Here's What Suspension to Buy. - Page 11 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 4.43 average. Display Modes
Old 07-14-2016, 01:26 PM   #201
chrisr03325xit
My Ride: 2003 325 xit
Year: 2003
Model: 325xit
Transmission: GM
Hello. I'm in the process of replacing my front struts. It's a 2003 XI wagon. I just realized I do indeed already have the reinforcement plates. However I do not have the spacer plates mentioned above, part number 31306779671. I did have the large 14 mm spacer on the rear springs. That made me think I did have the rough road package. Am I supposed to have this spacer plate? Does anyone else have it? By the way one day each to drill out both snapped pinch bolts. Auto parts store spring compressor wouldn't fit. But one step at a time, almost done. Had the springs compressed at a shop.
chrisr03325xit is offline   Reply With Quote
Old 07-28-2016, 03:16 PM   #202
snowboard1294
My Ride: 2001 BMW 330xi
My 330xi Suspension Set Up
In case other owners would like to see what the Koni adjustable sport shocks and struts with the H&R spring set up looks like...It is a rougher ride however my car has little body roll in the corners. I love this set up. I love it even more with a smooth, open mountain road!
ID:	637563   Click image for larger version
snowboard1294 is offline   Reply With Quote
Old 07-28-2016, 05:15 PM   #203
Jason325xi
My Ride: 2004 325xi 5speed
What size wheels and tires?
Jason325xi is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-28-2016, 07:45 PM   #204
snowboard1294
I have ASA AR1 18x8 and 18x9 staggered wheels. And I have 245/40/18 Continental Extreme Contact DSWs on the front and the same tires but 265/35/18 on the rears.
Old 07-28-2016, 08:24 PM   #205
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OK, that makes sense. Your front tires are over sized at 25.7 inches & your rear tires are over sized at 25.3 inches. Running over sized tires has many downfalls & I'd never recommend those sizes, but since the fronts are as big as they are, they do help fill the front wheel well a little better.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
(DynoDynamics
Dyno Video)
Old 07-28-2016, 08:38 PM   #206
Jason325xi
Any rubbing in the front or rear? What offset? If you know off the top of your head
Old 07-28-2016, 09:04 PM   #207
Jason325xi
Rob43
+1 on that, and I've never heard if any benefits of running a staggered setup on an xi.What i have heard is that you should stick with a square setup on an xi
Old 07-28-2016, 09:51 PM   #208
snowboard1294
The fronts are oversized by 2.6% and the rears by .9%. The OE tire diameter is about 25.1 inches and the 265s are at 25.3 inches amd the 245s are at 25.7. And with even wear those diameters will decrease overtime. However, they are still under a 3% difference and I get about 25mpg city and highway.
Old 07-28-2016, 09:56 PM   #209
snowboard1294
The offset is +42 on the front and +45 on the rear I think? I do agree for the xi a staggered set up is not the way to go. The wheels were a graduation gift from my parents and they didnt realize the wheels were not a square set up. So I originally did 255/35/18 all around but they had to squeeze onto the front wheels. However, when I switched to the 265/35/18 and 245/40/18 they fit the wheels perfectly. The fronts didnt rub at all and the rears only grazed the inner sidewall by a hair so I filed down some on the inner wall by a few millimeters and no more rubbing.
Old 07-28-2016, 09:58 PM   #210
snowboard1294
I am looking into doing 245/35/18 all the way around or 255/35/18. But, I don't think the 255s will fit on the front without some mods so I might do the 245s.
Old 07-28-2016, 10:11 PM   #211
zander271
My Ride: 6spd ZHP/5sp XI
Running an oversized tire is performance robbing for one and two you are putting undue stress on the drivetrain of the car.
Get the correct tire sizes on the car.
Old 07-28-2016, 10:19 PM   #212
snowboard1294
Excuse me sir, you do not know everything I have done to my car. Secondly, my car is performing exceptionally well. And may I ask what you are running on your BMW? Also, yes the larger tires do take a little off of my potential in mpg and acceleration; they do, however, perform fantastically around corners. Even having a staggered set up, my car holds through a corner with little understeer.
Old 07-28-2016, 10:37 PM   #213
Jason325xi
Thanks for the quick response! That doesn't sound too bad, i really don't have much to any personal experience actually messing around with different tire sizes though...the wheels look good though!
Old 07-28-2016, 10:45 PM   #214
snowboard1294
Thank you, and they do look good and give the car a look similar to the new M3. All in all, I would prefer a square setup with a smaller diameter to regain some acceleration and reduce the weight. The set up I have looks good and handles surprisingly well, but I think it is more than the car needs.
Old 07-28-2016, 11:31 PM   #215
Rob43
Rob43's Avatar
Seriously, putting the wrong size tires on an Xi is not the way to go.
You'll figure it out in due time....
Rob43
(DynoDynamics
Dyno Video)
Old 07-28-2016, 11:43 PM   #216
snowboard1294
Rob43
I apologize to say Rob43, it has already been quite awhile and my car has no issues. I constantly maintain and upkeep my car. The drivetrain is handling the extra strain just fine. I do understand the cons of having larger tires. I am also searching for a new setup of wheels and tires if you hadn't already read. My car isn't a race car, however, it was my temporary autocross car. Now I am making good progress on a car that will be meant for only racing.
Old 07-28-2016, 11:45 PM   #217
Rob43
Rob43's Avatar
You don't need to apologize, you can do whatever you want with your car.
Rob43
(DynoDynamics
Dyno Video)
Old 07-29-2016, 04:41 AM   #218
zander271
Drop the attitude.
How do you even know the drive train is taking the extra strain just fine? When your TC or transmission packs up we can reference this post and know why.
Im running a square 18x8 setup with Michelin PSS 225/40/18. I run 17's(225/45/17 = 24.97d) as my winter tire.
I know the car's performance is being robbed because I have a friend of mine that is driving around with squared 225/45/18. The diameter of his tires are 26.1 and mine are 25.2. Going between the 2 cars the acceleration difference is pretty noticeable.
Old 07-29-2016, 10:11 AM   #219
snowboard1294
Sorry. Overall, why do you care what I do with my car?
Old 07-29-2016, 10:14 AM   #220
snowboard1294
Drop the attitude.
Sorry. Overall, why do you care about what I do with my car?
