DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV? - Page 99 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Mobile Electronics Forum
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average. Display Modes
Old 07-15-2019, 04:43 AM   #1961
miikew
My Ride: X3 E83
Great skin, thnx a lot
about addon i still dont know how to configure it with pibus, can i try it on libreelec 9.02 ? can i simply kill pibus and start your ibuscomm ?
miikew is offline   Reply With Quote
Old 07-15-2019, 05:30 AM   #1962
PeteAU
My Ride: 330i
Originally Posted by vitalic View Post
Just to keep you up to date. Today i finally managed to get my copied RGBS to HDMI converter to work.
I desoldered all parts from oem converter, made a 1:1 pcb copy, ordered my pcb, resoldered all parts on my copied pcb.
Killed round about 5 oem pcb, while desoldering too hot, or bad resoldering.
In the pic the upper one is oem the lower one is my copy.
This is a very important step, as i will copy this pcb design into my big pcb.
Now the same procedure for the AV to HDMI converter...
Looks amazing, but I'm a little confused. Don't you want HDMI in (from pi) to RGsB out (to BMW monitor)?
PeteAU is offline   Reply With Quote
Old 07-15-2019, 10:07 AM   #1963
vitalic
My Ride: E38
No, i replace the oem rgbs display with a HDMI touch display.
That's why i convert rgbs from oem to HDMI. And also rearcam AV to HDMI. Pi delivers HDMI...
Then i have a 2 stage HDMI switch to choose between PI and OEM input in first stage and in second stage i choose between rearcam and stage 1 result.
vitalic is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-16-2019, 03:01 PM   #1964
harryberlin
My Ride: E39 Touring
yes should work on LE.
harryberlin is offline   Reply With Quote
Old 08-29-2019, 05:18 PM   #1965
traco
My Ride: BMW 320dA
my bm54 broke down and when I put the new one, the bass and treble settings sounds very bad, how can I change them? when I press tone I see 0.5sg the tone screen but it returns me to pibus so I can't modify it, any trick?
traco is offline   Reply With Quote
Old 09-12-2019, 03:15 PM   #1966
vitalic
My Ride: E38
So here are some pics of the new all in one PCB. It offers a 2 stage HDMI switch, RGBs to HDMI converter, AV to HDMI converter, 5V 5A power supply, Hifiberry DAC for sound out, USB soundcard for microphone in, IBUS communication, 4x USB 2.0 Hub powered (2 internal used for USB soundcard and one for USB FM/DAB dongle), soundfilter against alternator noise.
The both oem connectors are from an old tv module, they can't be bought...
The white one needs some repinning, the blue one stays oem.
Will start soldering after i finished my other project, bike to e-bike...
ID:	783813   Click image for larger version
ID:	783815   Click image for larger version
ID:	783817   Click image for larger version
Old 09-12-2019, 03:20 PM   #1967
vitalic
My Ride: E38
As Addition to the main PCB i designed 3 more PCB.
First is an adapter for the Pi 4 micro HDMI to HDMI. Second and third are designed to connect HDMI to flatcable and Pi USB out to flatcable.
Unfortunatly i made a mistake when designing the micro HDMI. Right now everything fits, but signal comes from HDMI1 instead of HDMI0.
I already asked pi foundation if it was possible to set default out to HDMI1 instead of HDMI0. Hope they will answer me...
ID:	783821   Click image for larger version
Old 11-27-2019, 11:54 AM   #1968
Baddabing
My Ride: E46 330 CI
Wow - incredible! Any more progress, or is it all eBike?!
Baddabing is offline   Reply With Quote
Old 11-27-2019, 11:59 AM   #1969
vitalic
My Ride: E38
Ebike is finished.
The last version caused HDMI interferences as i did not read HDMI design guidelines.
New version is in progress at PCB producer.
Hope the prototypes will come soon.
Old 11-27-2019, 03:20 PM   #1970
Baddabing
My Ride: E46 330 CI
Ebike is finished.
Well done on the eBike.
I'm very interested in your prototype. Thanks
Old 12-16-2019, 02:56 PM   #1971
vitalic
My Ride: E38
Has anybody ever tried to get pibus working in Pi4? Can't get pibus to blink and to communicate. Guess it has got something to do with Raspbian stretch and GPIO handling.
Old 12-16-2019, 03:24 PM   #1972
harryberlin
got pi4 with libreelec working with my ibus shield.
i think, pibus should working too.
Old 12-16-2019, 03:59 PM   #1973
vitalic
My Ride: E38
can u post the content of your cmdline.txt and config.txt please?
Old 12-16-2019, 04:13 PM   #1974
harryberlin
you can get the image from here:
https://drive.google.com/file/d/11Ys...w?usp=drivesdk
you must change the addon settings to pibus I/O Board and do a reboot.
in some cases you must update the raspberry firmware to get tv composite working. one point, if tv out is enabled in config.txt you don't get a signal on hdmi.
