Semi loaded caliper. Is this the piston directly pressing on the pad? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 03-26-2019, 10:28 PM   #1
fanatichuman
My Ride: 2001 e46 330xi
Hi all,
I have to confess (again) I'm a total brake noob. I got the semi loaded calipers for my brake job on the WE.
Is this caliper (see pic) ready? Is the round thing sticking out a bit the piston that comes out? It's hollow. That means the brake fluid is only in a smaller space behind that hollow piston, and the whole thing is sealed by the black seal that's around? And that piston/round opening is pressing against the pad?
Trying to figure out if I'm missing sth. Thanks.
Cheers,
FanaClick image for larger version
ID:	771075Click image for larger version
Sent from my MI 5 using E46Fanatics mobile app
fanatichuman is offline   Reply With Quote
Old 03-26-2019, 10:41 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Looks good to go. You should have some brake pad hardware/clips that often have a sheet metal spring loaded part that may go inside the piston. Cannot recall what hardware, if any, is required for the rear pad. The hardware is to keep the pads from rattling around and help stabilize the brake pads.
The pistons are cup shaped, so they almost all are hollow in the center where they contact the inner brake pad.
Solve your misfires, lean codes, rough idle - https://forum.e46fanatics.com/showthread.php?t=897616
Fuel pump failures - https://forum.e46fanatics.com/showthread.php?t=929501
Temp Info - https://forum.e46fanatics.com/showthread.php?t=964491
Hidden OBC Menu - Check Voltage, Temp, Fuel Level - https://forum.e46fanatics.com/showthread.php?t=239619
Old 03-26-2019, 11:07 PM   #3
fanatichuman
Thanks! The clip you mean can be seen in the lower part of the first pic, correct? That's the only part that came with the caliper.
Say, after I bled the breaks, what else do I have to do? (With new pads). Break in the pads? I think the akebonos say it's not needed. Any thing else before I can DD?
Cheers
Sponsored Links
Advertisement
Old 03-26-2019, 11:28 PM   #4
jfoj
The clip in the first pic is for the outer pad. I cannot recall if the inner pad has a clip, some do, some don't.
Suggest you see what is on the car, search RealOEM.com and ECSTuning.
If you allow the master cylinder to go dry, often you may need to bleed the master cylinder, which can be done while on the car. Often ever after bleeding the brakes. I had a situation like this lately where there was till air in the master cylinder between the 2 pistons after bleeding the entire system. Pedal had too long of a stroke. Just had someone pump up the pedal, hold and crack the brake lines at the master cylinder and removed the last part of the air and the pedal travel was reduced and where expected.
Good luck, if you get it all right, your brakes should be in good shape and have a good feel.
Make sure you do not leave any bolts loose, torque the wheel lugs.
Old 03-27-2019, 12:04 AM   #5
fanatichuman
1) No brackets on inner pads
2) I'm using a motive auto bleeder, so not anticipating to run the reservoir low. Why would I dry out the master cylinder?
Thanks!
Old 03-27-2019, 06:19 PM   #6
jmo69
My Ride: 03 325xi 98 328is
Thanks!
If you don't have enough fluid in the pressure bleeder you could conceivably empty the bleeder and start pumping air into the master. I did brakes on two cars this summer and both had clips on the inner pads that fit into the piston. My xi and an old Chrysler, front and rear.
Sent from my SM-G950U using E46Fanatics mobile app
Alternative to expensive xi control arm bushings https://forum.e46fanatics.com/showthread.php?t=1231503
Bad outer xi ball joint? https://forum.e46fanatics.com/showthread.php?t=1127077
2003 325xi auto Stahlgrau
1998328is 5sp
jmo69 is offline   Reply With Quote
Old 03-27-2019, 06:44 PM   #7
jfoj
Thanks!
Some pads have inner pad clips riveted to the pad backing, some pads have snap on clips.
See the pictures of these Hawk brake pads - https://www.ecstuning.com/b-hawk-par.../hb227f.630kt/
If you are replacing the calipers, depending on how long you have them disconnected, you could possibly allow the master cylinder to drain.
In find with pressure bleeders, it is better to just fill the master cylinder and allow the bleeder to provide compressed air.
You still may need to perform the old school 2 man pedal pump and bleed to get the proper pedal feel.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas Piston vs Direct Impingement AR-15 system Skeeter Gun Talk 9 12-18-2009 05:02 PM
Piston in the caliper Sammko18 General E46 Forum 9 05-29-2009 09:59 PM
***(Socal General Chat)*** patdeezy California 137992 02-19-2009 10:07 AM
Brake Pad Diy Question ManUtd8 DIY: Do It Yourself 7 10-31-2008 02:05 AM
Replacing a Brake Caliper Dust Seal PSU-LION-VA DIY: Do It Yourself 1 10-29-2008 08:24 PM
