Whats needed to swap from B25 to B30 intake? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-12-2019, 02:14 PM   #1
zfiles1701
My Ride: 2002 325it wagon
Year: 2002
Model: 325it sport wagon
Transmission: ZF 5hp
What do I need besides the DISA valve (just bought a B30 DISA) to swap my B25 intake manifold to a B30 intake manifold?
zfiles1701 is offline   Reply With Quote
Old 04-13-2019, 12:58 AM   #2
armenh7
My Ride: 2002 325i
The throttle body is bigger which also means you need bigger intake boots and corresponding maf
armenh7 is offline   Reply With Quote
Old 04-13-2019, 01:18 AM   #3
donBogi
My Ride: 325i
You can use the b30 lower hose and the b30 upper plastic connector to upper hose. You can fit the b25 hose easily on that connector piece and keep the maf
So throttle body, lower hose and the plastic connector to the upper hose
Gesendet von iPhone mit Tapatalk
donBogi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-13-2019, 02:20 AM   #4
Aussigazza
My Ride: E46 330i and M3
Year: 1999
Model: Now 330i
Transmission: 6 Speed M3
Intake temp sensor.
Garry
Aussigazza is offline   Reply With Quote
Old 04-13-2019, 08:56 AM   #5
armenh7
My Ride: 2002 325i
I mentioned the maf since a bigger maf reads more airflow
Old 04-14-2019, 09:25 PM   #6
zfiles1701
Year: 2002
Really appreciate the input. Got the throttle body with gasket, lower hose and the plastic connector to the upper hose on the way.
Looking into intake air temp sensor but it looks like B25 B28 and B30 take the same sensor. Part numbers?
Again thanks for input if you thing of anything else like tips or tricks to it please share.
Old 04-15-2019, 03:12 AM   #7
donBogi
My Ride: 325i
I understand! I also put in the bigger maf but from my log readings without another bigger cam it is not really necessary
Old 04-15-2019, 04:03 AM   #8
Aussigazza
Year: 1999
Model: Now 330i
According to Realoem they use the same sensor. Pn 13621739510.
Also make sure the vacuum nipples that go near the firewall are sealed if not used.
Garry
Old 04-15-2019, 08:08 AM   #9
zfiles1701
Year: 2002
Actually, I'm putting in a B30 intake cam. From what you guys are saying, looks like the bigger B30 maf and upper intake boot would make a difference. Is that correct?
And, does that mean I'll need to change my intake air filter box too?
Old 04-15-2019, 08:10 AM   #10
zfiles1701
Year: 2002
And, with the B30 MAF will I need to tune my DME or will stock B25 run ok without a tune?
Old 04-15-2019, 08:18 AM   #11
Aussigazza
Year: 1999
Model: Now 330i
I had a 2.8 intake manifold and ecu on a 3.0 motor. Changed everything to 3.0 and made a world of difference.
Garry
Old 04-15-2019, 04:25 PM   #12
donBogi
My Ride: 325i
It’s mandatory to “tune” your dme, otherwise it’s going to run crazy lean
Old 04-15-2019, 09:19 PM   #13
zfiles1701
Year: 2002
OK is there a tune you'd recommend and would there be a link to this site or somewhere else?
I was thinking of just running the 2.5 maf and not tune at first and put the 3.0 maf in and tune later.
But from what I've read here I'm thinking I better go with the 3.0 maf and tune.
Never tuned before. Thanks
Old 04-17-2019, 03:59 AM   #14
donBogi
My Ride: 325i
Well for the b30 maf you just need to copy the sensor definition from an b30 file to yours.
For the intake manifold I have no maps recommendations. I kinda did mine by myself, but I also put in the b30 cam and b30 maf. Still figuring out the tune to be safe.
Do some reading about MS43 here, install tunerpro, get all the hardware you need and pull your file off the car. Then we can talk about what you could do
Old 04-17-2019, 10:15 AM   #15
zfiles1701
Year: 2002
OK
I'm not doing this job till I get software ready. Doesn't sound easy, but I will give it a try. I was wondering if there was some sort of generic shark tune or something like that that I could just plug and play. Just to avoid having it run lean. Really appreciate the help.
Old 04-17-2019, 10:22 AM   #16
zfiles1701
Year: 2002
On more thing, if I left the 2.5 MAF on, would I have that lean problem? I was thinking of getting the car done and running and then later upgrading to the 3.0 MAF and tune the DME. Thanks
Old 04-17-2019, 11:32 PM   #17
donBogi
My Ride: 325i
Well you will have some little extra air at higher rpms so it will be a little leaner than before but you should be safe I guess
Old 04-20-2019, 08:22 PM   #18
zfiles1701
Year: 2002
Sanity check needed here. I ordered B30 parts and got them. Have the intake, TB, and DISA in my garage.
1 The intake manifold has a tag on it from seller saying 2002 530X (sold as a 3.0). But, this looks just like the on my 2002 325i wagon. I even measured the top dimensions of both manifolds and see no difference.
2 DISA I bought as a 3.0 DISA looks jsut like my spare 2.5 DISA (My spare 2.5 DISA fits 530X manifold too)
3 Throttle body has this part number 1354 7 502 445-05, which I found on web for fitting B30 AND B25
4 New TB gasket part number 13547504729 for a B30 TB measures 79.5 mm outer diameter only
I'll working on getting some photos posted too. Input appreciated.
Old 04-20-2019, 08:25 PM   #19
zfiles1701
Year: 2002
Add to 3. The throttle body actual ID is 70 mm and not 79.5 mm. Wondering if I was sent the right parts. Perplexed.
Old 04-21-2019, 07:21 AM   #20
donBogi
My Ride: 325i
So, there should be a difference in every piece you have there for the conversion. The runners are shorter at the b30 manifold, while the “chamber” in front of them is much wider. The b30 Disa Unit has also a longer flap, so it can close the bigger chamber at the manifold. And the TB... should have an 3 inches diameter or so.
No parts should be compatible with the b25 intake
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Authentic GruppeM Intake Explained DiscoStu General E46 Forum 16 08-12-2016 10:15 AM
Motor Swap 323ci m52 to m54(330ci) 01 raymond3080 General E46 Forum 104 11-09-2012 07:00 PM
330i Gruppe M Intake KrzyBum420 Engine & Performance 6 02-13-2009 08:11 PM
Intake manifold swap Bimmer Dude Xi General E46 Forum 0 12-25-2008 01:40 PM
Auto --> Manual Tranny Swap *Update Autobot325i General E46 Forum 14 11-24-2008 10:05 PM