Old 12-17-2019, 01:31 AM   #1975
PeteAU
My Ride: 330i
In the old days you needed: dtoverlay=pi3-miniuart-bt in config.txt.
Let me know if pi4-miniuart-bt works and I'll add it to the install script.
Old 12-17-2019, 02:54 AM   #1976
vitalic
My Ride: E38
@PeteAU true I already added pi3-miniuart... never checked if there is a pi4-miniuart...
In the cmdline.txt the the console=ttyAMA... has to be removed?
From researches in google i read that serial has to be configured via raspi-config to male serial work. When i disable console and enable serial port via raspi-config it writes uart-enable=1 (vor something like that) to config.txt .
No matter that i do, pibus led does not blink and ibus.txt just writes ibus idle.
Old 12-17-2019, 05:40 AM   #1977
harryberlin
later i can mount my sd-card and check the config.txt pi3-mini-uart is working on pi4. in documentation is the info, they will remove the pi3- prefix for pi4 and later.
Old 12-17-2019, 10:52 AM   #1978
harryberlin
this is my config.txt on Libreelec:
Code:
# SPDX-License-Identifier: GPL-2.0-or-later
# Copyright (C) 2009-2014 Stephan Raue ([email protected])
# Copyright (C) 2016-present Team LibreELEC (https://libreelec.tv)
# Bootloader configuration - config.txt
# Memory (System/GPU configuration )
# Default GPU memory split - at least 288M is needed for some 4k HEVC files
gpu_mem=320
gpu_mem_256=112
gpu_mem_512=160
gpu_mem_1024=320
# For overclocking and various other settings, see:
# https://www.raspberrypi.org/documentation/configuration/config-txt.md
# Set 'force_turbo=1' to disable dynamic overclocking and enable overclocking always.
force_turbo=1
# Force HDMI even if unplugged or powered off
# hdmi_force_hotplug=1
# Doesn't sent initial active source message.
# Avoids bringing CEC (enabled TV) out of standby and channel switch when
# rebooting.
hdmi_ignore_cec_init=1
# End of default configuration
# Include distribution specific config file if it exists.
[all]
include distroconfig.txt
disable_overscan=1
# Disable the PWR LED.
#dtparam=pwr_led_trigger=none
#dtparam=pwr_led_activelow=off
# Disable Rainbow splash
disable_splash=1
usb_max_current=1
force_turbo=1
sdtv_aspect=3
# Bluetooth
#dtoverlay=pi3-disable-bt
# for AVR-IBus
#dtoverlay=hifiberry-dac
dtparam=audio=on
# for Pi4
enable_tvout=1
here you can get the basic LE image:
https://libreelec.tv/raspberry-pi-4/
Old 12-17-2019, 11:14 AM   #1979
vitalic
My Ride: E38
Thx harry, do you also have the output of cmdline.txt?
Old 12-17-2019, 11:18 AM   #1980
harryberlin
@PeteAU
this is the pibus logfile from pi4:
Code:
000000.789 #startup bt=0 cam=1 anc=1 cdci=0 gpio=17 idle=300 hwv=4 in=9 hnp=0 rop=0 [Oct 26 2017]
000002.716 #send len=5 ******a003800122
000002.717 #send len=5 ******6803c001aa
000002.718 #send len=5 ******6803a001ca
000002.719 #send len=5 ******e703801074
000002.745 #service_queue(): ibus/gpio busy - waiting
000002.795 #service_queue(): ibus/gpio busy - waiting
000002.845 #service_queue(): ibus/gpio busy - waiting
000002.895 #service_queue(): ibus/gpio busy - waiting
000002.920 #send len=5 ******e703801074
000002.945 #service_queue(): ibus/gpio busy - waiting
000002.995 #service_queue(): ibus/gpio busy - waiting
000003.045 #service_queue(): ibus/gpio busy - waiting
000003.095 #service_queue(): ibus/gpio busy - waiting
000003.121 #send len=5 ******e703801074
000003.145 #service_queue(): ibus/gpio busy - waiting
000003.195 #service_queue(): ibus/gpio busy - waiting
000003.245 #service_queue(): ibus/gpio busy - waiting
000003.295 #service_queue(): ibus/gpio busy - waiting
000003.322 #send len=5 ******e703801074
000003.345 #service_queue(): ibus/gpio busy - waiting
000003.395 #service_queue(): ibus/gpio busy - waiting
000003.445 #service_queue(): ibus/gpio busy - waiting
000003.495 #service_queue(): ibus/gpio busy - waiting
000003.523 #send len=5 ******e703801074
000003.546 #service_queue(): ibus/gpio busy - waiting
