E53 M62b44TU swap to E46, help(EWS-DME issu) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 04-06-2018, 01:47 PM   #1
Nino11
My Ride: BMW E46 330ci
Hello guys,
Recently have swaped an M62b44TU engine from a E53 X5 year 2001, to 320CI E46 year 2001. We have installed engine Wirings to the car also ews and keys of the engine. Now the car crank but does not start, we find out that there is no fuel pressure and sparks. We have checked fuses relays fuel pumps, every thing is OK. When diagnosing with autocom its tells: 148 EWS 3.3 DME-EWS. We have tried to synchronize the DME and EWS but it says: Syncro not Possible. we have tried reprog a second EWS and still not working. ad now we have being thinking about deleting the ews3.3. Guys we are really stuck, what are your suggestions ? and we would be very thankful for any of your help!
Nino11 is offline   Reply With Quote
Old 04-06-2018, 02:06 PM   #2
Nino11
Forgot to say that the donor car (E53) has an auto tranny and E46 has a manual one.
Old 04-06-2018, 05:02 PM   #3
armenh7
My Ride: 2002 325i
I don't think an EWS delete for that DME exists. You either have to buy a DME that comes in a kit on eBay (has EWS, DME, locks, and keys). Each DME is hardcoded to one EWS so trying to sync it with another EWS will not work
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-07-2018, 08:24 AM   #4
Nino11
Armeh7,
I did swap DME, ews, key from the donor car. And the donor car was running perfectly. Now I don't have no check engine light in the cluster. I doubled checked the wires. Do i have to swap ignition cylinder too?
Old 04-07-2018, 10:38 AM   #5
armenh7
My Ride: 2002 325i
Originally Posted by Nino11 View Post
Armeh7,
Well if the ignition cylinder isn't swapped, I don't see how the donor key is going to turn it
Old 04-07-2018, 10:41 AM   #6
HayWagon
My Ride: 03 325iT
Or how it is checking the transponder in the key.
Sent from my tractor.
HayWagon is online now   Reply With Quote
Old 04-07-2018, 12:08 PM   #7
Nino11
I have put the donor key in the transponder ring, and it's reading it. I can see it with diagnostic.
Old 04-07-2018, 12:51 PM   #8
armenh7
My Ride: 2002 325i
The DME is a ME7.2. EWS delete exists but it isn't free.
https://www.google.com/search?q=me7....obile&ie=UTF-8
Old 04-07-2018, 01:27 PM   #9
Nino11
Yes I know it's not cheap, but do I have a choice? I just wanna make sure it's not something else, before doing anything costy!
Old 04-07-2018, 03:12 PM   #10
armenh7
My Ride: 2002 325i
I don't have much experience with that DME to be able to say
Old 04-08-2018, 07:26 AM   #11
Nino11
Thanks anyway.
Old 12-14-2018, 09:52 AM   #12
cwarel
My Ride: 330ci coupe
I think for the car to start , ews needs to know that the car is in neutral thats why there is no fuel or spark
cwarel is offline   Reply With Quote
Old 12-26-2018, 12:57 PM   #13
MAXixt
My Ride: e46 335ci
You must code ecu and ews as e39 540i manual or cheap and fast way is to connect on ews plate two pins togeather wich goes to starter.
MAXixt is offline   Reply With Quote
Old 12-26-2018, 01:00 PM   #14
MAXixt
My Ride: e46 335ci
In m62tu it desnt matter,you can turn on ignition and mechanicly turn on starter with wire to +12v ,car will start.
