Battery voltage seems really low - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-17-2019, 03:29 PM   #1
fanatichuman
My Ride: 2001 e46 330xi
Hey guys,
In the past days I did some pa soft reprogramming. Each time my car's battery was 11.4-11.5 V, which seems extremely low. I also think I get some low voltage related error codes.
I want to hook up a battery charger/tender over night to see how the voltage behaves afterwards. Where should I hook up the tender? At the posts under the hood, or should I take the battery out and hook the tender directly to the battery?
Cheers,
fanatic
Edit: the car (seems) to start fine despite the low V.
fanatichuman is offline   Reply With Quote
Old 05-17-2019, 05:43 PM   #2
shadetreemech
My Ride: 325ci
My battery has been 11.7 to 11.8 volts for several years. Alternator voltage exceeds 14 volts. That is measured by several different digital volt meters at the battery. I took the battery out of the car and took it to a local parts house. They tested it pronounced it good but 'needs a charge'. They charged it. I checked the 'parasitic drain' and it was under 30 ma, normal. Two weeks later it was back to 11.7 volts. Car starts every time even after sitting for 7 weeks. Oh well. At the first hint of a 'hard start' or funny cautions I will replace it. My habit, in order to protect the rest of the electronics, is to disconnect the positive terminal when charging a battery in the car. If you take the battery out of the car do not set it on concrete.
Cheers
shadetreemech is offline   Reply With Quote
Old 05-17-2019, 05:46 PM   #3
fanatichuman
Cheers
So, I gather I should disconnect the posts and charge with the tender directly at the battery.
How did you check for parasitic drain?
Cheers
Sponsored Links
Advertisement
Old 05-17-2019, 08:39 PM   #4
Sapote
My Ride: 2000 323i auto wagon
Cheers
Just leave batt untouched and connect the charger to the front RH fender posts.
No need to check batt drain unless you believe batt drained too fast problem.
Normal battery should be above 12.6V engine off, and around 14V engine idling, measured on batt posts directly.
Short trip driving not enough charging time?
Sapote is offline   Reply With Quote
Old 05-17-2019, 10:15 PM   #5
jmo69
My Ride: 03 325xi 98 328is
I hook my tender up directly to the battery without disconnecting it.
Alternative to expensive xi control arm bushings https://forum.e46fanatics.com/showthread.php?t=1231503
Bad outer xi ball joint? https://forum.e46fanatics.com/showthread.php?t=1127077
2003 325xi auto Stahlgrau
1998328is 5sp
jmo69 is offline   Reply With Quote
Old 05-17-2019, 10:56 PM   #6
fanatichuman
Jeah, i guess. 5 min to and back from work, and some longer trips on the WE. Trying to figure out whether my bat is bad or just never got fully charged.
Thanks,
Fana
Sent from my MI 5 using E46Fanatics mobile app
Old 05-19-2019, 12:09 PM   #7
shadetreemech
My Ride: 325ci
If I have a proper battery charger I agree. I don't know what some of these cheap Chinese battery tenders are. A friend of mine looked at the output of one with an oscilloscope and said it was a half wave rectified square wave. A battery will care less but some of the electronics might not like it.
Does anyone have any experience with these battery tenders?
Old 05-19-2019, 02:01 PM   #8
CalVol
My Ride: 2001 330i
Model: 330i
Transmission: 5-sp
I have a one-year old Bosch AGM battery and it consistently reads 12.1-12.2v using the instrument cluster with the car being driven about 2x/week. Alt output is 14.0-14.1v. I bought a cheap $10 Stanley battery tender and it keeps it charged at 12.6v. I tested parasitic draw and it was about 30ma. If I take the battery tender off for a few days, the voltage drops back down to 12.2v, so I guess it's just a shitty battery.
CalVol is offline   Reply With Quote
Old 05-19-2019, 06:31 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
You can connect the charger wherever you want, engine bay or trunk. No difference. A caveat is that the fasteners (screws) in the charging system must all be securely tightened. If not tightened, it still doesn't matter where you connect the charger because the entire system will be compromised and any voltages you get will be unreliable.
DISCONNECT THE NEGATIVE BATTERY TERMINAL SO YOU DO NOT TURN YOUR TOOLS INTO AN ARC WELDING ROD
There is a fat red wire on the back of the alternator that goes to a post on the starter that is shared with another fat red wire that goes to the terminal in the engine bay for the + connection (B Post) of the charger/jumper cables. From there, the fat red wire goes to the battery.
Check that the nuts on the underside of the B Post, the starter, and the alternator to be sure they are all tight. I had trouble once with the B Post that was not tightened properly.
Voltage on a static battery ought to be 12.6 volts. When the engine is running you should see 14.4 volts. A variance of 0.1 or so can be from the tester, but if you are seeing a variance of about 0.5 or more, then you should consider a malfunction, but certainly get another tester first. Use your tester on another car that is not giving trouble to confirm that your tester is giving bad intelligence.
Old Yesterday, 02:51 AM   #10
fanatichuman
Great advice, thanks!
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help! - Battery light, Alternator, Voltage Regulator? gradywhite2424 General E46 Forum 17 09-17-2013 09:28 PM
What is your running battery voltage? kuksul08 General E46 Forum 6 02-19-2010 03:29 AM
What would be the reason for the Service engine soon light to be on. ProchaineStation General E46 Forum 89 07-13-2009 03:14 PM
Battery replacement differences on SULEV theman5207 General E46 Forum 2 10-25-2008 05:19 PM
How to check the battery voltage and alternator again? msakuraz General E46 Forum 4 06-13-2008 02:47 AM
