Strange engine noises - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-25-2013, 02:22 AM   #1
4mustiuck
My Ride: 2001 BMW 330d
Unhappy Strange engine noises
Hi all,
Do you guys know what the problem might be?
There are actually two worrying sounds: a metalic rattle which gets worse by the end of the recording and some kind of vibration (starting at 00:24) which is not noticeable all the time (as you can hear in the video).
I turned off the engine once the metalic rattle got too loud...
Would it be safe to drive it to a car service? I don't have the possibility to try to fix it myself.
Regards_a_
4mustiuck is offline   Reply With Quote
Old 07-25-2013, 04:01 PM   #2
4mustiuck
come on guys, there has to be some of you facing the same issue at some point...
Old 07-25-2013, 04:39 PM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
The cricket noise is a bearing on an idler/tensioner pulley, nothing else matters.
Sponsored Links
Advertisement
Old 07-25-2013, 04:41 PM   #4
farukh
My Ride: BMW 325i 2002
Yep ^
99% its the pulley. Look in there with flashlight and see if any of the pulleys is moving weirdly.
farukh is offline   Reply With Quote
Old 07-25-2013, 04:46 PM   #5
jdstrickland
Originally Posted by farukh View Post
Yep ^
Even better, take the belt off and turn the pulleys. You may not see any strange movement, but you should be able to feel rotation that's not right, especially if you get a new pulley and compare how it feels to the old one.
Old 07-25-2013, 04:56 PM   #6
farukh
^that! OR, take the belt of and spin the the pulley hard... if it spins freely - it's time to change it! Good pulleys have some kind of mambo jumbo inside and don't spin freely.
Old 07-25-2013, 05:01 PM   #7
LeMansteve
My Ride: sold - '04 330i
You can clearly see the pulley is wobbling slightly in the video. Replace it.
Old 07-25-2013, 05:07 PM   #8
jdstrickland
Mambo jambo? I thought it was spider sperm.
Old 07-25-2013, 05:09 PM   #9
farukh
Haha it probably is!
Old 07-25-2013, 05:38 PM   #10
4mustiuck
Thanks a lot for the replies!
Does it make sense that the sound gets even more severe after a while? You can notice this @00:45.
Is is possible to be the chain? Is it safe to drive it to a car service? I don't want to crack something and invest a bunch of money afterwards...
Cheers
Old 07-25-2013, 05:44 PM   #11
farukh
Cheers
Well, the worst that can happen is: your pulley go out... belt tear into pieces... car suddenly shuts off... steering jams... brakes become hard...
Its a very easy DIY though.
Old 07-25-2013, 06:05 PM   #12
4mustiuck
Hmmm then I will consider to try doing it myself...
Any chance the noise might be caused by the timing chain? (I hope not!!)
Cheers
Old 07-25-2013, 06:12 PM   #13
farukh
Cheers
It drove for like 3 weeks with that noise until the big break down happened... Since you are DIYing it, it is a good idea to change both belts there and all the pulleys. Some people recommend to change the water pump as well, but I did not change mine since it looked good to me.
Old 07-25-2013, 06:17 PM   #14
4mustiuck
Yes, I also think it's a good idea to change as much as possible there. The water pump has been changed months ago therefore I would not change it for now.
Do you think the noise might be related to coolant being spread all over? I had a coolant leak issue just before getting this annoying sound...
Cheers
Old 07-25-2013, 06:48 PM   #15
farukh
Cheers
Sometimes the moisture can cause the belt to squeak. Did you have your leak taken care of?
Old 07-25-2013, 07:22 PM   #16
4mustiuck
Yes, of course.
First I had the coolant leak problem, after a while (few days) the noise came, then I fixed the leak. The noise was not so harsh in the beginning and after driving the car for few minutes it would go away. I drove the car few times, short distances, then suddenly the next day I start the engine and bang! I get this noise. Now, while the engine is running, the noise gets even worse contrarily to how it was before...
Cheers
Old 07-25-2013, 07:29 PM   #17
farukh
Yes, of course.
Cheers
Yea, when my pulley went bad, the noise was intermittent at first, but then it got louder and pretty much constant.
330d, e46, engine noise
