2003 325xi Center Support Bearing & Guibo - Lessons Learned - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-19-2013, 08:26 AM   #1
yellowboss
My Ride: 2003 325xi
I just replaced the centre support bearing and guibo/flex disc on my '03 325xi and thought I'd share a lesson learned. Specifically, to ensure you are lining up the two shafts during re-assembly in the EXACT same spot.
My car had two white dots on each of the two shafts which I lined up by eyeball but after re-assembly and road test, there was a vibration in the shaft. I had to completely disassemble everything again and turn the shaft only 1-spline which eliminated the vibration. So, although the white dots from the factory are helpful if I were to do it again I would scribe a mark EXACTLY where the two shafts connect. There's several steps to disassemble and replace the bearing and it is time consuming so you don't want to do it three times like I did before I was re-aligned.
yellowboss is offline   Reply With Quote
Old 08-19-2013, 09:13 PM   #2
dgknight
My Ride: 02 325xi 5sp 120k
Thanks for the heads up! Glad you got it sorted eventually :-)
dgknight is offline   Reply With Quote
