Hello to everyone in the community!
Just browsing around, trying to find out a solution to some concerns and issues with water leaking into the vehicle and I couldn't help to notice that there aren't many posts regarding water leaks and the drains on a E46 convertible.
It would be great if you could direct me to any post that I may have missed regarding the above.
Alternatively, my issue lays below.
Recently, I have noticed a lot of water in the trunk, leaking from the right side of it.
Later on, I also found about 3-4 liters of water below the batter in the trunk, which I drained successfully.
What I believe is that my drains might be clogged.
The first question is if anyone has a picture on where the drain holes are located.
I know these can be found as soon as we lift the rear hood compartment and under the latches and hinges, but I can't really access them unless I see them once. Otherwise, I need to remove the whole hood cover, which I would love to avoid doing.
Secondly, has anyone ever seen or have a full guide on the drain holes as well as which ones need to be cleaned regularly and how to?
Any help would be much appreciated!
