Have any of you nerds laid down a coating on your garage floor? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
General Off-Topic
Old 05-15-2019, 06:39 AM   #1
cowmoo32
cowmoo32's Avatar
My Ride: Yukon, E92 M3
I want to do mine but there are a ton of options out there and I know some are easier to apply than others with varying durabilities and looks.
Old 05-15-2019, 06:48 AM   #2
wild willy
My Ride: Cars
My friend has Nature Stone, that shiiiit is expensive and will need reapplication over time where your tires contact. I would not get it....
91 MR2
12 Altima SR
12 Quest SL
wild willy is offline   Reply With Quote
Old 05-15-2019, 07:46 AM   #3
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
Get something that's meant for abuse. Tite-Coat is the way to go.
https://titecoat.com/
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 05-15-2019, 07:58 AM   #4
SLVR JDM
My Ride: E39 M5
If/when I do my garage floor, I'll likely do Swiss Trax. I've done a coating, but it was 20 years ago and I didn't know what I was doing, so it did not hold up well. Tons more products and tutorials out there now.
SLVR JDM is offline   Reply With Quote
Old 05-15-2019, 08:29 AM   #5
///Mark_D
My Ride: 04 325i & 02 325iT
I went with a RaceDeck floor for my storage garage instead of a coating product. My concrete floor wasn't in the greatest shape so rather than try and patch cracks and level it out this was the easier and cheaper solution in my case
I'm happy with it after about 3 years of use it still looks really good. The floor is dirty in these photos but it cleans up easily. I usually go over it with a mop once a year and it ends up looking like new. Another benefit in my case is that the race deck acts like a barrier to keep moisture from coming up through the floor. This was a significant concern in my case since my car is parked here most of the year.
The website has an online floor designer you can use to make a custom pattern for the size of your floor and determine how much of each color you need. I also got a 10% discount from being a part of the GarageJournal forums.
RaceDeck website floor designer:
http://designer.racedeck.com/
Mark D.
(Previous user name mjdehlin)
///Mark_D is offline   Reply With Quote
Old 05-15-2019, 08:36 AM   #6
Black///M
My Ride: 2004 M3 Coupe
^Those pics are a throwback... is almost like going back in time...
Black///M is offline   Reply With Quote
Old 05-15-2019, 09:07 AM   #7
///Mark_D
I see what you did there.
Here's another picture I found from when I was installing the floor. It was pretty simple to put it all together and only took about an hour.
This was the layout I went with using the online design tool.
Mark D.
Old 05-15-2019, 09:42 AM   #8
bimmerfan08
My Ride: E46 M3
Yes. Proper prep is vital.
“But as I look overall at the capitalist economies, there are a lot of good things doing, and I think you can tune the tax parameters and get way more equity and get some additional government services and still be in the same basic framework.”
bimmerfan08 is offline   Reply With Quote
Old 05-15-2019, 09:58 AM   #9
Xcelratr
My Ride: 04 330Ci ZHP
Originally Posted by mjdehlin View Post
You, sir, need to go to a Radwood event.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
Old 05-15-2019, 10:24 AM   #10
///Mark_D
Oh man, I did not know such a thing existed. That's definitely my kind of car show...pretty frickin rad.
Mark D.
Old 05-15-2019, 11:52 AM   #11
aarondb4
My Ride: 2002 BMW 330CI Vert
I like this idea better than the coating. Less prep, less potential for issues down the road, and more easily replaceable if something does damage a tile or two.
aarondb4 is offline   Reply With Quote
Old 05-15-2019, 01:23 PM   #12
Stankia
My Ride: Germans
That looks gaudy as fuck.
Stankia is offline   Reply With Quote
Old 05-15-2019, 02:12 PM   #13
trizzuth
My Ride: Best M5 ever made
what was total cost for the racedeck flooring for that garage bay? I'm sure i can find out online but i'm lazy.
Personally, if I had a chance to do it and was building a new garage, I'd probably just do polished concrete and be done with it. But sounds like what is being asked here is more of how do I cover my existing shitty concrete floor with something nicer.
Racedeck sure looks like the easiest option to install with most minimal hassell, but appears to likely be way more costly.
2003 BMW E39 M5 - Current!
2001 BMW 330i - Totaled at 236K :(
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is offline   Reply With Quote
Old 05-15-2019, 02:20 PM   #14
trizzuth
I did some sample calculations for a larger 2 car garage...
24 feet long by 28 feet wide
diamond pattern inside with border, all XL squares which are 18", found a website that has them for approx $8 for the diamond print.
Tool says I would need 66 in alloy color, 119 in black diamond and 119 in graphite diamond, so 304 tiles in total.
304 x $8 = $2432!!! and no shipping cost which I can assume is a lot due to the weight.
Seems wicked expensive. Then compared it to the cost of a hardwood flooring install for the same area, and it seems cheapish. At least labor is free here, and don't forget this is a much larger area than the example provided here.
but man.. would last forever. How do these tiles hold up against things like jack stands with a car's full weight on them? and jacks?
Old 05-15-2019, 02:24 PM   #15
trizzuth
Cost for the standard 12" diamonds instead of the XL tiles comes out to 672 total tiles, and at around $3.69 each this totals $2479.68 so about the same price for 12's as for 18's.
Old 05-15-2019, 02:25 PM   #16
trizzuth
Oh - and Stainless Steel don't care about no silly moisture.
Old 05-15-2019, 02:27 PM   #17
MachRc
is married again
MachRc's Avatar
My Ride: 2003 Technik S1 M3
the racedeck free flow looks nice and pretty easy to maintain
but seeing more pix on the internet, I think I would rather just coat it
"My music Sicily, rich California smell. An axe killer adventure, paint a picture well. I sing a song from Sing-Sing
sipping on ginseng. Righteous wax chaperon rotating ring kings.."
MachRc is offline   Reply With Quote
Old 05-15-2019, 06:15 PM   #18
cowmoo32
cowmoo32's Avatar
No tiles, want a permanent single colored coating.
Old 05-15-2019, 08:53 PM   #19
Stankia
My Ride: Germans
Be a man and just do this:
Old 05-15-2019, 09:13 PM   #20
TitaniumSilber
Banned User
My Ride: E46 Cabrio stick
I have to agree w Stankia. Those snap-together-cheapy-Costco-tiles- bullsh1te are hideous. Look at all the waves/dimples,...
I don't get it....why not just PAINT checkerboard & SEAL it?? Lotsa vids on Youtube to do just that.
TitaniumSilber is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to level/fix my concrete garage floor? rkhettry23 General Off-Topic 24 04-10-2009 12:27 PM
Test bimmian Test Board 1 12-24-2007 07:40 AM
--UUC floor mats Review-- ADA General E46 Forum 17 12-05-2005 01:46 PM
FS: m3 floor mats bg For Sale, For Trade or Wanting to Buy 0 04-12-2002 01:35 AM
