rear spring and struts - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 04-03-2019, 08:17 PM   #1
magster
My Ride: '02 330cic
so i could use some help on this. i have an '02 330cic with 18" wheels from a 335. when i bought the car it became apparent that PO put in lower rear springs. i've got 4 3/8 clearance in the front and only 2 7/8 in the rear. it's starting to bounce and rub new tires and just feels sloppy. i put biltstein touring shocks all the way around about 50k mi ago. i've decided to go back to "stock" rear suspension. i think i'm sold on sachs rear struts but would like to save some money on the springs. anyone have any recommendations on aftermarket springs that are like stock, but more economical? or, really any advice is appreciated...
magster is offline   Reply With Quote
Old 04-03-2019, 08:22 PM   #2
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
Lesjofors
Archbid is offline   Reply With Quote
Old 04-03-2019, 08:42 PM   #3
thyde
My Ride: 2000 328i, 1994 YJ
I recently replaced my rear springs due to a broken spring, and just used Bilsteins. I believe they were "heavy duty" but I may be mistaken. They are stock height and I don't remember them being expensive enough to remember how much they cost. Car is great.
thyde is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-04-2019, 03:14 AM   #4
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Originally Posted by magster View Post
so i could use some help on this. i have an '02 330cic with 19" wheels from a 335. when i bought the car it became apparent that PO put in lower rear springs. i've got 4 3/8 clearance in the front and only 2 7/8 in the rear. it's starting to bounce and rub new tires and just feels sloppy. i put biltstein touring shocks all the way around about 50k mi ago. i've decided to go back to "stock" rear suspension. i think i'm sold on sachs rear struts but would like to save some money on the springs. anyone have any recommendations on aftermarket springs that are like stock, but more economical? or, really any advice is appreciated...
The Bilstein Tourings are for stock spring height, so using them with lowering springs may well have worn them out.
If you want to go back to stock height, I would buy some used stock springs and new Bilstein Tourings. They’re cheaper than the Sachs.
Old 04-04-2019, 07:32 AM   #5
markusmarkus
My Ride: 2018 M240i
Can’t the Bilsteins be rebuilt?
Old 04-04-2019, 01:32 PM   #6
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
I suppose.
https://www.bilstein.com/us/en/techn...ledge/service/
But the B4 Touring shocks are only $126 per pair.
https://www.ecstuning.com/b-bilstein...ir/bne-a315kt/
Old 04-04-2019, 04:56 PM   #7
magster
My Ride: '02 330cic
i didn't think about used springs. if i can source them at the bone yard do you know offhand if there's any difference for a convertible. i just know it's the sport suspension.
my shocks aren't leaking but could they be thrashed anyway because of pairing them with lower springs? my bump stops are thrashed so maybe just replace shocks, bumps and mounts?
the back end feels very unplanted. maybe a broken spring? thinking to put new spring pads too, since i'm in there. i haven't looked at trailing arm bushings yet.
Old 04-04-2019, 05:10 PM   #8
Archbid
Year: 03
Definitely used springs unless there is corrosion. Match the stripes painted on the spring.
Old 04-04-2019, 05:52 PM   #9
magster
My Ride: '02 330cic
you lost me on the stripes. since i don't have stock springs i can't compare. looks like i'll need convertible springs for the right ride height. or these: BMW Heavy Duty Coil Spring Rear - Suplex 06164 ($70). anyone know about Suplex?
Old 04-04-2019, 06:14 PM   #10
Archbid
Year: 03
https://forum.e46fanatics.com/showthread.php?t=397880
Old 04-04-2019, 08:44 PM   #11
magster
My Ride: '02 330cic
this looks like what i need for $178:
https://www.fcpeuro.com/products/bmw...rear-556882kt2
i'll chk the springs and if they're broken or non-stock get used ones off a convertible here. if they are oem and good i think at least new spring pads and maybe even the thicker spring pads. just seems like something's off with my ride height even with the bigger wheels. i just needed a second set of eyes on this and some consult...
Old 04-05-2019, 02:56 PM   #12
bmwbob89
My Ride: M-5 325 X3 528 740
If you need springs look at the Bilstein ones. Great price and 2 year warranty.
Actually after looking at FCP Euro I would get them there just for the lifetime warranty. They really don't last long on these cars. My XI is on at least its 3rd set and needs them again. My X3's need replace again and they are only 3 or 4 years old and I bought them at the dealer because it has the sports package. So sad!
bmwbob89 is offline   Reply With Quote
Old 04-05-2019, 04:59 PM   #13
Archbid
Year: 03
I have a 330 vert and I also got a 15mm spring pad for the right spring to address irritating tilt of the chassis
Part number 33531094754
Similar Threads
Thread Thread Starter Forum Replies Last Post
E46 M3 stock suspension rear end front suspension and brakes + more Gorzun Suspension and Braking 10 11-05-2009 09:22 AM
Struts, Shocks.. Springs??? heyzeus200 General E46 Forum 8 05-02-2009 01:33 PM
FS: Stock '05 ZHP Coupe Springs + Struts (30k on them) ///mshu Suspension and Braking 31 04-08-2009 08:25 AM
Right rear problem due to towing Wessy Suspension & Braking Forum by BimmerWorld 2 03-06-2009 05:31 PM
SACHS Sets of Struts and Shocks plus rear Coil Spring - $400 reynaldo Suspension and Braking 8 02-14-2009 01:13 PM
