Reedo302 help.....Miculek compensator - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 09-12-2012, 12:54 AM   #1
carcus
My Ride: 2006 BMW M5
Finally removed the birdcage from my M&P 15, put on a Miculek compensator. I noticed it does not go all the way down since the threads on the barrel bottom out. Has about a 1/16" gap between where the index nut goes and the barrel. It is on there very tight. Would like to hear your opinion on this. Also, I did not use high temp locktite as the birdcage did not require any. I can take pics if needed when I get the chance. The fit does not bother me, I just want to make sure it stays put. Never had a flash hider or compensator fit like this with a small gap.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 09-12-2012, 12:57 AM   #2
david05111
My Ride: drei hundert dreißig
Can you post a picture of this?
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
Follow me on Instagram:
david05111 is offline   Reply With Quote
Old 09-12-2012, 07:41 AM   #3
Serbonze
Master of his domain.
My Ride: My wife
You can use peel washers to close the gap. Since you would have timed the compensator correctly prior to tightening up the supplied nut, you just pick out the number of washers needed and throw them on there then reassemble everything. Or you can just leave it...
Serbonze is offline   Reply With Quote
Old 09-12-2012, 10:55 AM   #4
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
I would go to a shim/washer setup. AAC has a good setup.
http://www.advanced-armament.com/Shi...6mm_p_467.html
Otherwise, you can just use generic peel washers.
http://www.brownells.com/.aspx/sid=1...015005_d_11226
Post a pic if you have time though please.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Learning Firearms
Firearms training and hosted shooting courses
Reedo302 is offline   Reply With Quote
Old 09-12-2012, 11:18 AM   #5
speedcrazy1532
My Ride: is over
Are you concerned about the space or tightness? I was informed from someone that the flash hider was best being just hand tight and secured with locktite.
-Phil
speedcrazy1532 is offline   Reply With Quote
Old 09-12-2012, 11:32 AM   #6
Reedo302
Reedo302's Avatar
High temp Loctite and Rocksett really only needs to be used with suppressor adapters when you're going going to use them with suppressors.
With most comps, all you need is 25-30ft-lbs of torque to keep it solid. I have 4000rds through my BC 1.0 on my 11.5" and it's still solid. No thread locker.
Learning Firearms
Old 09-12-2012, 04:50 PM   #7
speedcrazy1532
My Ride: is over
that will probably save me haedaches in the future. I wasn't sure with the heating and cooling of the barrel constantly if torque was enough. I've also read that making it too tight actually hampers performance of the barrel.
-Phil
Old 09-13-2012, 03:55 AM   #8
carcus
Thanks guys, I think I will give the shims a try. I really don't think it will work loose but will check on it. I know steel expands and contracts with heating and cooling. The gap is really just an OCD thing I guess. Appreciate the info and links all.
I will try to post a pic soon though. Have to recharge the camera batteries....LOL.
Old 09-18-2012, 05:51 PM   #9
carcus
Went shooting today, AR shot great. The compensator did not work loose at all. Big difference in recoil even shooting 223. So far I like it quite a bit.
