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 10-25-2018, 06:21 PM   #42
zelaktv
My Ride: bmw e46
Model: 320ci
Transmission: manual
Also here is possibility to customize device
zelaktv is offline   Reply With Quote
Old 10-25-2018, 06:24 PM   #43
zelaktv
My Ride: bmw e46
Model: 320ci
Sponsored Links
Advertisement
Old 10-25-2018, 06:46 PM   #44
armenh7
My Ride: 2002 325i
Bravo. Very nice
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 10-25-2018, 11:29 PM   #45
Sykriss
My Ride: '00 328i
Year: 2000
Model: 328i
Transmission: S5D 320Z
Would it be possible to have one of these made to fit inside the single outer vent (the one closest to the drivers side door) instead?
Sykriss is offline   Reply With Quote
Old 10-26-2018, 11:08 AM   #46
zelaktv
My Ride: bmw e46
Model: 320ci
I will think about to make version for outer vent. It will take lot of work to use another smaller screen, rewrite all graphics and so, also making new frame for outer vent with new small screen isnt easy
Old 10-26-2018, 02:06 PM   #47
Sykriss
My Ride: '00 328i
Year: 2000
Model: 328i
Ah, I was under the assumption that the dimensions didn't differ that much, that it wouldn't be too much of a hassle. It would be much easier for both of us if I just figured out how to get the air from that vent to cool as well as the middle one, lol.
Old 10-26-2018, 04:52 PM   #48
zelaktv
My Ride: bmw e46
Model: 320ci
I need to mention that right side of central vent will work like before lcd installation, ony left side of vent closed from behind (to protect lcd of overheating). And here is absolutely no problem with air circulation with my device installed
Old 10-27-2018, 03:12 AM   #49
donBogi
My Ride: 325i
Ahh I didn’t get those fancy car pictures in the lcd info screen. But I think number one of all “series” devices looks the best
At this point I should mention the good display brightness at night. You can dim it almost so dark that you won’t see a thing during daylight. Android head units are so much brighter at night!
Also the brightness during daylight is unbelievable good, you can see everything even during sunshine. Also something an android HU cannot.
Gesendet von iPhone mit Tapatalk
donBogi is offline   Reply With Quote
Old 11-20-2018, 02:35 PM   #50
zelaktv
My Ride: bmw e46
Model: 320ci
Hello, guys! Little inside of development for e9X and e60 n52/n54
Old 11-23-2018, 04:46 AM   #51
leonardo_
My Ride: 323CI Cabrio
Once again,perfect device!!!
leonardo_ is offline   Reply With Quote
Old 01-20-2019, 07:16 PM   #52
d_cleverzz
My Ride: Manual 2001 330ci
Year: 2001
Model: 330CI
Transmission: 5 Speed Manual
So besides it displaying information from the DME. We can directly connect wideband O2 sensors, EGT sensors, boost, etc, DIRECTLY to your device so we can monitor those as well, correct?
IN SEARCH OF
CONVERTIBLE INTERIOR CARBON FIBER OR PIANO BLACK TRIM
ORIENT BLUE M3 VERT FRONT BUMPER
ORIENT BLUE VERT PRE-FACELIFT FRONT FENDERS
d_cleverzz is offline   Reply With Quote
Old 01-21-2019, 04:43 AM   #53
donBogi
My Ride: 325i
No direct connection of wideband sensors. You would have to use the auxiliary output(and maybe setupt) of the wideband controller.
But oil pressure and temperature sensors can be connected directly
Old 01-21-2019, 09:14 AM   #54
VitalyZHP
Ukrainian
My Ride: 04 330CI
Love my device. More people should be running this
VitalyZHP is offline   Reply With Quote
Old 01-21-2019, 01:43 PM   #55
d_cleverzz
Year: 2001
Model: 330CI
A little lost on setting up the AFR sensor. How is it done? Want to clarify before I make a purchase lol.
IN SEARCH OF
Old 01-21-2019, 02:13 PM   #56
VitalyZHP
Ukrainian
My Ride: 04 330CI
You set up the sensor per sensor's instructions, then 5v out from the sensor goes to the device's brain
Old 01-21-2019, 02:17 PM   #57
donBogi
My Ride: 325i
The device just grabs the voltage value delivered by the wideband sensor controller.
For example the innovate mtx-l has an configurable output which can be set from 1 to 5 volt or so, depending by the afr value.
So the display unit has two cables which have to be connected to the two from the innovate mtx-l (as example, since I use a mtx-l).
Old 01-21-2019, 02:32 PM   #58
d_cleverzz
Year: 2001
Model: 330CI
So if I understand correctly. You’ll still need to purchase a separate AFR gauge witch then this unit will piggy back off of and display the value? Everything else, this unit will act alone on. Correct?
IN SEARCH OF
Old 01-21-2019, 02:44 PM   #59
VitalyZHP
Ukrainian
My Ride: 04 330CI
It depends on what wideband you go with. You can buy Innovate LC2 sensor and controller without the gauge and use this as the gauge. I went with AEM UEGO which comes with the gauge, so I just hid it in the glovebox
Old 01-21-2019, 11:45 PM   #60
donBogi
My Ride: 325i
Sorry Vitaly, you were quicker