000003.596 #service_queue(): ibus/gpio busy - waiting
000003.646 #service_queue(): ibus/gpio busy - waiting
000003.696 #service_queue(): ibus/gpio busy - waiting
000003.725 #send len=7 ******e7058041010123
000003.746 #service_queue(): ibus/gpio busy - waiting
000003.796 #service_queue(): ibus/gpio busy - waiting
000003.846 #service_queue(): ibus/gpio busy - waiting
000003.896 #service_queue(): ibus/gpio busy - waiting
000003.928 #send len=7 ******e7058041010123
000003.947 #service_queue(): ibus/gpio busy - waiting
000003.997 #service_queue(): ibus/gpio busy - waiting
000004.047 #service_queue(): ibus/gpio busy - waiting
000004.097 #service_queue(): ibus/gpio busy - waiting
000004.130 #send len=7 ******e7058041010123
000004.147 #service_queue(): ibus/gpio busy - waiting
000004.197 #service_queue(): ibus/gpio busy - waiting
000004.247 #service_queue(): ibus/gpio busy - waiting
000004.297 #service_queue(): ibus/gpio busy - waiting
000004.331 #send len=7 ******e7058041010123
000004.347 #service_queue(): ibus/gpio busy - waiting
000004.398 #service_queue(): ibus/gpio busy - waiting
000004.448 #service_queue(): ibus/gpio busy - waiting
000004.498 #service_queue(): ibus/gpio busy - waiting
000004.533 #send len=7 ******e7058041010123
000004.548 #service_queue(): ibus/gpio busy - waiting
000004.598 #service_queue(): ibus/gpio busy - waiting
000004.648 #service_queue(): ibus/gpio busy - waiting
000004.698 #service_queue(): ibus/gpio busy - waiting
000004.740 #send len=6 ******6804f04aff29
000004.740 #send len=5 ******bf030079c5
000004.749 #service_queue(): ibus/gpio busy - waiting
000004.799 #service_queue(): ibus/gpio busy - waiting
000004.849 #service_queue(): ibus/gpio busy - waiting
000004.899 #service_queue(): ibus/gpio busy - waiting
000004.942 #send len=5 ******bf030079c5
000004.949 #service_queue(): ibus/gpio busy - waiting
000004.999 #service_queue(): ibus/gpio busy - waiting
000005.049 #service_queue(): ibus/gpio busy - waiting
000005.099 #service_queue(): ibus/gpio busy - waiting
000005.143 #send len=5 ******bf030079c5
000005.149 #service_queue(): ibus/gpio busy - waiting
000005.199 #service_queue(): ibus/gpio busy - waiting
000005.249 #service_queue(): ibus/gpio busy - waiting
000005.299 #service_queue(): ibus/gpio busy - waiting
000005.344 #send len=5 ******bf030079c5
000005.349 #service_queue(): ibus/gpio busy - waiting
000005.399 #service_queue(): ibus/gpio busy - waiting
000005.449 #service_queue(): ibus/gpio busy - waiting
000005.499 #service_queue(): ibus/gpio busy - waiting
000005.545 #send len=5 ******bf030079c5
000005.549 #service_queue(): ibus/gpio busy - waiting
000005.599 #service_queue(): ibus/gpio busy - waiting
000005.649 #service_queue(): ibus/gpio busy - waiting
000005.699 #service_queue(): ibus/gpio busy - waiting
000005.746 #send len=5 ******bf03d05a36
000005.749 #service_queue(): ibus/gpio busy - waiting
000005.799 #service_queue(): ibus/gpio busy - waiting
000005.849 #service_queue(): ibus/gpio busy - waiting
000005.899 #service_queue(): ibus/gpio busy - waiting
000005.947 #send len=5 ******bf03d05d31
000005.949 #service_queue(): ibus/gpio busy - waiting
000005.999 #service_queue(): ibus/gpio busy - waiting
000006.049 #service_queue(): ibus/gpio busy - waiting
000006.099 #service_queue(): ibus/gpio busy - waiting
000006.147 #send len=5 ******3f03d00be7
000006.149 #service_queue(): ibus/gpio busy - waiting
000006.199 #service_queue(): ibus/gpio busy - waiting
000006.250 #service_queue(): ibus/gpio busy - waiting
000006.300 #service_queue(): ibus/gpio busy - waiting
000006.348 #send len=5 ******bf03d05a36
000006.350 #service_queue(): ibus/gpio busy - waiting
000006.400 #service_queue(): ibus/gpio busy - waiting
000006.450 #service_queue(): ibus/gpio busy - waiting
000006.500 #service_queue(): ibus/gpio busy - waiting
000006.549 #send len=5 ******bf03d05d31
000006.550 #service_queue(): ibus/gpio busy - waiting
000006.600 #service_queue(): ibus/gpio busy - waiting
