Cylinder Head question, M54B30 swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 12-17-2018, 08:27 PM   #1
Laecaon
My Ride: 02 325iT, 71 510
Hi guys!
I have a very tired M54B25 in my car, running fine (mostly).
Got myself a 3.0 complete swap a few months ago. Plan was to install it later this month. I'm in the middle of rebuilding it and discovered the head is warped (bowed). The block threads are still good and the surface is straight.
I know the 3.0 cams are bigger so I will be wanting to keep those.
My new plan is to use the head off of my 2.5 that is in good shape, and swap the cams over.
My question is, how should I swap the cams? Just swap cams? or swap cams and the cam troughs (I don't know correct term)?
Is there anything I am giving up by using the 2.5 head? Valve size? Port size?
Can't wait to have a 3.0 Touring.
Thanks,
Jacob
Laecaon is offline   Reply With Quote
Old 12-18-2018, 08:21 PM   #2
Laecaon
Well, I have figured out I need to swap the valve springs. Probably just going to swap cams and springs only, unless someone can tell me otherwise. My current lifters are fine.
Old 12-22-2018, 09:04 AM   #3
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Just curious, why are you rebuilding the B30? Does it need it?
Are you going to time-sert the head bolt holes in the block?
BaliDawg is online now   Reply With Quote
Sponsored Links
Advertisement
Old 01-03-2019, 01:19 AM   #4
Laecaon
I never put mystery motors into cars. Rings and bearings are efforless to do when it's on a stand. And then all new gaskets, cleaning out the oil and coolant passages...
I bought the motor already torn apart.
Block was fine. Some thing scuffed main bearing 6. But the crank was good.
I did end up swapping the 3.0 cams and springs over.
Head install is in a holding pattern. Pulled a thread in the block. All the bolts did the 40NM fine, and the first 90 degree turn. It was the second 90 that killed the first bolt.
So now it's getting time serts. I am a CNC Machinist, have all the tools to do it, just not the inserts yet.
Old 01-03-2019, 03:47 AM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
All sounds good. Much respect. Growing up my Dad was a machinist; our garage had a milling machine, lathe, arc welder, oxy-acetelene welder, band saw, surface plate, gauge blocks, endless tools, you name it. Could barely park a bicycle in there!
Hey, one thing Iíve seen others do in previous rebuilds is to use head studs instead of bolts to avoid the potential thread pull in final torque down. Is that something youíre considering?
Old 01-20-2019, 03:32 AM   #6
Laecaon
I think I should probably update this.
I just used head bolts, a stock motor really shouldn't need studs... I was successful at putting the timeserts in. If I was doing it again, I would have gotten 30mm long ones instead of the 24mm ones someone was selling on amazon.
I got the motor fired up, it has about 200 miles on it now, even got it past emissions testing. Still running the 2.5 tune (which was updated in 07 according to my PA Soft log). Engine runs real smooth, except sometimes at WOT it hesitates. Plan is to flash the 3.0 tune tomorrow.
So, I guess the answer to my original question is, springs and cams. Though I am not 100% sure on the springs thing, just going off what others claim. the 2.5 and 3.0 heads had the same number of coils on the springs, and the thickness of the coils were the same, which should mean the same spring rate and same compression height.
I had headers on my 2.5 since it had clogged the cats, the 3.0 with the 2.5 tune and cats feels like it has a decent amount more torque, but not so much high end.
Old 01-20-2019, 06:05 AM   #7
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Let me know if you need help updating the DME to the B30 software. See link below for details.
Old 01-20-2019, 03:58 PM   #8
Laecaon
Well I got the EGS module to update. Did that to make sure I could read/follow the guide/make sure everything was working well.
But now my INPA seemed to have hosed itself... sigh. Ill get it back to working.
Old 03-30-2019, 02:06 AM   #9
Shawk
I just finished swapping a 04 Zhp everything into my 02 325iT. Having just a few issues and wondering if the Zhp lcm could possibly be the problem. Dim tail lights, cooling fan not turning on. Warning lights for brakes, yellow brake light
Shawk is offline   Reply With Quote
Old 03-30-2019, 03:21 AM   #10
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Originally Posted by Shawk View Post
I just finished swapping a 04 Zhp everything into my 02 325iT. Having just a few issues and wondering if the Zhp lcm could possibly be the problem. Dim tail lights, cooling fan not turning on. Warning lights for brakes, yellow brake light.
What all did you swap from the ZHP into the 02 325iT?
I’d expect leaving everything original in the 02 325iT except the swapped B30 engine would be the easiest route. The MS43 DME could be programmed with B30 software and it would run just fine.
