DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV? - Page 96 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average. Display Modes
Old 11-22-2018, 12:19 PM   #1901
Baddabing
My Ride: E46 330 CI
Originally Posted by vitalic View Post
Right now i use the RV cam switch of the tv module like the pibus board does. If oem pic on channel 1 is displayed it has 5V plus and HDMI switch stays on channel 1. If i choose the Pi as pic it goes to 0V and the HDMI switch is going to channel 2. Need to figure out a way to use this signal to go back on channel 1 if rear gear is selected.
Good work Vitalic!
I agree two channel is the way to go.
Could you please provide details of the HDMI switch and a diagram of how you wire up the switch from OEM to Pi please?
Baddabing is offline   Reply With Quote
Old 11-23-2018, 09:27 AM   #1902
Arron5
My Ride: 330D F30
Hi All,
I have a pibus 4 with all the cables (I believe) it's been sat in the garage for 2 years as I sold the e46. Open to offers if it is any use to someone?
Thanks,
Arron
This item has been sold, thank you
Arron5 is offline   Reply With Quote
Old 11-25-2018, 01:36 PM   #1903
vitalic
My Ride: E38
At PeteAu:
Is there a partlist with the type/name/value of the resistors, coils, diodes etc.? For maintenance. Giuss i grilled Q2 while testing videoswitching.
Already changed the Pi but still get 0.5V output from this pin. Need to know what LPW41 is?
vitalic is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-25-2018, 06:14 PM   #1904
bb7_rider
My Ride: car
Originally Posted by Arron5 View Post
Hi All,
Thanks,
Arron
You have PM
bb7_rider is offline   Reply With Quote
Old 11-25-2018, 11:38 PM   #1905
vitalic
My Ride: E38
@Baddabing its relative easy to switch between 2 HDMI channels with the right hardware. But it has become a problem to use the reversecam with this setup.
Thats why i will wait until i habe a solution for this too. But now i need some info from Pete as i grilled Q2 on the board while testing (LPW41).
Don't want someone else to crash the board.
Old 11-26-2018, 03:22 AM   #1906
PeteAU
My Ride: 330i
At PeteAu:
Q1, Q2: 2n7002 (any n-channel mosfet)
D3, D4: BAT54C
PeteAU is offline   Reply With Quote
Old 11-26-2018, 09:00 AM   #1907
vitalic
My Ride: E38
D3, D4: BAT54C
Thx. Fixed it. Desoldered one from broken laptop mainboard and resoldered it at Q2. Works again.
Old 12-02-2018, 05:56 AM   #1908
bmwdud121
My Ride: 2002 330i
I've had a weird issue come up lately: there is a seemingly random rolling or flickering/fuzzy effect when using the pibus. It started when the colours started to get a bit too bright and washed out around the edges, then the random rolling effect starts. The rolling only lasts for a little bit, and if I switch back to the nav screen then back to pibus it goes away for a while. The over-bright flickering/fuzzy effect stays though. Checked all connections, running OSMC and an old version, but all do the same thing. Any ideas what I could check?
bmwdud121 is offline   Reply With Quote
Old 12-08-2018, 01:53 AM   #1909
vitalic
My Ride: E38
So i managed to switch between 2 different HDMI channels automatic. Just like Pibus does but now with new touchscreen instead of oem display. I also managed to switch to reversecam, but some more investigation is needed here, because the green is to high at cam picture. This is because of the sync signal separated from green line.
So right now i use a 2 in 1 HDMI switch. Channel 1 is TV Modul, Channel 2 is Pi. The RGsB signal from TV Modul is converted to HDMI via a separate converterboard. Th sync signal therefor needs to be separated from the green color signal.
At the moment i use 2 relais to switch between the channels. They also react on reversegearsignal and switch to cam.
I'll upload a schematic when the greencolor problem on reverse is fixed.
So no other switches or anything else but oem buttons and control is needed to switch the input automatic.
Old 12-08-2018, 03:18 AM   #1910
vitalic
My Ride: E38
So i found a way to reduce the extragreen color on reversecam.
On the converterboard you can also setup some things. Clamp st and clamp sp fixed the prolem. So now everything runs super.
ID:	763295   Click image for larger version
Old 12-16-2018, 06:16 PM   #1911
chriskuta
My Ride: M3
@vitalic .. nice work, the bench setup is great. Keep us posted
2001 e46, Euro Spec, Manual, OEM CSL Airbox & CSL Tune, OEM CSL Wheels, Brembo Porsche MBK
chriskuta is offline   Reply With Quote
Old 12-16-2018, 09:51 PM   #1912
crazyazz
My Ride: 2002 M3 2010 135i
Anyone running crankshaft on the pibus? If so do I need to remap the keys of the OEM headunit?
crazyazz is offline   Reply With Quote
Old 12-18-2018, 04:55 AM   #1913
bmwdud121
My Ride: 2002 330i
I've been working on mine on and off - probably should get around to updating my guide on the other thread...
You need to remap the keys, which are set using the evdev file. Sudo nano /usr/share/X11/xkb/keycodes/evdev will get you into the file, and replace the existing mapped number with these:
57: replace with 60
55: replace with 59
65: replace with 56
That will take care of the steering wheel controls for next, previous and play/pause. When I get some time I'll keep going with the rest.
Still working on my weird rolling image issue first....
Old 12-18-2018, 10:14 PM   #1914
crazyazz
57: replace with 60
55: replace with 59
65: replace with 56
Thanks for the reply mate, really appreciate it! What is the rolling image issue your having?
Old 12-19-2018, 02:42 PM   #1915
vitalic
My Ride: E38
I guess it's a hardware issue with the tv module as it creates the pic from pi input.
The nav creates it's own pic and the tv module is only in bridgemode when nav sends the pic.
Old 12-23-2018, 05:32 PM   #1916
bmwdud121
My Ride: 2002 330i
Here's a video showing the rolling (sorry for the music...):
And an image:
I'm still trying to work out some bugs with the latest version of crankshaft, but will update when I have it working plus more button maps
Old 12-24-2018, 01:02 AM   #1917
crazyazz
And an image:
Attachment 764357
Sweet
Old 12-25-2018, 03:12 PM   #1918
vitalic
My Ride: E38
And still i guess tv module. Sync problem.
You may try different sdtv modes on config.txt of the pi. But i'm sure it wont help.
Old 01-05-2019, 05:27 AM   #1919
bmwdud121
My Ride: 2002 330i
Ha! That did it! I tied PAL, no luck, then the Japanese NTSC setting and bingo! No more rolling.
It must be have been when I set my region to Japan to bypass the warning message on startup... I just didn't think it would affect anything else
Old 01-18-2019, 08:34 AM   #1920
Baddabing
My Ride: E46 330 CI
Anyone got any idea how to enable Right Rotary Controller when in Aux mode. Natively it does nothing - but I am told it can be switched on.