000006.650 #service_queue(): ibus/gpio busy - waiting
000006.700 #service_queue(): ibus/gpio busy - waiting
000006.750 #send len=5 ******3f03d00be7
000006.750 #service_queue(): ibus/gpio busy - waiting
000006.800 #service_queue(): ibus/gpio busy - waiting
000006.850 #service_queue(): ibus/gpio busy - waiting
000006.900 #service_queue(): ibus/gpio busy - waiting
000006.950 #service_queue(): ibus/gpio busy - waiting
000006.951 #send len=5 ******bf03d05a36
000007.000 #service_queue(): ibus/gpio busy - waiting
000007.050 #service_queue(): ibus/gpio busy - waiting
000007.100 #service_queue(): ibus/gpio busy - waiting
000007.150 #service_queue(): ibus/gpio busy - waiting
000007.152 #send len=5 ******bf03d05d31
000007.200 #service_queue(): ibus/gpio busy - waiting
000007.250 #service_queue(): ibus/gpio busy - waiting
000007.300 #service_queue(): ibus/gpio busy - waiting
000007.350 #service_queue(): ibus/gpio busy - waiting
000007.352 #send len=5 ******3f03d00be7
000007.400 #service_queue(): ibus/gpio busy - waiting
000007.451 #service_queue(): ibus/gpio busy - waiting
000007.501 #service_queue(): ibus/gpio busy - waiting
000007.551 #service_queue(): ibus/gpio busy - waiting
000007.553 #send len=5 ******bf03d05a36
000007.601 #service_queue(): ibus/gpio busy - waiting
000007.652 #service_queue(): ibus/gpio busy - waiting
000007.702 #service_queue(): ibus/gpio busy - waiting
000007.752 #service_queue(): ibus/gpio busy - waiting
000007.754 #send len=5 ******bf03d05d31
000007.802 #service_queue(): ibus/gpio busy - waiting
000007.852 #service_queue(): ibus/gpio busy - waiting
000007.903 #service_queue(): ibus/gpio busy - waiting
000007.952 #service_queue(): ibus/gpio busy - waiting
000007.955 #send len=5 ******3f03d00be7
000008.002 #service_queue(): ibus/gpio busy - waiting
000008.052 #service_queue(): ibus/gpio busy - waiting
000008.102 #service_queue(): ibus/gpio busy - waiting
000008.152 #service_queue(): ibus/gpio busy - waiting
000008.156 #send len=5 ******bf03d05a36
000008.202 #service_queue(): ibus/gpio busy - waiting
000008.252 #service_queue(): ibus/gpio busy - waiting
000008.302 #service_queue(): ibus/gpio busy - waiting
000008.352 #service_queue(): ibus/gpio busy - waiting
000008.357 #send len=5 ******bf03d05d31
000008.402 #service_queue(): ibus/gpio busy - waiting
000008.452 #service_queue(): ibus/gpio busy - waiting
000008.502 #service_queue(): ibus/gpio busy - waiting
000008.552 #service_queue(): ibus/gpio busy - waiting
000008.558 #send len=5 ******3f03d00be7
000008.602 #service_queue(): ibus/gpio busy - waiting
000008.652 #service_queue(): ibus/gpio busy - waiting
000008.702 #service_queue(): ibus/gpio busy - waiting
000008.752 #service_queue(): ibus/gpio busy - waiting
000008.759 #send len=5 ******e703801276
000008.760 #send len=5 ******3b038014ac
000008.789 #ibus idle
000008.802 #service_queue(): ibus/gpio busy - waiting
000008.852 #service_queue(): ibus/gpio busy - waiting
000008.902 #service_queue(): ibus/gpio busy - waiting
000008.953 #service_queue(): ibus/gpio busy - waiting
000008.961 #send len=5 ******e703801276
000008.962 #send len=5 ******3b038014ac
000009.002 #service_queue(): ibus/gpio busy - waiting
000009.052 #service_queue(): ibus/gpio busy - waiting
000009.102 #service_queue(): ibus/gpio busy - waiting
000009.152 #service_queue(): ibus/gpio busy - waiting
000009.163 #send len=5 ******e703801276
000009.164 #send len=5 ******3b038014ac
000009.202 #service_queue(): ibus/gpio busy - waiting
000009.252 #service_queue(): ibus/gpio busy - waiting
000009.302 #service_queue(): ibus/gpio busy - waiting
000009.352 #service_queue(): ibus/gpio busy - waiting
000009.365 #send len=5 ******e703801276
000009.365 #send len=5 ******3b038014ac
000009.402 #service_queue(): ibus/gpio busy - waiting
000009.452 #service_queue(): ibus/gpio busy - waiting
000009.502 #service_queue(): ibus/gpio busy - waiting
000009.552 #service_queue(): ibus/gpio busy - waiting
