Removing Intake Manifold, what should I replace while it's out? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 11-07-2019, 02:38 PM   #1
wes.cooper
My Ride: 2002 e46 M3
Year: 2002
Model: M3
Transmission: Manual
New to the forum and a total BMW noob
I recently bought a 2002 e46 M3 and I'm about to remove the Intake Manifold to replace both Throttle Position Sensors. I'm replacing these because the car has dropped into "LIMP" mode twice now and reading through the threads hear, most people say to start by replacing both TPS sensors. While the Intake manifold is out and while I'm replacing the sensor that sits under the manifold, what else should I replace while it's out? I need to do the power steering, so that too will be done, but if you can recommend replacing anything else, such as vacuum hoses, I would greatly appreciate it. I'm trying to not have to remove the intake manifold too many times.
Thanks for your time.
Wes
wes.cooper is offline   Reply With Quote
Old 11-07-2019, 02:51 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
You would do best by reading codes first - before buying and replacing things.
Alan is offline   Reply With Quote
Old 11-07-2019, 03:00 PM   #3
wes.cooper
Year: 2002
Model: M3
Thanks for the quick reply. I unfortunately do not have a scanner (if you could recommend one, I would appreciate it) and the BMW shop I took her to came back with no codes. Like I mentioned, after I shut off the car and turn it back on, the car is fine, so I assume the codes are being wiped?
Thanks again for the reply.
Sponsored Links
Advertisement
Old 11-07-2019, 04:51 PM   #4
DaHammer
My Ride: 2003 325i
There are a lot of choices when it comes to scan tools for these cars. The forum favorite is probably OBDFushion along with a compatible this one:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
That will cover your basic codes, from there you can get into more specific tools like BMW Scanner, DIS, INPA and etc.
”Those who give up their liberty for more security neither deserve liberty nor security.”
Ben Franklin
DaHammer is offline   Reply With Quote
Old 11-07-2019, 05:40 PM   #5
mrgizmo04
My Ride: '05 ///M3
Depending whether you need to, there are a lot of things for while you are in there.
Air filters, clean icv and tb, you could get into cooling with fan clutch/thermostat/orings, all power steering hoses, accessory belts, engine mounts, starter, heater core and hoses...next thing you know you are replacing the clutch, rebuilding vanos, replacing rod bearings and re-bushing the rear end. That's how it went with me .
So careful about "while you are in there".
Sent from my SM-G950U using Tapatalk
mrgizmo04 is offline   Reply With Quote
Old 11-11-2019, 03:09 AM   #6
Dogthebountyhunter
My Ride: 03 M3 Vert 2005 745i
If your definitely taking off the intake, I would replace the plastic drain hose. That is going to break. Also replace all the icv hoses while your there & clean it. Before you do anything I would buy a scanner. Is your car smg?
Dogthebountyhunter is offline   Reply With Quote
Old 11-13-2019, 09:02 PM   #7
turbokid
My Ride: 2005 325i
This guy will tell ya...
Regards,
turbokid is offline   Reply With Quote
Old 11-13-2019, 09:08 PM   #8
mrgizmo04
My Ride: '05 ///M3
Just be careful that Jason is not working on an S54, common problem areas are somewhat different, we have no disa, cooling system is different, fluids are different, part numbers are different, ccv, etc
Old 11-14-2019, 12:40 AM   #9
PhantomX
My Ride: E46 M3
Wes
Bro my car is having the same issues! Please let me know when you swap out both TPS and if the problems go away. Thanks!
-1999 BMW M3 Convertible 6SP(Sold)
-2002 BMW M3 Coupe SMG(Current DD)
-2002 BMW M3 Convertible 6SP(Totaled by Red Light runner....that Bastard)
-2004 BMW 325CI Coupe (Sold)
-2003 CBR 600RR (Sold)
-1995 Acura Integra Turbo (Sold)
-1989 BMW E30 (Totaled by sis)
Instagram | Snapchat @ TwinzTurbo
PhantomX is offline   Reply With Quote
