DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV? - Page 10 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Mobile Electronics Forum
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average. Display Modes
Old 02-08-2014, 12:44 AM   #181
headlock
My Ride: E46 M3
^ correct
2002 M3 - no navigation but i do have 16:9 TV.
is there a way around this without nav? I *think* that at least one of those 2 cables is the antenna, possibly both.
The blue harness doesn't quite have the same options to wire into as the white one
headlock is offline   Reply With Quote
Old 02-08-2014, 02:07 AM   #182
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Use another plug just to get the wires onto the pins. The aerial is actually the 2 coax looking plugs.
E46 Coupe is offline   Reply With Quote
Old 02-08-2014, 02:10 AM   #183
E46 Coupe
E46 Coupe's Avatar
Use anything like that you can find. It's a pita as you'll likely need to pull the unit out to plug into the correct pins. It's really the easiest option besides having a wrecker or the like cutting out the plug and loom for you.
Sponsored Links
Advertisement
Old 02-08-2014, 02:12 AM   #184
PeteAU
My Ride: 330i
Couple guys have this problem of the missing white plug. It's a bit of a nuisance, but shouldn't be a show stopper.
You can still insert pin 17 into the blue plug, that just leaves two more wires.
The pins out of the white plug should be visible, it's just a matter of accessing two of them.
It might be worth a look through Jaycar or Altronics to see if they have something that'll fit into it.
Here's an image of the BMW style housing, except the TV plug is 2 x 10pins.
Maybe even a dupont connector (e.g. old CD ROM audio wire) could do the trick. You only need to access pin 13 and 14.
PeteAU is offline   Reply With Quote
Old 02-08-2014, 02:12 AM   #185
headlock
My Ride: E46 M3
ah i see, that's easy enough.
i had it in my head that the TV unit was being disconnected.
thanks guys, i'll give that a crack.
Old 02-08-2014, 02:13 AM   #186
E46 Coupe
E46 Coupe's Avatar
You have a "rare" M3 btw. No hifi audio and nav. Is it an import?
Old 02-08-2014, 02:23 AM   #187
headlock
My Ride: E46 M3
no definitely locally delivered, has books all the way back to purchase at Adelaide BMW.
has harmon kardon etc. - everything except nav :/
Old 02-08-2014, 04:40 AM   #188
E46 Coupe
E46 Coupe's Avatar
Ahh ok. I had thought the audio comes from the white plug to the amp. Maybe the white plug is all nav.
Old 02-08-2014, 05:06 AM   #189
headlock
My Ride: E46 M3
looks that way, nav and reverse camera.
got it working - well video anyway. still no audio apart from some interference somewhere and it seems to freeze or stop getting inputs. It will work for a bit - accepting commands from the head unit - and then stop, usually when you try to open a folder. It's either freezing or just stops understanding whats coming down the line for a minute. Comes good for a bit and then it'll drop out again. Took it back out and tested, the audio from the Pi's line out is ok. I think i've either done a bodgy solder or two on the 6 pin connector to the cd changer, or i've stuffed something else up somewhere. tomorrows problem.
just to confirm, you definitely dont need any of these other files in the pibus-20140124.zip file?
Old 02-08-2014, 02:56 PM   #190
E46 Coupe
E46 Coupe's Avatar
Nope
Old 02-08-2014, 03:41 PM   #191
netgun
My Ride: 2008 E92 M3 Coupe
Originally Posted by E46 Coupe View Post
Nope
Look out, starting to get some penguin achievement stamps!
netgun is offline   Reply With Quote
Old 02-08-2014, 04:03 PM   #192
E46 Coupe
E46 Coupe's Avatar
Nope
Old 02-08-2014, 05:24 PM   #193
headlock
My Ride: E46 M3
so... what do all those files do then?
oh well i guess i can rule that out as the cause of my problems. spewing, i was hoping it was just going to be that i had missed a file or something.
Old 02-08-2014, 05:55 PM   #194
netgun
They're just the source code that when compiled produces that one file you're using now.
Old 02-08-2014, 07:12 PM   #195
PeteAU
My Ride: 330i
Try it with a keyboard in the USB port. If it still freezes up, then it's some kind of Pi problem, maybe a dodgy SD card.
Old 02-09-2014, 01:49 AM   #196
headlock
My Ride: E46 M3
fixed. it was something so dumb that i'm not even going to say it, except to say it was easily fixed lol.
works beautifully now, thanks everyone
might have to knock up a little enclosure for it.
Old 02-09-2014, 06:18 PM   #197
SKR7
My Ride: E46 MY04.5 SMG M3
Mine is exactly the same. AND was originally sold by BMW Adelaide too.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 02-09-2014, 06:35 PM   #198
PeteAU
My Ride: 330i
Adelaide has only 3-4 roads, you don't need Nav
Old 02-09-2014, 07:08 PM   #199
E46 Coupe
E46 Coupe's Avatar
Old 02-09-2014, 11:09 PM   #200
SKR7
you've got to ask why you'd select the option and pay for an analogue TV receiver and NOT a GPS. In 2005 no less. When did they start advertising the turnoff of analogue TV, 1985?...
///M
2004 E46 M3
