INPA and resetting adaptions + Bad fuel economy! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-08-2019, 01:33 AM   #1
Cibby600
My Ride: 2001 E46 325I Sedan
Hi All,
I recently did a LOT of work on my car.
I changed / repaired the following:
Rebuilt VANOS
Replaced entire CCV system
Replaced intake boots and DISA valve
Replaced intake manifold gasket
Replaced all perished and cracked vacuum lines and hoses
Replaced throttle body gasket
Replaced VCG and dipstick O rings
Replaced coolant temp sensor and cam position sensor (Ex)
Replaced injector O rings and filter screens
Cleaned MAF, TB and IAC
Replaced OFH Gasket
Replaced water pump
Replaced all drive belts and tensioners
I did some other work, but unrelated, removed mechanical fan etc.
So car runs great except for a purge valve error. No big drama, I'll get there eventually.
So I recently installed INPA and went to reset my adaptions as the car has been running in a neglected state for a LONG time and has just had a heap of repairs done.
Car was idling and I was mashing keys and clearing adaptions.
Now I really should have read exactly what each adaption does as I got to F4 or F6, can't remember exactly, but RPM rose to about 1300 and throttle did nothing. Car bogged and wouldn't accelerate.
I quickly turned the car off and then tried to restart it. It started ok, idled ok, so I went for a drive.
Car drives OK. MAYBE a little down on power, but could be my paranoia!! lol
QUESTIONS:
Could I have done any damage resetting adaptions with car running??????
Car is also still using a lot of fuel.
I think the thermostat is stuck open as it takes a long time to warm up. Runs at 187 degrees farenheit when hot.
Will fuel consumption possibly settle after resetting adaptions, or more related to soft failing thermostat. Getting around 14 - 15MPG
Car is a 2001 325i Auto Sedan with 200K KMS
Sorry in advance for my ramblings! lol
Cheers.
Cibby600 is offline   Reply With Quote
Old 11-08-2019, 01:43 AM   #2
darkfires102
My Ride: 325xi, '07 E60 M5
Year: 2003
Transmission: 5spd Manual
Shouldve reset with the car on power on mode only, not engine running, huge mistake. MPG will come back later after adaptation occurs again. Damage done? unlikely if the car is running fine now. Soft thermostat will hurt mpg since the car will be dumping fuel in to try and heat up quicker
darkfires102 is offline   Reply With Quote
Old 11-08-2019, 02:56 AM   #3
LeverThis
My Ride: 2004 325i automagic
+1 ^
Soft failing tstat will hurt fuel economy. Hopefully that 14 to 15 mpg is city driving, not highway. Operating temp is around 96C, btw.
While you are in there, it's a good idea to replace the expansion tank (if that hasnt been done recently) since that is a major weakness of the cooling system. With an auto, you also will need to change the atf thermostat that is at bottom of ET as it often breaks when the ET is removed.
You may also want to look around the transmission for signs of leaking ATF, including at the selector shaft where it goes into side of transmission. Low atf levels can cause sluggishness and probably a loss of fuel economy.
20mm OD x 12mm ID x 4mm W : Viton O-Ring
3/4" OD x 1/2"ID x 1/16" Thick : Thrust Bearing/Washer
LeverThis is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-08-2019, 03:34 AM   #4
Cibby600
Originally Posted by LeverThis View Post
+1 ^
Auto is reasonably leak free. Will be doing a full fluid and filter change in the near future so will double check it.
Think I'll just do thermostat for now and hope I don't break anything when swapping it out. Will check fuel economy then refressh cooling system later.
Yes city driving BTW.
Thanks.
Old 11-08-2019, 04:48 AM   #5
Anticdubai
14 mpg is still too much unless you rev to red zone from every traffic light. Iíd recommend to get a close look at MAF. The way it affects driving is hugely underestimated usually and paid attention only when your instrument panel lights like a Xmas tree. cleaning usually doesnít do much unless it really was covered with dust, and even using proper MAF cleaner doesnít guarantee safe result. It could still work but not right. It wonít show any codes, but if you swap it with new one youíll see noticeable difference.
Anticdubai is offline   Reply With Quote
Old 11-08-2019, 11:46 AM   #6
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Originally Posted by Anticdubai View Post
14 mpg is still too much unless you rev to red zone from every traffic light. I'd recommend to get a close look at MAF. The way it affects driving is hugely underestimated usually and paid attention only when your instrument panel lights like a Xmas tree. cleaning usually doesn't do much unless it really was covered with dust, and even using proper MAF cleaner doesn't guarantee safe result. It could still work but not right. It won't show any codes, but if you swap it with new one you'll see noticeable difference.
The MAF can and will trip trouble codes if it falls too far out of range or if there's a problem with the circuit.
I would not blindly replace the MAF, or any other part for that matter. Check its performance first. The MAF at warm idle with accessories off should be between 3.6-4.2 g/s. MAF should be genuine BMW or Siemens/VDO brand.
Old 11-08-2019, 11:50 PM   #7
Cibby600
Here is a screenshot at idle before deleting adaptions. Pretty sure it's the original MAF.
I will check again tomorrow as I went for a 60KM drive today. Getting almost 17MPG after todays city drive.
Will check further tomorrow.
Cheers.
Old 11-09-2019, 12:33 AM   #8
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Cheers.
Your MAF value of 12.5 kg/hr converts to 3.47 g/s, which is fine.
