DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV? - Page 97 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average. Display Modes
Old 01-25-2019, 01:25 PM   #1921
harryberlin
My Ride: E39 Touring
i mean, you have a different aux message.
harryberlin is offline   Reply With Quote
Old 01-30-2019, 02:57 AM   #1922
Archbid
My Ride: Leaf
Originally Posted by vitalic View Post
So i found a way to reduce the extragreen color on reversecam.
On the converterboard you can also setup some things. Clamp st and clamp sp fixed the prolem. So now everything runs super.
What camera are you using?
Archbid is offline   Reply With Quote
Old 01-30-2019, 10:02 AM   #1923
Baddabing
My Ride: E46 330 CI
The way I want to solve my Bordmonitor upgrade is by enabling right rotary controller in Aux Mode. Then switch screen to HDMI input from RPi and use Ressler to link to iBus.
I understand the iBus messages are:
F0 04 3B 49 81 07 Left turn
F0 04 3B 49 01 87 Right turn
F0 04 3B 48 05 82 push*
F0 04 3B 48 45 C2 hold*
F0 04 3B 48 85 02 rel
Baddabing is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-31-2019, 04:30 PM   #1924
harryberlin
does it mean you use the pibus program with the resler usb interface?
very confuse thing...
the messages are from button, but has nothing to do with aux. the aux message comes from radio device.
Old 02-03-2019, 03:35 PM   #1925
vitalic
My Ride: E38
A rearcam ntsc from ebay. Mounted in numberplate holder.
Meanwhile a soldered my own circuit to control HDMI channel via r-gear and pibus / tv-modul signal.
Works like charm. Will post some pics of it soon.
Just a little problem with sync signal from cam on startup. Takes some seconds to get a stable pic from rear cam. After complete warming up phase pic is stable fom rear cam. Looks like a sync problem from LM1881.
vitalic is offline   Reply With Quote
Old 02-04-2019, 02:19 PM   #1926
Baddabing
My Ride: E46 330 CI
No - the pibus device is (basically) no longer available. I need another solution, not pibus or its program.
Aux provides good solution as it is Audio In (from RaspPi) - but how to activate radio device so that rotary controller works in Aux MODE is a mystery!
Old 02-06-2019, 01:49 PM   #1927
vitalic
My Ride: E38
With Petes yes i'd like to try to make a copy of the pibus board. A partlist a maybe printlayout file would be great. At least i will try to make a copy for my own use just in case...
Old 02-07-2019, 02:14 AM   #1928
harryberlin
inspired by pibus, i did developed an other rasp shield with arduino for ibus.
you can get some pics and infos from here:
https://github.com/harryberlin/Ardui...ster/README.md
but at the moment it's very early state.
Old 02-13-2019, 06:53 AM   #1929
Kensey
My Ride: E39 528iA
Year: 1999
Hi Harry,
is there any chance, that We can buy / make one from You ? Seems Pete is not doing it anymore... I would like to run it in my car...
Regards
Kensey is offline   Reply With Quote
Old 02-16-2019, 08:48 AM   #1930
harryberlin
Originally Posted by Kensey View Post
Hi Harry,
Regards
send pm to me.
Old 02-19-2019, 03:27 AM   #1931
vitalic
My Ride: E38
At Pete,
I'm building my own Pibus Mainboard with HDMI switch and some other things. As base i use your v4.03 board to get some solutions. Right now i try to understand the power supply. There is a TD1501 DC/DC converter which is on when pin5 is low. This is controlled by a n-channel mosfet (Q3 on your board). S is ground, D is connected to pin5, G isconnected via 100k to ground and also to pin 8 of IBUS IC (U1 TPIC1021A).
But how does it know when to turn on and when to s.hut down? The IBUS sends signal to all connected modules to wake up. So your board receives the signal and pi boots. But how?
Old 03-08-2019, 04:33 AM   #1932
vitalic
My Ride: E38
So here they are. 10 pcb based on version 4.03 but without Petes yes they are just for my own.
Old 03-08-2019, 05:43 AM   #1933
Baddabing
My Ride: E46 330 CI
So you need 10 of these for yourself?
Old 03-08-2019, 08:15 AM   #1934
vitalic
My Ride: E38
It was the min order quantity... just made them to understand the pibus board and to check the quality of the pcb. Developing my own pibus mainboard right now. Pictures coming soon.
Old 04-26-2019, 12:10 PM   #1935
vitalic
My Ride: E38
So here it is.
It will combine the Hifiberry-DAC, powersupply, ibus-com, 2xpoweed usb hubs (each has 4 ports), RGsB to HDMI converter, HDMI switch, soundcard with mic input and an audio noise filter.
On top i can put the raspberry. So it's an all in one solution.
If everything works, the next version may have an onboard dab/fm receiver.
Regards
ID:	773765   Click image for larger version
Old 04-30-2019, 06:03 PM   #1936
[email protected]
My Ride: BMW E46 318i
At Pete,
Hi any progress on building your own PiBus Mainboard. I need one for my E46. If possible if you could share your schematic
humured@gmail.com is offline   Reply With Quote
Old 05-01-2019, 01:04 AM   #1937
vitalic
My Ride: E38
Soldering everything at the moment.
Right now powersupply, Raspberry connection, IBUS, HDMI switch and Hifiberry-DAC are working.
ID:	774131   Click image for larger version
ID:	774133   Click image for larger version
Old 05-09-2019, 07:58 AM   #1938
Baddabing
My Ride: E46 330 CI
Very interested in one Vitalic - I will be buy one if you are selling, thank you.
Old 05-12-2019, 12:35 PM   #1939
vitalic
My Ride: E38
Maybe i'll produce some, if everything runs fine. At the moment everything is soldered.
USB hub, ok
USB soundcard for Mic in, ok
Ibus Communication, ok
HDMI switch, ok
Power supply, ok
Hifiberry dac, ok
RGsB to HDMI, not ok
The RGsB to HDMI converter works, but the output is very very green and has some glitches. Need to find the error before i'll let the next pcb be produced. Found several other mistakes which are solved in version 2.
Old 05-12-2019, 08:11 PM   #1940
PeteAU
My Ride: 330i
Hi vitalic,
Did you consider making a replacement TV-module motherboard? Then you could do all the RGsB video switching inside without lots of wires.
PeteAU is offline   Reply With Quote
