DIY: Strengthen/Repair Windshield Latches - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 04-14-2016, 11:04 PM   #41
BranchTwenty1
BranchTwenty1's Avatar
My Ride: '04 330Ci Vert 6-Spd
This thread saved me... so thank you to everyone who has contributed here. It turned out my passenger side latch was broken clean in two. The driver's side was cracked and on it's way. I unfortunately didn't add the putty or glue (it ended up being a two-day deal and I didn't get a chance to get any), but the two bolt resolve was beyond helpful and it looks to be extremely solid now on both sides. Thank you, and thank you!!
BranchTwenty1 is offline   Reply With Quote
Old 04-15-2016, 08:09 AM   #42
Juhan
My Ride: 2002 325ci
It saved your wallet as well! Congrats!
Juhan is offline   Reply With Quote
Old 04-15-2016, 12:53 PM   #43
grubbab
My Ride: 330ci convertible
Has anyone replaced the broken plastic part in the latch? I bolted and epoxied mine as a short term solution, but will probably order the "VSR8-9 ROOF LOCK LATCH Parts LEFT and RIGHT for BMW E46 Convertible" available on Ebay for $209 to keep around for when my rigged repair fails. VSR8-9 ROOF search eBay for "LOCK LATCH Parts LEFT and RIGHT For BMW E46 Convertible." If anyone installs these, I'd love a tutorial and review.
grubbab is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-01-2016, 02:36 PM   #44
O'sideBMW-Dave
My Ride: BMW325ci convertible
Has anybody fabricated this part out of metal yet? I was able to do the mod on the drivers side but the passenger side is broke of in a manner that there is nothing to drill into.
O'sideBMW-Dave is offline   Reply With Quote
Old 07-20-2016, 08:33 PM   #45
nyredeye21
My Ride: 2003 E46 M3
Removing cover
I recommend doing step 7 and when trying to pry off the cover use a hook to pull down on the inside of the cover (part that the fabric attaches too) while also pulling down on the front of the cover (windshield side). I struggled with it for almost an hour but once I removed everything and used the hook it came off with ease
nyredeye21 is offline   Reply With Quote
Old 07-22-2016, 08:00 AM   #46
Juhan
My Ride: 2002 325ci
Do not loosen or remove the screws that the headliner is attached to or you will have unnecessary obstacles re-installing.
Old 08-05-2016, 08:54 AM   #47
atdapin
My Ride: 2005 325ci vert
Thank you for everyone's contribution on this thread.
Unfortunately, I saw this thread too late and mine were beyond repair. I ordered the through eBay brosautoparts.net $190 + $13 shipping. They arrived in 5 business days from Turkey via UPS and were as advertised. I had a local indy top/sunroof specialist do the install and all works perfectly.
atdapin is offline   Reply With Quote
Old 08-06-2016, 05:18 PM   #48
Juhan
My Ride: 2002 325ci
Well you should get about 10 years of use from them depending on how much you lower your top? Juhaus6 @ Ebay is a good seller also.
Old 08-14-2016, 10:50 AM   #49
Derekwh
My Ride: '01 330cic & '86 E24
Will the cracking of the pieces affect the action of the elbow latches? I seem to get an occasional hang up where these latches are. The top action will be fine until the top is about to make its final move into the storage compartment but will stop, the pump is running and trying to move but this joint seems locked. This doesn't always happen. I haven't opened it up yet to see what the latch mechanism looks like.
Derekwh is offline   Reply With Quote
Old 08-17-2016, 01:42 PM   #50
Juhan
My Ride: 2002 325ci
I doubt its affecting that . I could be wrong but the only thing that I know those latches affect is your over head latch release & lock system.
Old 08-30-2016, 08:51 PM   #51
dredlokbwoi
My Ride: 2001 bmw 525ci
YEARS later and this post is still saving money. Thanks to the writer for this one!!
dredlokbwoi is offline   Reply With Quote
Old 09-16-2016, 09:57 PM   #52
HeatGun
Hi guys,
I am glad I found this forum!
