SOLVED What could it be? Codes P0171 P0174 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-22-2013, 07:43 AM   #1
Arnezie
My Ride: 04 325XI
Ok driving to work today on the highway the service engine light comes on and all of a sudden it is super jerky , push down accelerator and it acts like I'm pumping the pedal. I could get it to around 60 mph and that's it. Also when it was doing this the mpg needle would shoot down to 0 , no smells no other issues. I know I need my codes read but have a couple hours before the auto parts store opens.
Arnezie is offline   Reply With Quote
Old 08-22-2013, 08:21 AM   #2
Kubica
My Ride: 2003 325xi
Hopefully a crank sensor or something simple.
Old 08-22-2013, 09:19 AM   #3
Arnezie
My Ride: 04 325XI
What could it be?
Hopefully heading to get codes read now .
Sponsored Links
Advertisement
Old 08-22-2013, 10:32 AM   #4
Arnezie
My Ride: 04 325XI
What could it be?
Got it to autozone and read the codes and then wouldn't run at all Click image for larger version
Old 08-22-2013, 11:40 AM   #5
SamDoe1
My Ride: Economy Hatchback
Lean codes, looks like you need to get your intake boot checked for cracks and tears. Other thing could be fuel pump and filter. Based on the sudden onset and severity of issues, I'd point to the fuel pump and filter.
Old 08-22-2013, 12:07 PM   #6
bmwbob89
My Ride: M-5 325 X3 528 740
Sounds like a failed fuel pump. Do a search as I've posted an easy way to diagnose a bad pump.
bmwbob89 is offline   Reply With Quote
Old 08-22-2013, 12:17 PM   #7
Arnezie
My Ride: 04 325XI
What could it be?
Thanks I'll look for it. I guess I thought the fuel pump would have it's own code :/
Old 08-22-2013, 06:37 PM   #8
Arnezie
My Ride: 04 325XI
Thank you to all of those that helped me I learned a lot it turned out to be the fuel pump changed it in about 20 minutes in The driveway. The only bad thing is the only pump I could get a hold of was a non-OEM oh well. 150 bucks and she's rolling again.
Old 08-31-2013, 11:10 PM   #9
jmo69
My Ride: 03 325xi 98 328is
I just went through this with my e46 and got no codes either, luckily a friend borrowed me his e38 till the VDO pump showed up. At least it's easy to replace when it does fail again.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 09-01-2013, 01:09 PM   #10
White_Knuckles
My Ride: 2003 325xi
It's recommended you change out the drivers side, cartridge shaped fuel filter under the car. The filter has a pressure regulator built in. The reason to change it is, should the filter be restricted or the regulator is failing, it may cause premature pump failure. And if it's unknown when/if it was ever changed, it's due anyway. Dealers and Indi's usually change 'em together when the pump takes a dirt nap.
I changed mine together and the car actually felt peppier. Nice.
Edit: >> not saying that your car will enjoy a boost from a new filter. My pump could have been weak but never threw codes, she just died. I suspect the new filter made it happy but pure speculation.
Old 09-01-2013, 09:13 PM   #11
Arnezie
My Ride: 04 325XI
Yea I just changed the filter also the other day, crazy that the filter was harder to change than the pump.
