Glass Plate Negative Display Idea - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Photography
Photography
Old 05-10-2016, 02:46 PM   #1
Brucifer325
My Ride: 2007 Ford Edge
I have an 8x10 glass plate negative of a rock outcropping in the ocean.
The idea is to create a kind of shadowbox with a light source illuminating the plate from behind.
Something like this:
Light Source ---> Opaque Glass ---> Glass Plate ---> Opaque Glass
The light source will more than likely be LED Christmas lights in a pegboard for even distribution.
This goes through a frosted pane to defuse the light.
Glass plate and final opaque pane to display image.
I've searched lightly for light box/shadow box and such, but didn't see anything. Has anyone seen such a set up before? The frame would be rather simple to construct with my neighbor's table saw, but any suggestions as to distances between the plates? Because of the cord, this would probably be displayed on a shelf.
Rate this post positively
I'm doing something wrong with my life.
"Love Us with Money, or We'll Hate you with Hammers!" - Milk & Cheese
BMWCCA# 147961
Brucifer325 is offline   Reply With Quote
Old 05-13-2016, 09:04 AM   #2
cowmoo32
cowmoo32's Avatar
My Ride: Yukon, E92 M3
The distance between plates will be determined by the brightness of the lights and the opaqueness of the glass that you're using. I'm assuming you're talking about frosted glass to get diffuse light coming through the negative, right? Just get a few thin strips of wood/plastic/whatever and lay them on either side of the lights, then you can play with the distances between plates until you get it right. The frame should be simple enough, just cut channels to allow the plates to slide in and cap the top/bottom.
Old 06-03-2016, 09:22 AM   #3
Brucifer325
Frosted up a dollar store 8x10 and what was in the back of my mind happened: it didn't work.
For some reason (foolish hope) I thought a projected image of a negative would inverse onto a surface. I forgot that the reason for the negative is to regulate light onto a chemical solution to create an image.
So, unless there is a way to inverse the coloring of a negative by optic means alone, I think I'm SOL.
BMWCCA# 147961
Old 06-13-2016, 06:32 PM   #4
cowmoo32
cowmoo32's Avatar
I have a vague memory of seeing a negative print with different colored light projected on it that showed up in "true" colors. I'm sure it could be done with some gel filters or colored LEDs