000009.567 #send len=5 ******e703801276
000009.567 #send len=5 ******3b038014ac
000009.602 #service_queue(): ibus/gpio busy - waiting
000009.652 #service_queue(): ibus/gpio busy - waiting
000009.703 #service_queue(): ibus/gpio busy - waiting
000009.753 #service_queue(): ibus/gpio busy - waiting
000009.768 #send len=8 ******3006447300008081
000009.803 #service_queue(): ibus/gpio busy - waiting
000009.853 #service_queue(): ibus/gpio busy - waiting
000009.903 #service_queue(): ibus/gpio busy - waiting
000009.953 #service_queue(): ibus/gpio busy - waiting
000010.003 #service_queue(): ibus/gpio busy - waiting
000010.053 #service_queue(): ibus/gpio busy - waiting
000010.103 #service_queue(): ibus/gpio busy - waiting
000010.153 #service_queue(): ibus/gpio busy - waiting
000010.203 #service_queue(): ibus/gpio busy - waiting
000010.254 #service_queue(): ibus/gpio busy - waiting
000010.304 #service_queue(): ibus/gpio busy - waiting
000010.354 #service_queue(): ibus/gpio busy - waiting
000010.404 #service_queue(): ibus/gpio busy - waiting
000010.454 #service_queue(): ibus/gpio busy - waiting
000010.504 #service_queue(): ibus/gpio busy - waiting
000010.554 #service_queue(): ibus/gpio busy - waiting
000010.604 #service_queue(): ibus/gpio busy - waiting
000010.654 #service_queue(): ibus/gpio busy - waiting
000010.704 #service_queue(): ibus/gpio busy - waiting
000010.755 #service_queue(): ibus/gpio busy - waiting
000010.805 #service_queue(): ibus/gpio busy - waiting
000010.855 #service_queue(): ibus/gpio busy - waiting
000010.905 #service_queue(): ibus/gpio busy - waiting
000010.955 #service_queue(): ibus/gpio busy - waiting
000011.005 #service_queue(): ibus/gpio busy - waiting
000011.055 #service_queue(): ibus/gpio busy - waiting
000011.105 #service_queue(): ibus/gpio busy - waiting
000011.155 #service_queue(): ibus/gpio busy - waiting
000011.205 #service_queue(): ibus/gpio busy - waiting
000011.256 #service_queue(): ibus/gpio busy - waiting
000011.306 #service_queue(): ibus/gpio busy - waiting
000011.356 #service_queue(): ibus/gpio busy - waiting
000011.406 #service_queue(): ibus/gpio busy - waiting
000011.456 #service_queue(): ibus/gpio busy - waiting
000011.506 #service_queue(): ibus/gpio busy - waiting
000011.556 #service_queue(): ibus/gpio busy - waiting
000011.606 #service_queue(): ibus/gpio busy - waiting
000011.656 #service_queue(): ibus/gpio busy - waiting
000011.707 #service_queue(): ibus/gpio busy - waiting
000011.757 #service_queue(): ibus/gpio busy - waiting
000011.807 #service_queue(): ibus/gpio busy - waiting
000011.857 #service_queue(): ibus/gpio busy - waiting
000011.907 #service_queue(): ibus/gpio busy - waiting
000011.957 #service_queue(): ibus/gpio busy - waiting
000012.007 #service_queue(): ibus/gpio busy - waiting
000012.057 #service_queue(): ibus/gpio busy - waiting
000012.107 #service_queue(): ibus/gpio busy - waiting
000012.158 #service_queue(): ibus/gpio busy - waiting
000012.208 #service_queue(): ibus/gpio busy - waiting
000012.258 #service_queue(): ibus/gpio busy - waiting
000012.308 #service_queue(): ibus/gpio busy - waiting
000012.358 #service_queue(): ibus/gpio busy - waiting
000012.408 #service_queue(): ibus/gpio busy - waiting
000012.458 #service_queue(): ibus/gpio busy - waiting
000012.508 #service_queue(): ibus/gpio busy - waiting
000012.558 #service_queue(): ibus/gpio busy - waiting
000012.609 #service_queue(): ibus/gpio busy - waiting
000012.659 #service_queue(): ibus/gpio busy - waiting
000012.709 #service_queue(): ibus/gpio busy - waiting
000012.759 #service_queue(): ibus/gpio busy - waiting
000012.809 #service_queue(): ibus/gpio busy - waiting
000012.859 #service_queue(): ibus/gpio busy - waiting
000012.909 #service_queue(): ibus/gpio busy - waiting
000012.959 #service_queue(): ibus/gpio busy - waiting
000013.010 #service_queue(): ibus/gpio busy - waiting
000013.060 #service_queue(): ibus/gpio busy - waiting
