DIY: Convertible hydraulic cylinders and lines - Page 8 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 104 votes, 5.00 average. Display Modes
Old 09-01-2017, 05:57 PM   #141
Greg325
My Ride: 2005 330Ci conv
Thanks, I actually just fixed it.
Bought the Mercedes ZH-M oil, mainly because my local MB dealership stocked it. Tried BMW first but they didn't even have it in stock.
Filled it up and now the top goes super fast!
2005 330Ci convertible
Greg325 is offline   Reply With Quote
Old 09-30-2017, 05:01 PM   #142
taylor192
My Ride: 2003.5 M3
Photos are fixed, moved to imgur. Please let me know if any are not displaying or accurate.
Old 10-21-2017, 07:38 PM   #143
Lucho813
My Ride: 2002 M3 e46 converti
I contacted Top Hydraulic in Florence Or. My symptoms were that I had to assist manually the open and close sequence while holding the appropriate button. Ordered the hydraulic pump from them replaced and now the top works ***128175;% automatic. No need to manually assist the open/close sequence. The culprit was a weak pump.
Lucho813 is offline   Reply With Quote
Old 01-07-2018, 07:27 PM   #144
jman103099
My Ride: e90, f25, e46
Originally Posted by taylor192 View Post
Damn! Great job! wish I had considered alternative routing, way to think outside the box!
In theory the line could be run along the forward edge of the storage area. Either tuck the line under the weather striping or secure the line with some double-sided tape clamps.
I'll update the original post with these ideas. Hopefully the next person can document it.
Oh, could you please delete your triple posts. Thanks!
Looks like my line 23 is shot so Iím ordering extended version. I swear I read somewhere to replace 23 and 24 together but canít find that again. Thoughts on this?
Iím really thinking of running it along the back seat like the posts above pointed out or in the forward edge of the storeage area. Iíll document with pictures which way I go. Any reason I couldnít run 23 and 24 both through one of these methods???
jman103099 is offline   Reply With Quote
Old 01-13-2018, 02:39 PM   #145
taylor192
My Ride: 2003.5 M3
No need to replace both of you buy a single line from Top Hydraulics. The only reason to replaced both is if you buy the OEM lines which are sold as a pair.
Looking forward to someone trying the routing along the forward edge of the storage compartment... Although it doesn't save that much effort, most of the steps are still required.
Sent from my [device_name] using E46Fanatics mobile app
Old 01-13-2018, 02:49 PM   #146
jman103099
I just replaced my line 23 with the extended version. I ordered line 24 with it but didn't replace as only 23 was leaking at the bend.
I didn't remove 23, rather plugged the ends and left where it was basically. I removed everything in the back and in the trunk in order to determine the best way to run the line (without going through the roof). Running it along the back seat would have worked (like someone else posted). Instead I opted for running it along the bottom lowest points possible in the storage area (against the wall/side of the back seat). I taped it down. I went this route because I could periodically check on it when the top goes up or down and it seemed to provide a route away from the hinge parts.
I had no idea how I was going to run that line through the roof - it looked harder than it might actually be, BUT running it through the top storage area was VERY easy. The hardest thing was playing with it to make sure it wasn't landing in an area around the hinges that would pinch it.
2 hours to disassemble everything (again I did way more than needed) and 3 hours to run the line and refill the pump with the help of my wife with an hour of reinstall and clean up. Removing the clip on the passenger side that holds line 23 was a pain! Found out moving the top back just about 1/3 of the way provided great access. Of course didn't think of this until trying for about 30 min.
As a side note, I don't see how it would be possible to do line 24 without removing/lifting the top. Hopefully I won't have to find out.
Big thanks to everyone who helped with these threads!
