325ci Chumpcar Build - Page 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-24-2018, 12:23 PM   #101
Zero Cool
My Ride: 04 325Ci, 91 318iS
Originally Posted by zack_280 View Post
Also, regarding the non-///M stock fuel system. I took my 'street' car to Barber Motorsports Park last weekend. It fuel starved at 1/2 tank in turn 2/3 and over the back roller coaster turn. So for anyone in the future reading through this, you will need to plan for fuel system improvements if you are racing with less than 1/2 tank.
do you have the M3 fuel baffle installed?
Zero Cool is offline   Reply With Quote
Old 08-24-2018, 12:47 PM   #102
Zimo32
My Ride: E46 325, E53, E63 M6
Originally Posted by Zero Cool View Post
are you using the M56 specific gasket, or the M54 gasket? the M56 has a metal frame in it, and if carefully removed, can be reused.
i will see if it seems loose tonight and get back to you. as of right now, i have no leaks. but i also haven't ran or driven it too much.
Yepp M56 gasket:
https://www.fcpeuro.com/products/bmw...5i-71-36522-00
and
https://www.fcpeuro.com/products/bmw...5i-11127521010
My Nissan might have problems burning oil but at least it doesn't leak when I use brand new gaskets! These damn germans, plastic valve covers, sub frames that rip out of the car, oil pump nuts that come loose....
Zimo32 is offline   Reply With Quote
Old 08-24-2018, 12:57 PM   #103
zack_280
My Ride: E36 M3 and E46 330Ci
Transmission: Manual
No. Just stock non-///M fuel system.
zack_280 is offline   Reply With Quote
Old 08-24-2018, 10:15 PM   #104
Zero Cool
Yepp M56 gasket:
and
That's odd, I have the same gaskets and no issues. Did you by chance forget to pull out the old spark plug tube gaskets?
Ok, I guess that's good since I have the M3 baffle and have read good things about it.
Old 11-27-2018, 03:58 PM   #105
BryanPendleton
My Ride: 325i
Year: 2004
Model: 325i
Transmission: 5-Speed Manual
Most of the "slowness" in filling modern fuel tanks is the car, rather than the jugs, but as mentioned the Hunsakers are the best investment with regard to jugs. But the biggest restrictor is usually the car. Few tips:
1) remove the unleaded restictor in the fuel line as mentioned.
2) make sure your fill nozzle sits below where the vent line intersects the fill line. If you can run a "seal/barrier" to prevent splash from backing up into the vent you will minimize venting issues.
3) the biggest issue usually is the evap crap on the tank itself. Slows the venting process. Prevents fully filling the tank. Removing this will pay dividends.
Different application, but with the above we have been able to dump 5gal/20seconds.
BryanPendleton is offline   Reply With Quote
Old 11-29-2018, 04:52 PM   #106
Zimo32
Thanks I was about to start diving into this over the weekend. Bought the Hunsakers, ill start taking apart the filler and see what to do from there.
Any reason to not swap out the stock filler neck with something like this?https://www.wescoperformance.com/rec...QaAkkwEALw_wcB
I measured the stock tube off the fuel tank to be 1.75".
Old 11-29-2018, 05:49 PM   #107
Geo31
Ironman
My Ride: 98 M-Z3/01 330iT 6MT
OT....
With the Z32, I'm assuming you know who Mike Kojima is.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 12-01-2018, 02:23 PM   #108
Zimo32
^^ Well i know him now lol.
I removed the restrictor so now I'm just waiting on my fuel jugs to see if it works.
Old 12-04-2018, 10:43 PM   #109
Zimo32
With this modification and the Hunsaker fuel jugs, fills in about 29 seconds. Maybe 25 seconds since i was a little slow get the jug up vertical, fuel tank is completely full so I couldn't do a second run to confirm. Only other thing i might do is delete the carbon canister and see if that speeds it up a bit.
Old 02-13-2019, 03:00 PM   #110
Zimo32
Made some changes.
Pretty cool to see just how badly these rotors get abused. Pulled from my 300zx which always roasted the brakes on the track.
ID:	768219   Click image for larger version
ID:	768221   Click image for larger version
ID:	768223   Click image for larger version
Old 02-13-2019, 03:26 PM   #111
zack_280
Nice! How did you do the front transition to a single pipe?
Old 02-13-2019, 05:08 PM   #112
Zimo32
its an old bimmerworld y pipe for an e36 that i picked up for cheapand extended 5".
Old 02-18-2019, 09:58 AM   #113
Zimo32
We had been using zip ties to secure our kill switch for all of 2018, finally made something little more secure.
ID:	768439   Click image for larger version
ID:	768441   Click image for larger version
Old 02-18-2019, 10:00 AM   #114
Ettinger
My Ride: 4 doors, 3 pedals
Excellent thread, Zimo32
My BLT drive is broken
Ettinger is offline   Reply With Quote
Old 12-13-2019, 01:00 PM   #115
Zimo32
Haven't updated in a while. We a slight front end incident this year. Changed around some wiring so that all my connections were fused.
ID:	790077   Click image for larger version
ID:	790079   Click image for larger version
ID:	790081   Click image for larger version
