Build/swap possibilities? Will s52 block bolt to m52tub25 head? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 05-23-2019, 08:29 AM   #1
iamanonymous
So I have a blown head gasket on my 1999 323i motor. Cylinder 6 took a crap on me and has 120 compression.
I want to do a very basic turbo build like I had on my 1998 e36 m3.
I want to ditch my stock aluminum block and bolt my head, intake, and exhaust manifolds to an s52 block (or m50, m52, or s50 us).
Is it possible? Any mods needed? I can build and tune, I want to keep all e46 sensors and functionality. I cannot fabricate. I can only cut, move, adapt, and assemble. I cannot weld and have no access to making custom brackets or anything.
iamanonymous is offline   Reply With Quote
Old 05-23-2019, 09:39 AM   #2
infoboy
My Ride: 325ci
I dont think the block of s52 would fit on m52tu head,but you can use the s52 internal and move them to the m52tu block.
Sent from my SM-J415F using E46Fanatics mobile app
infoboy is offline   Reply With Quote
Old 05-23-2019, 10:45 AM   #3
iamanonymous
That is good to know.
I want the iron block. Has anyone tried this?
I can see a slight issue with the thermostat housing for sure. Other than that???
Sponsored Links
Advertisement
Old 05-23-2019, 10:52 AM   #4
infoboy
My Ride: 325ci
As i know the head of the m52tu/m54 has different and more holes for water cooling than old heads used in e36's so these holes of the m52tu wouldnt align with the s52 block
Old 05-23-2019, 11:04 AM   #5
iamanonymous
What if I used an s52 headgasket and "siliconed" the timing cover section? Or visa versa.
I'm used to building frankenmotors.
Old 05-23-2019, 12:23 PM   #6
infoboy
My Ride: 325ci
I dont think this is a good idea and i dont think anybody did this.and since the holes of cooling water are different in the heads its different between the 2 blocks too, so you will have problems of cooling.
Old 05-23-2019, 12:25 PM   #7
iamanonymous
I guess I could look at both head gaskets...
Old 05-23-2019, 12:32 PM   #8
infoboy
My Ride: 325ci
Do what ever you want but in my opinion this a waste of time,unless you swap the block internal cranckshaft...
Old 05-23-2019, 12:42 PM   #9
iamanonymous
In this scenario, the only m52tub25 parts will be all the sensors, and everything that is attached to the head. Basically I would be bolting an entire s52 block, clutch, flywheel, transmission, and at least part of the driveshaft.
My goal should be to run this all with the ms42 and not lose any AC or cooling system functionality.
I understand there may be substantial differences in the cooling passages which may be the final nail in the coffin.
