Meter clock adjustment knob fix DIY - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-14-2011, 11:21 PM   #1
vishmutzy
My Ride: '01 325i Touring
The clock adjustment knob on my '01 325iT finally gave up the ghost. Several years ago the reverse CCW direction stopped working, but the advance CW still functioned. Yesterday the advance CW broke and I could no longer adjust my clock. The push direction still functioned, so I knew that the little poking finger was still intact.
Took the meter apart and sure enough both white resin hinge tabs were broken off. I did some research and the only fix I could find involved soldering a jumper onto the circuit board. To that dude's credit, he came up with an elegant solution and has wicked good soldering skills. I was all set to attempt it but ran into two issues:
1) My meter circuit board was different than his '99 and the etched traces were completely different;
2) Holy frijole... everything on that board is so tiny that I would surely short something as I globbed sloppy blobs of solder trying to attach a jumper wire.
While my soldering skills are lacking, I am a Jedi Master with a Dremel. Considering all of the micro-buttons are the same radius from the knob centerline, I figured that the little finger would be able to reach all three if the knob was given more freedom of motion.
So here's where the DIY starts (read through all before you start cutting!):
1) Remove meter, unscrew rear cover, and pull off rubber sleeves from knobs (pull straight off, requires some force).
2) Carefully separate circuit board from meter face.
3) Remove clock adjustment knob and prepare it for surgery.
4) Using a Dremel with a sanding drum or equivalent, remove the side ears (which used to contact the now-broken white tabs to reverse/advance time) all the way down to the disc-shaped part at the base of each ears. Keep the disc-shaped part of the knob and the shank intact and smooth since this limits the knob travel when pressed and serves as the rotating contact surface.
5) Now flip over the circuit board so the gauge dials are face up. Use a Dremel milling bit to carefully remove the top portions of the white resin slotted rim around the knob hole. Only remove the areas shaded RED in the attached diagram (10:00-11:00 & 1:00-2:00 positions only, keep 11:00-1:00 intact). Take the material down to the same level as the recessed surface.
6) Thoroughly clean out all your grinding debris.
7) Reassemble the meter cluster, ensuring that the modified knob is oriented in it's neutral position (finger downward) as you install the rear cover.
If you did it right, you will now be able to rotate the clock adjustment knob to activate all 3 button (reverse, advance, and 12/24 hour) with the finger. It requires a bit of finesse to find the reverse/advance buttons, but since you have a detent at 6:00 (12/24 hour button) and positive stops at 11:00 and 1:00 (can not move between 11:00-1:00 due to remaining top section of rim), it's not difficult to find the reverse/advance buttons.
Sorry but the photos are stolen from other posts. I did this during my lunch break today in the parking lot in the rain and didn't have the luxury of taking photos.
vishmutzy is offline   Reply With Quote
Old 05-14-2012, 11:04 PM   #2
Chris3Duke
Going to try this...
Chris3Duke is offline   Reply With Quote
Old 03-08-2015, 08:50 PM   #3
The Snake
My Ride: 330Ci
Has anyone else tried this?
"If you aren't driving a stick shift BMW, you're just steering"
Suspension: Koni Yellow Struts, Rob43 Shocks, H&R Race Springs, ZHP Control Arms, Meyle HD bushings
Drivetrain: ECStuning Lightweight Flywheel + E34 M5 Clutch kit, 545i shifter
Interior: GSP Mason Clutch Pedal, M3 Seats, M3 Steering Wheel (Coby), ZHP Knob
Misc: E90 Chime Retrofit, CF Strut Bar, VMR V703 CSL Rep. Wheels
The Snake is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-09-2015, 02:31 AM   #4
SilberVogel
My Ride: 2002 330Ci Conv.
^ Yes; works great and very easy to do. Here's some additional links that address the "twist" and "push" functionality, depending on what all is broken:
Videos & Tips: https://forum.e46fanatics.com/showthr...5#post16289730
DIY Push Functionality: https://forum.e46fanatics.com/showthread.php?t=719606
DIY Twist Functionality: https://forum.e46fanatics.com/showthr...7#post14142857
Replacement Knob: http://onlineshop.wunschtacho.de/pro...t-cluster.html
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 12-28-2017, 05:14 PM   #5
owatdahey
My Ride: 2000 328Ci
Thank you vishmutzy for this DIY fix. My 2000 328Ci plastic "wings" broke as I was trying to change the clock while I was driving last Fall. I finally got around to getting a Dremel tool and followed the instructions above. Easy project -- just follow the instructions and look at the video link posted by SilberVogel above too.
owatdahey is offline   Reply With Quote
Old 03-26-2019, 04:18 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 1.569 mu
Year: 99
Model: 328i
Transmission: 5-spd
I like it...can't wait to try!
See Facebook for upcoming shows...and listen to my podcast! dmax on Facebook
Brand new unlisted vid just for you.
Mangofy your E46!
dmax is online now   Reply With Quote
Old 05-17-2019, 07:57 AM   #7
dmax
dmax's Avatar
Year: 99
Model: 328i
Transmission: 5-spd
Do I need to disconnect the battery to remove the cluster? I know it's always a good idea, but it's a pain and easier to ask here! Thanks!
Mangofy your E46!
Old 05-17-2019, 11:11 AM   #8
dmax
dmax's Avatar
Year: 99
Model: 328i
Transmission: 5-spd
All done and thank you so much OP. Both my little white plastic tabs were broken. I've been without the ability to reset my clock for over a month and I can't believe how frustrating that was to see it an hour behind.
I didn't disconnect my battery and it turned out fine...except...
When I plugged it in the first time, the odometer had lots of broken up parts to it...so took it out again and figured I may have put one screw in the wrong hole. So...I chose another and this time it's fine. Thank you OP!
Mangofy your E46!