000013.110 #service_queue(): ibus/gpio busy - waiting
000013.160 #service_queue(): ibus/gpio busy - waiting
000013.210 #service_queue(): ibus/gpio busy - waiting
000013.260 #service_queue(): ibus/gpio busy - waiting
000013.310 #service_queue(): ibus/gpio busy - waiting
000013.360 #service_queue(): ibus/gpio busy - waiting
000013.410 #service_queue(): ibus/gpio busy - waiting
000013.461 #service_queue(): ibus/gpio busy - waiting
000013.511 #service_queue(): ibus/gpio busy - waiting
000013.561 #service_queue(): ibus/gpio busy - waiting
000013.611 #service_queue(): ibus/gpio busy - waiting
000013.661 #service_queue(): ibus/gpio busy - waiting
000013.711 #service_queue(): ibus/gpio busy - waiting
000013.761 #service_queue(): ibus/gpio busy - waiting
000013.811 #service_queue(): ibus/gpio busy - waiting
000013.861 #service_queue(): ibus/gpio busy - waiting
000013.911 #service_queue(): ibus/gpio busy - waiting
000013.961 #service_queue(): ibus/gpio busy - waiting
000014.011 #service_queue(): ibus/gpio busy - waiting
000014.061 #service_queue(): ibus/gpio busy - waiting
000014.111 #service_queue(): ibus/gpio busy - waiting
000014.161 #service_queue(): ibus/gpio busy - waiting
000014.211 #service_queue(): ibus/gpio busy - waiting
000014.261 #service_queue(): ibus/gpio busy - waiting
000014.311 #service_queue(): ibus/gpio busy - waiting
000014.362 #service_queue(): ibus/gpio busy - waiting
000014.412 #service_queue(): ibus/gpio busy - waiting
000014.462 #service_queue(): ibus/gpio busy - waiting
000014.512 #service_queue(): ibus/gpio busy - waiting
000014.562 #service_queue(): ibus/gpio busy - waiting
000014.612 #service_queue(): ibus/gpio busy - waiting
000014.662 #service_queue(): ibus/gpio busy - waiting
000014.712 #service_queue(): ibus/gpio busy - waiting
000014.762 #service_queue(): ibus/gpio busy - waiting
000014.813 #service_queue(): ibus/gpio busy - waiting
000014.862 #service_queue(): ibus/gpio busy - waiting
000014.912 #service_queue(): ibus/gpio busy - waiting
000014.962 #service_queue(): ibus/gpio busy - waiting
000015.012 #service_queue(): ibus/gpio busy - waiting
000015.062 #service_queue(): ibus/gpio busy - waiting
000015.112 #service_queue(): ibus/gpio busy - waiting
000015.162 #service_queue(): ibus/gpio busy - waiting
000015.212 #service_queue(): ibus/gpio busy - waiting
000015.263 #service_queue(): ibus/gpio busy - waiting
000015.313 #service_queue(): ibus/gpio busy - waiting
000015.363 #service_queue(): ibus/gpio busy - waiting
000015.413 #service_queue(): ibus/gpio busy - waiting
000015.463 #service_queue(): ibus/gpio busy - waiting
000015.513 #service_queue(): ibus/gpio busy - waiting
000015.563 #service_queue(): ibus/gpio busy - waiting
000015.613 #service_queue(): ibus/gpio busy - waiting
000015.663 #service_queue(): ibus/gpio busy - waiting
000015.713 #service_queue(): ibus/gpio busy - waiting
000015.764 #service_queue(): ibus/gpio busy - waiting
000015.814 #service_queue(): ibus/gpio busy - waiting
000015.864 #service_queue(): ibus/gpio busy - waiting
000015.914 #service_queue(): ibus/gpio busy - waiting
000015.964 #service_queue(): ibus/gpio busy - waiting
000016.014 #service_queue(): ibus/gpio busy - waiting
000016.064 #service_queue(): ibus/gpio busy - waiting
000016.114 #service_queue(): ibus/gpio busy - waiting
000016.164 #service_queue(): ibus/gpio busy - waiting
000016.215 #service_queue(): ibus/gpio busy - waiting
000016.265 #service_queue(): ibus/gpio busy - waiting
000016.315 #service_queue(): ibus/gpio busy - waiting
000016.365 #service_queue(): ibus/gpio busy - waiting
000016.415 #service_queue(): ibus/gpio busy - waiting
000016.465 #service_queue(): ibus/gpio busy - waiting
000016.515 #service_queue(): ibus/gpio busy - waiting
000016.565 #service_queue(): ibus/gpio busy - waiting
000016.615 #service_queue(): ibus/gpio busy - waiting
000016.665 #service_queue(): ibus/gpio busy - waiting
