door locks are crazy - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 51 votes, 4.94 average. Display Modes
Old 11-15-2005, 11:56 AM   #41
byunts
My Ride: '06 330i
Read my post farther up. I'm pretty sure your lock actuator(s) are beginning to fail or have already failed. I replaced mine a few months back. The problem has never come back.
byunts is offline   Reply With Quote
Old 11-15-2005, 07:25 PM   #42
vinceye36
central locking problem
had my car checked with a mechanic and plugged the computer.. there are errors in the module.. but the weird part is that for the past 3 days before i brought my car to him the unlocking is working properly.
will have it check again as it may be a loose connection, or probably a dirty mechanism inside the door panels..
vinceye36 is offline   Reply With Quote
Old 11-15-2005, 10:04 PM   #43
HiMiles
My Ride: 99 328i
Actuator
You don't happen to have that actuator part# handy? I would really appreciate it. Let m eknow. Thanks
HiMiles is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-16-2005, 09:07 AM   #44
mikeson
My Ride: 99 323I
we are in same boat.
I have a exactly same problem and past a month, it works ok.
But the module is too expensive so I think I have to live with.
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 11-16-2005, 10:57 AM   #45
byunts
My Ride: '06 330i
For a '99 328i,
Front R-51217011308
Front L-51217011305
Back R-51227011310
Back L-51227011309
Old 11-29-2005, 01:45 AM   #46
bmw320CI_FR
My Ride: 320CI 2L (150 ch)
I have the same problem on my 99 320Ci since almost a year now and it is getting worse.
Which lock actuators have been replaced for you? left, right or both?
My problem is that doors won't unlock unless I use the key. But passenger door won't unlock at all.
bmw320CI_FR is offline   Reply With Quote
Old 12-14-2005, 03:29 PM   #47
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
omg I've only had my 01 330ci for a few months and I have the same problem as all of you. Seems that with such a common problem with these cars, BMW would have a recall to fix it? Maybe my car is too old tho. Out of warranty too =(.
This problem is not only a hazard, but embarrassing too!! Such an expensive car to have to climb through windows.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 01-28-2006, 03:42 PM   #48
TKC
This problem is getting ridiculous. My friend had to go to the hospital in an emergency and the ****ING door wouldn't unlock!!! Lucky for us, we happened to be at a friends house who let us use their car!! This is ridiculous! I hope BMW realizes what a hazard this problem is and what a huge safety issue it is.
Old 01-28-2006, 06:28 PM   #49
gjvilleg
My Ride: 2001 325Ci
same problem here..... Drivers side only
gjvilleg is offline   Reply With Quote
Old 01-29-2006, 12:36 AM   #50
dadysev
My Ride: 1999 323i
Send a message via MSN to dadysev
I found that when I replaced the battery in the key, it never happened again.
dadysev is offline   Reply With Quote
Old 01-29-2006, 02:56 PM   #51
TKC
I don't think replacing the battery in the key will help me. The alarm chirps that it's turning on and off, just the door locks themselves won't move.
Old 02-21-2006, 06:47 PM   #52
bimmer
it seems to be happening for most cars that are around 99-01. I had the same problem and replaced the actuator for on side.
If both don't lock and unlock at the same time or you are having troubles disarming the car, it might be the key battery
bimmer is offline   Reply With Quote
Old 02-21-2006, 06:47 PM   #53
bimmer
Old 02-21-2006, 08:09 PM   #54
TKC
Nah, locking has never been a problem, just unlocking. And it does happen to both sides, but fortunatly I can unlock the driver's side with the key.
I doubt it's the battery inside the key because the alarm beeps and the parking lights flash that it's unlocking, but the locks themselves physically don't move/unlock. That's why I think it's the actuator.
Note: there was a couple times where I held in the gas cap door (i pressed in on it gently, incase the pin was caught too tight) and it worked! The door locks opened!! So weird...
BYUNTS, was it a pain to do the work or did you take it in?
Old 02-22-2006, 02:03 PM   #55
DUH I4GOT
My Ride: 2002 Silver 330 Ci
Send a message via AIM to DUH I4GOT Send a message via Yahoo to DUH I4GOT
Any solution yet guys? I have the same problem in the winter time.
DUH I4GOT is offline   Reply With Quote
Old 02-22-2006, 02:11 PM   #56
dadysev
My Ride: 1999 323i
I'm telling you its weird man but I poped a new battery in my key and the spare and it stopped
Old 02-22-2006, 02:29 PM   #57
'busa
'busa's Avatar
My Ride: E90 335i (sold)
Your key has removable batteries?
'busa is offline   Reply With Quote
Old 02-22-2006, 02:33 PM   #58
Masko
Masko's Avatar
My Ride: silver coupe
Send a message via AIM to Masko
The key does not take batteries and even if it did it's close to impossible to open the key without damaging it.
BTW I have the same exact problem with my locks and everybody I ask tells me the problem is the lock actuator.
Masko is offline   Reply With Quote
Old 02-22-2006, 02:39 PM   #59
dadysev
My Ride: 1999 323i
mine is the fat key and yes you can remove the batteries. you take out the little cover, take out the two phillips screws and there it is. Some keys charge off the ignition barrel.
good luck
Old 02-22-2006, 05:05 PM   #60
Masko
Masko's Avatar
good luck
I didnt know 99 e46's had different keys
Just curious as to what type of battery your style of key holds? Is it like a standard round watch battery type?
