Ms45.1 tuning - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-24-2019, 10:39 PM   #1
Machewjr
Ms45.1 tuning
Has anyone on here used Renovelo byte tune for the ms45.1 recently added compatibility to tune the DME through the obdII and Iím looking for opinions
Machewjr is offline   Reply With Quote
Old 01-28-2019, 12:07 PM   #2
mjdarg
My Ride: 2003 330i ZHP
Transmission: Manual
I purchased ByteTuner a few months ago and have been using it since. Have succesfully coded out the secondary air pump and secondary cats with catless header. I've also been playing with the VANOS tables a bit but haven't finished optimizing for the ZHP cams.
I didn't really know what it was going to be like so it was a bit overwhelming at first. You have access to all of the parameters in the factory DME that BMW was using for development and production. There are single digits, up to large tables. They have short descriptions for each parameter to help you understand what it is doing. Even though parameter names are different for MS43 and MS45, the large tuning thread has been a great help to me.
Instead of having to ship out my DME to get an EU tune for the headers and SAP delete, I figured I would spend a bit more money and have way more capability in the future.
Also, customer service has been great so far. Jeff is very receptive to emails when I have run into issues with flashing (user error) or for general help. If you have specific questions, you could contact him directly and I'm sure he would get back to you quickly.
mjdarg is offline   Reply With Quote
Old 01-28-2019, 12:17 PM   #3
Machewjr
Do you have any screenshots of the software Iím trying to get an idea of what it looks like
Sponsored Links
Advertisement
Old 01-28-2019, 02:22 PM   #4
TerraPhantm
My Ride: M3 & ZHP
Personally I wrote my own application to read/write to the MS45.1. I will probably release that open source in the near future.
Old 01-28-2019, 06:28 PM   #5
DOT.
My Ride: '04 ZHP Sedan
DOT. is offline   Reply With Quote
Old 01-28-2019, 11:33 PM   #6
604Beamski
My Ride: 2005 325i
All I want is launch control and the ability to code out o2s for catless headers
604Beamski is offline   Reply With Quote
Old 01-29-2019, 11:16 AM   #7
hassmaschine
My Ride: '91 325ix
IIRC I'm not sure how launch control is possible on MS45.1. It probably is - just not the same way you do it with MS43, we already tried it and it doesn't work.
deleting DTCs is easy. I can post a guide when the flash app is out.
hassmaschine is offline   Reply With Quote
Old 01-29-2019, 12:59 PM   #8
TerraPhantm
My Ride: M3 & ZHP
Well if/when I do release anything, you guys will have to figure out mapping (or better yet, let hassmaschine do it for you via bimmerlabs).
I'm also debating whether or not I should leave program writes in. That can definitely render the DME unbootable if you're not careful.
As far as launch control... do you have any idea how the SMG does it? If most of that is DME side, I wonder if we can invoke that somehow.
Old 01-29-2019, 02:08 PM   #9
sda2
My Ride: BMW E46 330i Touring
Hi Terra, regarding SMG launchcontrol, Im maybe able to supply you something that may help you. How can I contact you?
..:: Visit MS4X.net - the ultimate Siemens MS wiki ::..
sda2 is offline   Reply With Quote
Old 01-29-2019, 09:49 PM   #10
mjdarg
Here are two screenshots of bytetuner. For the price, it is a very nice package that can read, write, and change parameters. Once the bin file is fully downloaded (~40 mins for MS45.1) flashing an updated file takes about 45 seconds.
Old 01-30-2019, 12:40 PM   #11
hassmaschine
My Ride: '91 325ix
40 minutes.. why bother. Just download the stock tune off the internet.
I've been busy and haven't responded to Terra's emails yet.. but I will.
Old 01-30-2019, 01:11 PM   #12
mjdarg
Bytetuner uses a specific file type .dme2. There is a library of stock tunes in this file type, but if you have a modified flash file, you have to pull it from the dme with Bytetuner to create this file.
Old 01-30-2019, 03:28 PM   #13
TerraPhantm
My Ride: M3 & ZHP
I can do a full read in under 15 minutes
Not super necessary since stock files are readily available, but still beats 40 minutes.
Old 01-31-2019, 12:04 AM   #14
604Beamski
My Ride: 2005 325i
Hmm. Is there a reason why MS45.1 isn't able to and MS43 is? I'm assuming I'd have to install an aftermarket WOT box then? I guess I won't bother because I don't NEED it
Old 01-31-2019, 08:47 AM   #15
hassmaschine
My Ride: '91 325ix
No, the code is just different so the parameters work in different ways. If you use the same settings from MS43 for launch control it won't work. There may be another way to do it, and probably is, but I don't know it. I don't own an E46 either so it's not like I can test it (although it might be similar to MSV70).
Old 01-31-2019, 08:48 AM   #16
hassmaschine
My Ride: '91 325ix
Probably encrypted so you have to use their software.
Old 01-31-2019, 09:30 AM   #17
mjdarg
Yeah, no doubt. I didn't mind paying $250 for a package that works well and is currently the only solution that can do what it does.
Old 02-02-2019, 03:13 AM   #18
Blu302
My Ride: '98 E46 323i
Hassmaschine,
How is the reader coming along? Will it do MS45.0?
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 02-02-2019, 04:31 AM   #19
daniel_f.
My Ride: 330iC
MS43 is driver wish based throttle control whereas MS45 is torque based throttle control. If you write anykind of launch control sequence into the dme, the torque controller will simply override you setpoints.
Current licensing status:
Security implementation *done*
Implementing Flex Fuel
Siemens MS43 wiki!
Old 02-02-2019, 07:34 AM   #20
hassmaschine
My Ride: '91 325ix
Originally Posted by Blu302 View Post
Hassmaschine,
yeah, it should work with any version of MS45.