000016.716 #service_queue(): ibus/gpio busy - waiting
000016.766 #service_queue(): ibus/gpio busy - waiting
000016.816 #service_queue(): ibus/gpio busy - waiting
000016.866 #service_queue(): ibus/gpio busy - waiting
000016.916 #service_queue(): ibus/gpio busy - waiting
000016.966 #service_queue(): ibus/gpio busy - waiting
000017.016 #service_queue(): ibus/gpio busy - waiting
000017.066 #service_queue(): ibus/gpio busy - waiting
000017.117 #service_queue(): ibus/gpio busy - waiting
000017.167 #service_queue(): ibus/gpio busy - waiting
000017.217 #service_queue(): ibus/gpio busy - waiting
000017.267 #service_queue(): ibus/gpio busy - waiting
000017.317 #service_queue(): ibus/gpio busy - waiting
000017.367 #service_queue(): ibus/gpio busy - waiting
000017.417 #service_queue(): ibus/gpio busy - waiting
000017.467 #service_queue(): ibus/gpio busy - waiting
000017.517 #service_queue(): ibus/gpio busy - waiting
000017.567 #service_queue(): ibus/gpio busy - waiting
000017.617 #service_queue(): ibus/gpio busy - waiting
000017.668 #service_queue(): ibus/gpio busy - waiting
000017.718 #service_queue(): ibus/gpio busy - waiting
000017.768 #service_queue(): ibus/gpio busy - waiting
000017.818 #service_queue(): ibus/gpio busy - waiting
000017.868 #service_queue(): ibus/gpio busy - waiting
000017.918 #service_queue(): ibus/gpio busy - waiting
000017.968 #service_queue(): ibus/gpio busy - waiting
000018.018 #service_queue(): ibus/gpio busy - waiting
000018.069 #service_queue(): ibus/gpio busy - waiting
000018.118 #service_queue(): ibus/gpio busy - waiting
000018.168 #service_queue(): ibus/gpio busy - waiting
000018.218 #service_queue(): ibus/gpio busy - waiting
000018.268 #service_queue(): ibus/gpio busy - waiting
000018.318 #service_queue(): ibus/gpio busy - waiting
000018.368 #service_queue(): ibus/gpio busy - waiting
000018.418 #service_queue(): ibus/gpio busy - waiting
000018.468 #service_queue(): ibus/gpio busy - waiting
000018.518 #service_queue(): ibus/gpio busy - waiting
000018.568 #service_queue(): ibus/gpio busy - waiting
000018.619 #service_queue(): ibus/gpio busy - waiting
000018.669 #service_queue(): ibus/gpio busy - waiting
000018.719 #service_queue(): ibus/gpio busy - waiting
000018.769 #service_queue(): ibus/gpio busy - waiting
000018.819 #service_queue(): ibus/gpio busy - waiting
000018.869 #service_queue(): ibus/gpio busy - waiting
000018.919 #service_queue(): ibus/gpio busy - waiting
000018.969 #service_queue(): ibus/gpio busy - waiting
000019.019 #service_queue(): ibus/gpio busy - waiting
000019.070 #service_queue(): ibus/gpio busy - waiting
000019.120 #service_queue(): ibus/gpio busy - waiting
000019.170 #service_queue(): ibus/gpio busy - waiting
000019.220 #service_queue(): ibus/gpio busy - waiting
000019.270 #service_queue(): ibus/gpio busy - waiting
000019.320 #service_queue(): ibus/gpio busy - waiting
000019.370 #service_queue(): ibus/gpio busy - waiting
000019.420 #service_queue(): ibus/gpio busy - waiting
000019.470 #service_queue(): ibus/gpio busy - waiting
000019.520 #service_queue(): ibus/gpio busy - waiting
000019.570 #service_queue(): ibus/gpio busy - waiting
000019.620 #service_queue(): ibus/gpio busy - waiting
000019.670 #service_queue(): ibus/gpio busy - waiting
000019.720 #service_queue(): ibus/gpio busy - waiting
000019.770 #service_queue(): ibus/gpio busy - waiting
000019.820 #service_queue(): ibus/gpio busy - waiting
000019.870 #service_queue(): ibus/gpio busy - waiting
000019.920 #service_queue(): ibus/gpio busy - waiting
000019.970 #service_queue(): ibus/gpio busy - waiting
000020.020 #service_queue(): ibus/gpio busy - waiting
000020.071 #service_queue(): ibus/gpio busy - waiting
000020.121 #service_queue(): ibus/gpio busy - waiting
000020.171 #service_queue(): ibus/gpio busy - waiting
000020.221 #service_queue(): ibus/gpio busy - waiting
000020.271 #service_queue(): ibus/gpio busy - waiting
000020.321 #service_queue(): ibus/gpio busy - waiting