I have 2006 325ci with 101k miles on and convertible just stopped closing, please see attached video (Youtube) and photos,
Do you guys think it is the common latch issue or wiring as well?
One last question, I see this thread started a bit over 2 years ago and how is your top doing so far? Has anyone experienced same problem after repairing it?
Thank you.
Video 1
Video 2
_nr_
ID:	641195   Click image for larger version
HeatGun is offline   Reply With Quote
Old 09-18-2016, 11:32 AM   #53
mattman928
My Ride: e46 M3
V
Looks like the latch issue. You can tell by looking at the last elbow before the front latches. There is a "u" fitting the is pushed into place by a piston connected to the front latch
mattman928 is offline   Reply With Quote
Old 09-18-2016, 12:59 PM   #54
atdapin
That looks exactly like the latch issue. I am only a couple of months into my repair but so far the aftermarket parts are working well.
Old 09-18-2016, 11:28 PM   #55
HeatGun
Originally Posted by HeatGun View Post
Hi guys,
Thank you.
This is how my repair is going so far, I used Loctite Plastic Epoxy as this one was the only one available at Home Depot.
On right latch I had to use three washers, somehow screw was slightly high with two washer, left one was OK with two. I will install these on Tuesday
FYI to DIYers, my battery died while it was parked top open in garage.
Name:	Photo Sep 18, 3 30 59 PM.jpg
ID:	641319   Click image for larger version
Name:	Photo Sep 18, 3 30 55 PM.jpg
ID:	641320   Click image for larger version
Name:	Photo Sep 18, 3 30 52 PM.jpg
Old 09-19-2016, 01:12 AM   #56
taylor192
My Ride: 2003.5 M3
Good job, nice repair!
I'm also interested in how well the screws plus epoxy solution holds up. So far no-one has reported issues post repair.
Old 09-19-2016, 05:57 AM   #57
mattman928
My Ride: e46 M3
Thanks for sharing! I took my latch out yesterday and it is pretty damaged. I am going to try to super glue all the part back together and then do the repair. I am also going to completely disassemble the latch mechanism to clean and relubricate everything. As I slide the parts, I can see why they failed from the old lubricant becoming contaminated with dust
Old 09-19-2016, 06:34 PM   #58
HeatGun
My notes so far; (I havent put it back together)
- Your battery may drain, be aware
- Get extra Epoxy, I had to buy second one
- Epoxy I used require 24 hours for complete dry, be-prepared to leave your parts out for a day or two
- Get extra washer, I had to use total of 10
- Get extra super-glue
- Sandpaper I used was 120 grit (home depot didnt have 150)
- Use airspray to blow broken pieces and plastics leftover from drilling
- You will not drill through a metal, so ANY type drill bit is OK, pilot hole is a must!
- Cover your eyes with goggles, I was about to damage my eyes while drilling that plastic
Old 09-20-2016, 03:52 PM   #59
HeatGun
IGNORE QUESTION BELOW, somehow car has adjusted itself and now everything works perfect! Thank you so much everyone specially taylor192
Repair is done, top is working as it should now I think I have a little issue due drained battery,
- Before, when I hit top close button windows used to close all the way, now rear small windows close only, I have to close front ones manually
- Front windows were all automatic meaning I used to pull button one time and they used to close all the way, now I have to hold my finger until windows are closed
Any idea? how can I configure it back to way it was?
Thank you
Old 01-27-2017, 03:43 PM   #60
Tonys_e46_vert
My Ride: 02 330ci Convertible
In case Anyone was curious, this can be completed on the car. I just did. Drivers side was completely broken while passenger side was cracked in half but still worked , but it wouldn't last much longer. Did this repair and it works great. Thanks for such a detailed string.
Tonys_e46_vert is offline   Reply With Quote
