Ms45.1 tuning - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-10-2019, 12:06 AM   #21
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
The reader is awesome by the way.
I have just loaded my first tune using BimmerEditor.
I can tell that the MS45.0 (X3)uses torque mapping because after the first run, low gears felt no different but the higher gears pulled more than before.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 03-08-2019, 01:35 PM   #22
TerraPhantm
My Ride: M3
Something I've been working on:
Might want to mess with the RPM thresholds a bit. And looking at the video, I think I need to add a little bit of code to switch to the oil temp routine if the clutch is depressed. Might also implement RPM thresholds per gear.
Old 03-08-2019, 06:18 PM   #23
604Beamski
My Ride: 2005 325i
Wow that is awesome Terra! Good work
LF: Koni yellow rear shocks (non-sport FL sedan), gloss black kidney grills
604Beamski is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-25-2019, 03:44 PM   #24
Floszek_P
I just tried the MS45 Flash Tool. Is there any instructions on disable DTE / Sap ?
Floszek_P is offline   Reply With Quote
Old 04-28-2019, 06:52 AM   #25
rkneeshaw
My Ride: 330i ZHP
For those of you using ByteTuner to tune your MS45.1 cars, or if you have all the maps and are using terra's flash tool, be sure to check out the MS45 section on ms4x.net. I added a bunch of content there for disabling O2 sensors and disabling SAP and a few other odds and ends, feel free to contribute!
Direct link: https://www.ms4x.net/index.php?title=Siemens_MS45
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread: https://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i ZHP
rkneeshaw is offline   Reply With Quote
Old 04-30-2019, 10:44 AM   #26
Cordtus
My Ride: E46 325i
Originally Posted by hassmaschine View Post
IIRC I'm not sure how launch control is possible on MS45.1. It probably is - just not the same way you do it with MS43, we already tried it and it doesn't work.
deleting DTCs is easy. I can post a guide when the flash app is out.
Oh god yes how can I be notified of this?
Cordtus is offline   Reply With Quote
Old 05-13-2019, 02:32 PM   #27
simba15
My Ride: E46 B30
Year: 2004
I would also love a guide for this new App.
Let us know when its available!
simba15 is offline   Reply With Quote
Old 06-14-2019, 04:41 AM   #28
Blu302
Year: 98
Model: E46
I am looking for the fuel maps on 7561512, MS45.0.
My problem is that with my vanos tuning, the fuel trims vary wildly across the rpm/load range and when I hit full throttle it goes lean from fuel trims.
Old 06-14-2019, 08:43 AM   #29
cwarel
My Ride: 330ci coupe
You got no o2? They should compensate no? I know on MS43 when I had it NA , I did vanos , timing and added 3% of fuel to the maps and the rest adaptations did for me , more I drove the car in racing kinda of manner the better it got. I had a wideband and I could tell it was getting better.
cwarel is offline   Reply With Quote
Old 06-14-2019, 07:50 PM   #30
Blu302
Year: 98
Model: E46
I am running narrowband O2 same as MS43/42. The MS45 runs the learned trims at full load. My vanos maps are making the engine 13% rich at part load which are trimmed to 0%(-13% trims). 13% lean at full load is bad and there is no learning when in full load.
Old 06-15-2019, 02:18 AM   #31
Blu302
Year: 98
Model: E46
Terra,
Does the MS45 use the same DS2 commands as MS42/43? I.E 12050B03 for most engine operating parameters.
I am having problems getting logging to work with my X3(MS45.0) when the programs all work with my MS42 DME.
Testo and INPA etc work but nothing else. i.e. Bimmerlogger, tuner Pro, Romraider all fail with the X3
Old 06-15-2019, 11:21 PM   #32
TerraPhantm
My Ride: M3
Terra,
It does not. It uses the KWP2000 protocol.
Old 08-05-2019, 07:32 PM   #33
Blu302
Year: 98
Model: E46
I don't care about the hardware layer protocol, I am looking for the software commands.
Old 08-08-2019, 11:23 PM   #34
nextelbuddy
My Ride: e46 ZHP
Year: 2003
Model: 330i ZHP
Transmission: 6MT
Sweet! Any plans to tell us what was changed? Now that we have your flasher program which by the way works awesome.. this would be really awesome to try to implement.
2003 e46 ZHP M3 Sedan | S54 6 Speed
2002 e46 ZHP Touring | M54 6 Speed
nextelbuddy is offline   Reply With Quote