000020.371 #service_queue(): ibus/gpio busy - waiting
000020.421 #service_queue(): ibus/gpio busy - waiting
000020.471 #service_queue(): ibus/gpio busy - waiting
000020.521 #service_queue(): ibus/gpio busy - waiting
000020.572 #service_queue(): ibus/gpio busy - waiting
000020.622 #service_queue(): ibus/gpio busy - waiting
000020.672 #service_queue(): ibus/gpio busy - waiting
000020.722 #service_queue(): ibus/gpio busy - waiting
000020.772 #service_queue(): ibus/gpio busy - waiting
000020.822 #service_queue(): ibus/gpio busy - waiting
000020.872 #service_queue(): ibus/gpio busy - waiting
000020.922 #service_queue(): ibus/gpio busy - waiting
000020.972 #service_queue(): ibus/gpio busy - waiting
000021.023 #service_queue(): ibus/gpio busy - waiting
000021.073 #service_queue(): ibus/gpio busy - waiting
000021.123 #service_queue(): ibus/gpio busy - waiting
000021.173 #service_queue(): ibus/gpio busy - waiting
000021.223 #service_queue(): ibus/gpio busy - waiting
000021.273 #service_queue(): ibus/gpio busy - waiting
000021.323 #service_queue(): ibus/gpio busy - waiting
000021.373 #service_queue(): ibus/gpio busy - waiting
000021.423 #service_queue(): ibus/gpio busy - waiting
000021.473 #service_queue(): ibus/gpio busy - waiting
000021.523 #service_queue(): ibus/gpio busy - waiting
000021.574 #service_queue(): ibus/gpio busy - waiting
000021.624 #service_queue(): ibus/gpio busy - waiting
000021.674 #service_queue(): ibus/gpio busy - waiting
000021.724 #service_queue(): ibus/gpio busy - waiting
000021.774 #service_queue(): ibus/gpio busy - waiting
000021.824 #service_queue(): ibus/gpio busy - waiting
000021.874 #service_queue(): ibus/gpio busy - waiting
000021.924 #service_queue(): ibus/gpio busy - waiting
000021.975 #service_queue(): ibus/gpio busy - waiting
000022.025 #service_queue(): ibus/gpio busy - waiting
000022.075 #service_queue(): ibus/gpio busy - waiting
000022.125 #service_queue(): ibus/gpio busy - waiting
000022.175 #service_queue(): ibus/gpio busy - waiting
000022.225 #service_queue(): ibus/gpio busy - waiting
000022.275 #service_queue(): ibus/gpio busy - waiting
000022.325 #service_queue(): ibus/gpio busy - waiting
000022.375 #service_queue(): ibus/gpio busy - waiting
000022.425 #service_queue(): ibus/gpio busy - waiting
000022.476 #service_queue(): ibus/gpio busy - waiting
000022.526 #service_queue(): ibus/gpio busy - waiting
000022.576 #service_queue(): ibus/gpio busy - waiting
000022.626 #service_queue(): ibus/gpio busy - waiting
000022.676 #service_queue(): ibus/gpio busy - waiting
000022.726 #service_queue(): ibus/gpio busy - waiting
000022.776 #service_queue(): ibus/gpio busy - waiting
000022.826 #service_queue(): ibus/gpio busy - waiting
000022.876 #service_queue(): ibus/gpio busy - waiting
000022.927 #service_queue(): ibus/gpio busy - waiting
000022.977 #service_queue(): ibus/gpio busy - waiting
000023.027 #service_queue(): ibus/gpio busy - waiting
000023.077 #service_queue(): ibus/gpio busy - waiting
000023.127 #service_queue(): ibus/gpio busy - waiting
000023.177 #service_queue(): ibus/gpio busy - waiting
000023.227 #service_queue(): ibus/gpio busy - waiting
000023.277 #service_queue(): ibus/gpio busy - waiting
000023.327 #service_queue(): ibus/gpio busy - waiting
000023.377 #service_queue(): ibus/gpio busy - waiting
000023.428 #service_queue(): ibus/gpio busy - waiting
000023.478 #service_queue(): ibus/gpio busy - waiting
000023.528 #service_queue(): ibus/gpio busy - waiting
000023.578 #service_queue(): ibus/gpio busy - waiting
000023.628 #service_queue(): ibus/gpio busy - waiting
000023.678 #service_queue(): ibus/gpio busy - waiting
000023.728 #service_queue(): ibus/gpio busy - waiting
000023.778 #service_queue(): ibus/gpio busy - waiting
000023.790 #ibus idle
000023.829 #service_queue(): ibus/gpio busy - waiting
000023.879 #service_queue(): ibus/gpio busy - waiting
000023.929 #service_queue(): ibus/gpio busy - waiting
..... and so on