2018 X1 (9/17 - present)
2004 330CiC (8/15 - present)
2011 X3 28i (1/12 - present)
2011 328i (5/11 - 7/17)
2009 MINI Cooper (4/09 - 5/11)
2006 X3 (03/07 - 1/12)
1995 325i (05/06 - 3/09)
1985 325e (08/00 - 12/04)
Old 04-14-2018, 11:22 AM   #147
Patryk81
My Ride: 2004 BMW 330Ci
Need help. Read through the forum and I'm lost. I have 2004 bmw 330ci convertible. Here are my issues and problems. First off thank you the the members and great write ups. I was able to reinforce laches so my roof now locks and closes at the windshield. But I have 10 more problems.
When I press open button roof goes up maybe two inches and stops. Rear part of windshield is trying to move but it quits and red light start blinking. Then I manually help raise the back windshield and convertible storage lid starts lifting but it won't go all the way up. I took four nuts holding cover to hitches and hitches with out cover go up no problem. ( there is slight delay between right hitch going up). Then the roof goes down to the compartment and hitches are going down.
To raise roof it's same thing like opening only in reverse. Roof at the windshield goes up maybe an inch and error (So I manually lift it). Storage department cover tries to go up but it want all the way up. With out plastic cover hitches are going up all the way. Then rear windshield goes down but it self and rest of the roof is closing and latching in place.
Also I'm attaching errors. First picture with code 11 happened today. Second one yesterday and the third on yes you guess it 2 days ago.
Any help would help. Thanks guys and gals.
ID:	739540Click image for larger version
ID:	739542Click image for larger version
Patryk81 is offline   Reply With Quote
Old 04-23-2018, 09:04 AM   #148
cabinetbob
My Ride: 2004 330c1
pump vs valve block
After reading so very much to read!! Symptoms of top moving slowly to requiring intervention. Mine has done both and now requires manual intervention The valve block symptom says when going bad the top moves slowly. When the hydraulic pump is going bad the top normally stops half way and requires assistance. That valve cost almost the same as the pump. Is there any way of knowing for sure which is the real problem?
cabinetbob is offline   Reply With Quote
Old 04-23-2018, 07:21 PM   #149
taylor192
My Ride: 2003.5 M3
Start with the pump, it is far more likely to be the problem. Even if it's not, since these cars are >12yo your pump is probably due soon anyways.
Old 07-15-2018, 02:43 PM   #150
cabinetbob
My Ride: 2004 330c1
The Pentosin CHF-11S can be bought at a Napa store for about $21. Even though it says power steering fluid, it s the one that is mentioned on here. Also, the guys at napa said its the same fluid for the hydraulic pump. So, anyway, was wondering if there is a special way of draining the fluid and replacing it. I dont want to go crazy and disassemble the whole pump.
Old 04-22-2019, 08:41 PM   #151
330CI-CONV
My Ride: 2004 330CI convertib
Taylor192... this is one great post and replies. Thanks for your help. Big gap between last post and this one, but will try anyway.
Mine is a 2004 330CI vert. Roof starts ok as it disengages at front. Stops a few inches from the windshield, but pump keeps humming with increasing loudness until it stops, red light blinking. At this point I can complete the storing of roof manually, but to latch the back cover, I press button for a few more seconds until light stops blinking. I sense pump has not enough force. No leaks detected anywhere, fluid level ok.
So, question is... is it the pump? Does sending it to Top Hydraulics for rebuilding internals likely fix problem?
Could it be electric... a cable... the pump relay?
Your help would be greatly appreciated.
Thanks in advance.
330CI-CONV is offline   Reply With Quote
Old 04-22-2019, 08:42 PM   #152
330CI-CONV
Also thanks to all others that have contributed too.
Old 04-26-2019, 06:10 PM   #153
330CI-CONV
Checked hydraulic fluid level and it is over the normal mark, but I have never topped off. Canít see any leaks anywhere.
Help is appreciated.
Sent from my iPad using E46Fanatics
Old 07-12-2019, 08:47 PM   #154
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
this has to be the best DIY thread I have ever seen on this forum. Mind blown
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
