Can't get spring onto strut - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 03-21-2019, 02:43 AM   #1
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
Transmission: 6-Speed Manual
After moving on to the front struts installing my new h&r sport cup kit I'm at a complete loss. The strut rods are completely recessed into the struts and only stick out about 4". There's no way I can get an even fully compressed spring on there. I also can't get the stock one's back on because the rods are the same length. If I pull the rods they come out a little and then just reset to their neutral position again. Any ideas?
Sent from my Moto Z (2) using E46Fanatics mobile app
BarelyMovingWreck is offline   Reply With Quote
Old 03-21-2019, 02:54 AM   #2
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
I don't even understand, every video on YouTube show struts with at least 8" of rod sticking out.
Old 03-21-2019, 03:01 AM   #3
RayPooley
My Ride: 320i SE Coupe
A picture is worth a thousand words. Take a few and post them so folks can see what your problem is.
Sponsored Links
Advertisement
Old 03-21-2019, 03:20 AM   #4
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
Here is the shaft.Click image for larger version
Old 03-21-2019, 03:23 AM   #5
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
That one picture is all I grabbed before I left, I'm back home now.
Old 03-21-2019, 03:47 AM   #6
RayPooley
Here is the shaft.Attachment 770687
Can you not just attach a nut to the end of the shaft and pull it out? They are pretty hard to move. Very stiff. Maybe attach the pushrod end to some immovable object, stick a screw driver through the bush end and give it all you got. It should move.
Old 03-21-2019, 03:57 AM   #7
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
Yeah, I tried the nut thing, but could only pull about 1/2" and it went right back. Seems like however I move it it's gonna go right back to that neutral position.
Old 03-21-2019, 05:46 AM   #8
M3stang
My Ride: A bunch of cars
Are these shocks new? It sounds like/looks like they are just blown. I remember when I removed blown shocks from various cars, the rods were just chilling. As soon as you break the strap that secured the rods down on new ones for shipping the shoot up. They arenít going down without some weight on them. You should never even have to pull them up. That would be very blown and negate the point of the springs imho.
2016 328i Auto Mediterranean blue on brown
2001 Z3 M Coupe S54 Phoenix Yellow/Black
2001 M3 Titanium Silver/Gray
2001 E46 330Ci Sport Package Manual Schwarz/Black
1997 M3 Coupe Dakar Yellow/Gray Hurricane
1989 M3 Zinnobarrot/gray
M3stang is offline   Reply With Quote
Old 03-21-2019, 06:13 AM   #9
cp2708
My Ride: 325ci Convertible
Model: Sport
Transmission: Auto
When I changed my old ones out they sat in the ride position and kept going back there, the new ones naturally crept up to the top under the gas pressure. I'd agree with M3stang and say they're shot.
cp2708 is offline   Reply With Quote
Old 03-21-2019, 06:25 AM   #10
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
I can't really believe that they're both just shot, they're brand new dampers in the box. Has anyone had an h&r sport cup kit do this?
Old 03-21-2019, 06:27 AM   #11
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
If anything I would figure that being so hard to extend they're not blown, you would think they'd be easy to dampen / extend.
Old 03-21-2019, 06:33 AM   #12
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
Even the picture of the kit shows the short rods, so I'm really having doubts about them being shot.Click image for larger version
Old 03-21-2019, 06:40 AM   #13
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
And here is another picture of the kit, there has to be a way to extend them.Click image for larger version
Old 03-21-2019, 06:45 AM   #14
cp2708
Model: Sport
Transmission: Auto
Fair point. I don't know then, all the gas struts I've ever fitted have driven themselves to full extension and usually have a steel wire holding them compressed so they take up less room in the packaging. Maybe ask HR or the supplier if you've bought them new?
Old 03-21-2019, 07:30 AM   #15
Ettinger
My Ride: 4 doors, 3 pedals
OP, show us a fully compressed spring next to the strut please
Ettinger is offline   Reply With Quote
Old 03-21-2019, 07:31 AM   #16
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
I can't get any pictures now but will later after work. I think I'm gonna try and rent another set of compressors to see it they help and if that fails, bring then to a shop and have them mount them.
Old 03-21-2019, 07:44 AM   #17
Ettinger
Sounds like a plan. In any event, keep the top of the strut facing away from you & on the ground until the mount is secure!
Old 03-21-2019, 07:54 AM   #18
RayPooley
Can you not get some advice from the manufacturer? Tell them your problem. Maybe you just need more force than you can muster. They should be able to advise.
Old 03-21-2019, 05:38 PM   #19
BarelyMovingWreck
My Ride: 2004 330ci
Year: 2004
Model: 330Ci
Here's the fully compressed spring next to the strut.Click image for larger version
Old 03-21-2019, 07:47 PM   #20
DEADF15H
My Ride: 2001 325i Auto
Model: 325i
Transmission: Auto
Just an FYI, I tried two different types of spring compressors to try and get them tight enough to install the spring. One was the same as your using.
Ended up taking them to a shop and paid $60. They used a wall mounted compressor, and had to get the owner to show them how to do it. Then I put them on the car.
They were Eibach Pro Kit springs and Sach struts.
That doesn't address your piston issues, but it's something to think about. I would call HR and get their input.
Sent from my SAMSUNG-SM-N910A using Tapatalk
DEADF15H is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
E46 Strut Spring Compressor db6906 Suspension & Braking Forum by BimmerWorld 47 05-22-2016 06:49 AM
WTB: Any Strut bar to fit a 2002 e46 M3 Located in NY local pickup preferred ! RydinRuff Suspension and Braking 8 01-03-2009 11:16 AM
FS: NEW OEM Strut Mounts (2) peanut_man Suspension and Braking 3 12-12-2008 06:34 PM
Help removing strut with Meyle CA installed. peanut_man General E46 Forum 3 12-08-2008 10:26 PM
M3 strut bar question tokayd General E46 Forum 4 10-28-2008 12:28 PM