Post the L-probe and A-reg screens as those show the O2 sensors and fuel trims.
Old 11-09-2019, 05:57 AM   #9
Cibby600
No probs. Will do it tomorrow. I am guessing it is just down to the EVAP purge solenoid and 200K on the motor.
Cheers.
Bloody valve cover gasket is leaking again. Replaced it a month ago. Oh well, time to rip it out and RTV it! LOL
Old 11-09-2019, 12:13 PM   #10
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Regarding clearing adaptations, I have seen a few cases where clearing all DME adaptations using INPA significantly improved engine running. Cannot tell you exactly why. In the course of doing over 300 free DME and EGS updates over the years I have seen it more than once.
I've never seen a case where clearing adaptations hurt anything. Make sure the engine is off while clearing.
Old 11-09-2019, 12:19 PM   #11
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Itís pretty common to get hairline cracks on these old plastic valve covers, so check for that. May be the source of your leak if the gasket is fairly new. Iíve patched them with JBWeld.
Old 11-09-2019, 04:31 PM   #12
Cibby600
Will double check the valve cover for cracks as I didn't when it was off last time.
Engine seems to be running a little better after resetting adaptions. Not much, but a little.
Perhaps after "relearning" for a while it will run a little better again.
Yeah, I should have read up on resetting adaptions as my motor was running when I did it. Doesn't seem to have hurt it, but lesson learned!
Thanks everyone. Will post screenshots of O2 sensors and Fuel Trims later today!
Old 11-10-2019, 03:58 AM   #13
Cibby600
Well, everything looks ok. Could be a little better, but motor has 200K KMs!
I think long term fuel trims are either perfect, lol, or perhaps not reading yet as I reset adaptions 70KMs ago.
I am posting VANOS as I have nothing to compare it to. Does it look ok???
If anything doesn't look right, please let me know.
P.S. My car does not have post cat O2 sensors.
Cheers.
Name:	Fuel trims 1.jpg
ID:	787707   Click image for larger version
Name:	Fuel trims 2.jpg
ID:	787709   Click image for larger version
ID:	787711   Click image for larger version
Old 11-11-2019, 07:48 AM   #14
TR4G-
My Ride: E36/8 3.0i, E46 ZHP
Long term fuel trims will correct themselves after just a few miles on their own. Thatís what they do.
Sent from my iPad using E46Fanatics
TR4G- is offline   Reply With Quote
Old 11-11-2019, 02:01 PM   #15
Cibby600
Old Yesterday, 02:20 AM   #16
Cibby600
So just an update.
I replaced the thermostat that was stuck open, and reset all DTC's and Adaptions. WITHOUT THE ENGINE RUNNING this time! lol
Everything looks good, car drives great and fuel economy is down to about 20MPG with mainly city driving.
Running temps are now around the 200 Degrees F. So Win Win!
Still have an EVAP purge valve that has a dead short, so might get better economy again when I get around to replacing that!
Thanks again for all your help and advice people!
Cheers.
Old Yesterday, 12:51 PM   #17
NAVIRA
NAVIRA is offline   Reply With Quote
Old Yesterday, 01:55 PM   #18
Cibby600
I did think about it, but time and money dictated the repairs, as I needed the car back on the road and had bills to pay! LOL
Old Today, 09:26 AM   #19
MrMCar
My Ride: M-3 R1150 MCoupe
Glad you found a thermostat issue and replaced it. Should help.
A note about resetting adaptations:
With our scanners (Autel, GT-1 & ISTA) resets can be done on the fly and/or KOEO or at idle, doesn't matter. After resetting it takes the engine/DME a few minutes to get a baseline (other than the baseline map stored in the DME) of what values the engine is reporting and where it needs to be. Often the car can run funny for a minute or two.
We're not a big fan of resetting adaptations as a generality. Adaptation & trim numbers read out can be a VERY useful tool.
1) You suspect you have a vacuum leak and effect repairs to various hoses and/or intake boots. Did your work bring about a correction?
If you DO NOT reset the adaptations, you can drive the car normally for a day (taking note of the adaptation & trim numbers before you did some repairs) and then after a day, have the numbers started to return to a more normal state?
2) You suspect you have a bad MAF sensor. You swap in a new one. Again take note of the adaptation & trim numbers. Drive the car NORMALLY, do the numbers start to come closer to normal? If yes, you're on the right path.
Additive (short term) and Multiplicative (long term) take time to register a baseline, especially the multiplicative. If the car is taking action to bring the engine into line by making corrections (adaptations) you can use this as a very useful tool in diagnosis.
Resetting the numbers to a zero value makes the DME start all over again and it's going to take some time before you see if the work you've tried brings about fruit.
A misconception about resetting adaptations. Many claim the car will run better, it can/does for a short while. Resetting is most often done after a repair of sorts, so the car should run better.
The DME will always take measurements and utilize strategies to correct engine parameters in order to bring the engine into a "optimal" baseline. When the engine runs either lean or rich of the target corrections are brought forward: Multiplicative. Knowing how much the DME has added or subtracted is indeed a useful tool.
So when you have a running issue, resist the urge to reset the adaptations, just clear the engine faults (adaptations are unaffected by clearing) and drive the car. Then look at the adaptation numbers after some time and normal driving. Are they returning back to normal? If so, your accomplishing something.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
