Cooling Part Question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 07-21-2019, 09:28 PM   #1
Zyaltr
My Ride: 03-330cic,14-535 IX
I was replacing my expansion tank, the bottom fitting where the tank clips on has a spring loaded check valve. Circled in the picture is how it is supposed to look. Mine was cracked and spring and plunger where loose. What is the actual fitting the expansion tank is connection to? It is not the radiator, the best guess it has to something with the Tranny cooler. I cannot find the actual part that this check valve resides in. Anyone??
I had to put it back together with out the check valve.
Zyaltr is offline   Reply With Quote
Old 07-22-2019, 12:04 AM   #2
Bidno
My Ride: 2002 325i
That's the thermostat for the transmission cooler. These often crack and need replacement with the expansion tank. Their role is to allow the transmission to warm faster in cold weather. Here's a diagram that illustrates. This thermostat is item #4. GL
P.S. In my opinion, you're should be okay without during summer but replace before cold weather. And if mucking around down there, replace orings including where tran cooler mounts seals to the radiator, item #3.
Bidno is offline   Reply With Quote
Old 07-22-2019, 07:21 AM   #3
Zyaltr
Thank you. Next project!
Sponsored Links
Advertisement
Old 07-22-2019, 10:58 AM   #4
Bidno
My Ride: 2002 325i
You're welcome. Enjoy the ride!
