DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV? - Page 100 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Mobile Electronics Forum
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average. Display Modes
Old 12-17-2019, 11:20 AM   #1981
harryberlin
My Ride: E39 Touring
Originally Posted by vitalic View Post
Thx harry, do you also have the output of cmdline.txt?
Code:
boot=UUID=2311-4421 disk=UUID=4a7717ae-4e4f-431a-86cf-643c8bb8834a quiet
harryberlin is offline   Reply With Quote
Old 12-18-2019, 12:46 PM   #1982
vitalic
My Ride: E38
@PeteAU and harry
I solved the problem with Pi4:
cmdline.txt : remove console=serial0,115200 (or console=ttyAMA0) if it exists
config.txt : add dtoverlay=pi3-miniuart-bt (don't download the modified, use original from stretch) and also add enable_uart=1
disable internal bluetooth with command:
sudo systemctl disable hciuart.service
most important:
@PeteAU you need to modify gpio.c . I forked your repo on github and made some changes to fit for the Pi4:
https://github.com/Vitalic66/pibus/b...ter/rpi/gpio.c
Code:
//Pi3
#define V1_BCM2708_PERI_BASE        0x3F000000
#define V1_GPIO_BASE                (V1_BCM2708_PERI_BASE + 0x200000) /* GPIO controller */
//Pi4
#define V2_BCM2711_PERI_BASE        0xFE000000
#define V2_GPIO_BASE                (V2_BCM2711_PERI_BASE + 0x200000) /* GPIO controller */
After compiling the new pibus and copying to my pi, pibus works. LED is blinking and ibus communication is logged in ibus.txt
vitalic is offline   Reply With Quote
Old 12-18-2019, 03:23 PM   #1983
harryberlin
great news.
that means, the program only runs on rasp 4 or is it compatible to 1-3?
Sponsored Links
Advertisement
Old 12-18-2019, 06:32 PM   #1984
PeteAU
My Ride: 330i
Code:
//Pi3
//Pi4
Test this out:
http://pibus.info/sw/pibus-20191219.zip
https://github.com/PeteAU/pibus/comm...84bb77f93101d2
PeteAU is offline   Reply With Quote
Old 12-19-2019, 11:54 AM   #1985
harryberlin
do you need new pibus version compiled on rasp 1 b+?
Old 12-22-2019, 04:14 AM   #1986
vitalic
My Ride: E38
Thx Pete for the new version. I can confirm that it also works on Pi4.
Just got one little question about the shutdown event. How does it work? When does Pi shutdown? If the 300sec bus idle time is over or also if there is a specific ibus message?
I watched the ibus messages with navcoder. There was one "ignition off" but that didn't make the pi go down. Maybe it's because i took out all necesarry modules (speedometer, navmodule, tvmodule, bordmonitor, radiomodule) out of my car to test my new board.
The ibus and the board work, but I can remember that there was a message "immobilizer on", which also made the pi go down?
Old 12-22-2019, 05:52 AM   #1987
harryberlin
normaly the pi shuts down after timeout (300s). timeout counter starts after last ibus message. if there is a new message, the counter gets reset.
Old 12-22-2019, 02:44 PM   #1988
vitalic
My Ride: E38
Btw the new PCB prototypes (Pibus AiO 1.4.1) arrived and already started soldering.
Unfortunately I just found 2 mistakes but with this version I can start the new HDMI switch tests and see if I applied the HDMI design guidelines careful enough (had HDMI artefacts in former version).
At the moment picture from Pi and reversecam come clear and stable.
See the video how it works:
I use navcoder to emulate reversegear signal.
The PCB is designed to also work without the Pi.
It will fit into the TV module housing.
Next steps are soldering RGsB to HDMI converter on the PCB and further testing.
But first of all clean up dining table from soldering tools for xmas...
ID:	790569   Click image for larger version
ID:	790571   Click image for larger version
Old 12-23-2019, 05:46 PM   #1989
vitalic
My Ride: E38
Just because I wanted to check if picture from OEM also works I soldered the RGsB to HDMI converter too.
The video shows switching from OEM to Pi and back and also switching to reversecam in OEM mode and Pi mode.
So at least all video sources work. Next step is soldering and testing USB hub and audio.
Old 01-08-2020, 03:40 PM   #1990
PeteC
My Ride: 330XI Silver
@PeteAU
Have a couple of BMW's / IBus with CarPC's. I am switching over to MicroPCs and I would like to run your PiBus software on an Intel based PC.
Is the PiBus software available for Intel.
I tried to compile the software but had issues and I am not proficient at this sort of stuff.
CC = x86_64-linux-gnu-gcc
STRIP = x86_64-linux-gnu-strip
all:
$(CC) -Wall -O2 -ggdb mainloop.c slist.c pibus.c ibus.c ibus-send.c keyboard.c gpio.c server.c log.c annotate.c -o pibus -lrt
cp pibus pibus.debug
$(STRIP) -R .comment pibus
Just got errors when compiling.
home/pete/Desktop/pibus-master/rpi# ./pibus
mmap error 0xffffffffffffffff
Can you please help?
E46 - Mods - 18.5 wheels (summer), Homelink, NAV software upgrade, 16:9 display, TV Module, Radio to V53, AUX, USB IBUS interface,OEM alarm, Mini ITX computer, halos, front clears,BT, LED Tails and DEI remote starter. Pending - painting brake calipers.
E83 - NAV - Panoramic Sun roof, Sirius, BT, etc. Completed Mods - Homelink mirror, rear door release, AUX, CD changer. NAV video input module. USB IBUS Interface. MinITX CarPC - 20" wheels
PeteC is offline   Reply With Quote
Old 01-09-2020, 03:02 PM   #1991
vitalic
My Ride: E38
@PeteC
I guess it won't work without recoding. Pibus is designed to work with Pi.
Take a deeper look into the files at github. Thx PeteAU it's open source.
The problem starts at the gpio.h file. There are several settings for Pi's RAM and from which adress it should start using the gpio...
About my project:
Finally found a way to shutdown everything save with an adjustable offtimer circuit. Giving the board 6 minutes default time before cutting power off completly after IBUS is idle.
Also fixed picture problems coming from input noise.
USB hub works as expected. Will test audio from Hifiberry DAC circuit soon.
Going to redesign some traces and connectors too. Next version should be final prototype to test in my car.
Old 01-10-2020, 07:03 PM   #1992
bmwdud121
My Ride: 2002 330i
This is fantastic work, Vitalic! Looking forward to seeing the prototype in action
bmwdud121 is offline   Reply With Quote
Old 01-11-2020, 04:37 AM   #1993
harryberlin
got mine pcbs for atmega 2560 too.
today is solder day
Old 01-11-2020, 05:28 AM   #1994
bmwdud121
My Ride: 2002 330i
today is solder day
Ha! Used to program on those back when I started with Arduino (Megas!). Wunderbar
Old 01-12-2020, 11:44 AM   #1995
PeteC
OK so I tried running the Kodi Raspicontroller plugin on the S912 TVBox (Octocore Arm / 3Gb of RAM) and it works well!
The S912 TV box with 3Gb of RAM includes a Gb NIC and Wireless and Bluetooth with a smaller footprint than any RPi.
I like these better than the RPi's lately.
Note this is sold as an Android based TV Box and I have been testing these for 4K KODI with Armbian Linux.
Using an HDMI to VGA cable which goes to the combo Ibus / VGA box to the E46 / E83 automobiles.
