BMW E46 Sunshade Sunroof Final Fix COMPLETE Pictorial DIY! - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.95 average. Display Modes
Old 04-23-2010, 06:59 PM   #21
q0192837465
My Ride: 99.4 A4, 03 330xi
Send a message via ICQ to q0192837465
u'r a lifesaver. a clip broke & my mechanic pulled it out so that it wouldget stuck. I'll do this DIY rigth away. Thanks a bunch
Oh, and what kind of lubricant should I use for the rails?
q0192837465 is offline   Reply With Quote
Old 04-24-2010, 12:59 AM   #22
delmarco
My Ride: 335i xDrive Deep Sea
Year: 2011
Model: 335i
Transmission: Steptronic
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
no problemo.
ONLY USE a gel type lube.
DO NOT use a liquid lube like wd40.
VISIT MY GARAGE TO SEE MY BMW MODS & PROJECTS:
E90 -
E46 -
delmarco is offline   Reply With Quote
Old 05-01-2010, 12:53 AM   #23
lkstaack
My Ride: 04 330iZHP, 05 325iT
Do I need to remove the moon roof to properly grease the rails?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-01-2010, 03:43 AM   #24
delmarco
Year: 2011
Model: 335i
Yup. However removal of the Moonroof (glass part of the Sunroof) is ridiculously easy. It takes about 2 minutes. Literally 2 minutes.
E90 -
E46 -
Old 05-01-2010, 08:58 AM   #25
lkstaack
I defer to your awesomeness. Thanks, I needed to know that.
Lars
Old 05-02-2010, 07:54 AM   #26
Poorboyz
My Ride: 2001 330Ci
Delmarco, I've also changed all my clips to find out that the sliding head was also mangled but I was thinking about it and decided that I would try to make a sliding head of rubber and cut a slice in the rubber to slide it into the metal piece that holds the original plastic sliding head. I just installed the clips on Friday and was going to attempt to make the rubber piece today. I'll report back on what my outcome is.
Poorboyz is offline   Reply With Quote
Old 05-02-2010, 01:08 PM   #27
jdstrickland
My Ride: '94 325iC & '00 323i
IMPORTANT POINTS ON THE DRIVER SIDE CLIPS
There are two sizes of the clips that go on the driver side of the inside shade. The difference in the two clips is the spacing between the mounting holes. The slides themselves are the same. but the metal tab with the mounting holes are different sizes. You need the correct size according to the Production Date of your car.
Don't ask how I know this.
The Passenger Side clips can fall off and rest inside the roof, along the track. I've done this job on three different cars, and the passenger side clips were usually serviceable after I found them using a flashlight and a coathanger to pull them out. I think I replaced one of them on the three roofs I have worked on.
The repair strategy wouuld be to take the roof apart and then go buy the parts you need, unless you are willing to buy extra parts and then return the parts you don't use. You can't tell before hand if you need one or both of the driver side clips, or what size, and you also won't know if you need the passenger side clips or not.
Old 05-02-2010, 01:12 PM   #28
jdstrickland
no problemo.
One should not use the words "lube" and "WD40" in the same sentence.
WD40 is good AT BEST to free sticky mechanisms, but it has to be completely removed from whatever you put it on because it will dry and turn to goo that just makes the mechanism sticky again.
Old 05-15-2010, 11:48 PM   #29
jeffmr
My Ride: 2003 325xi
jeffmr is offline   Reply With Quote
Old 05-16-2010, 12:56 PM   #30
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Yeah all these delmarco DIY's are awesome. This guy is a legend.
Rain Sensor Retrofit:
Coupe Headline Replacement:
jaymemaurice is offline   Reply With Quote
Old 06-15-2010, 07:47 AM   #31
Rickna
My Ride: '02 330xi - '09 IS-F
Year: 2002
Model: 330xi
Transmission: AT
Did this about a year ago. Could not have done it without delmarco's write up! Thank you!
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 06-25-2010, 05:14 AM   #32
alofuzion
My Ride: 323i 00
i have problems with the driver too, such a headache
alofuzion is offline   Reply With Quote
Old 01-02-2011, 02:37 AM   #33
_k
My Ride: e46 coupe
Awesome write up, i can see you have put in alot of effort int this write up so i will take this opportunity to use your DIY and repair my sunshade.
thanks mate
_k is offline   Reply With Quote
Old 01-03-2011, 11:15 PM   #34
vidospace
My Ride: 318ti
Great guide. Can I just add that mine is now fixed BUT my driver is totally screwed. It wont move at all (back or forward with the roof). To get around this issue I simply pushed it all the way back into the roof cavity along its guide. This makes the sunshade basically a manual slider, and it works puurrrfectly!
vidospace is offline   Reply With Quote
Old 02-23-2011, 05:57 PM   #35
MasterTJ
My Ride: 2002 e46 BMW M3 6sp
GREAT DIY!
I used this and found out my driver was all sorts of F'd like yours was. I bent it down and have a temp fix. Luckily my clips were all in decent enough condition to leave in there. What a Sh*t design! Way to go BMW lol.
Anyway, it works but kinda sorta. I'm tempted to just destroy and cut off the driver head so my shade becomes manual. I use it that way anyway! Thanks again.
2002 BMW E46 M3 Black 6sp
Borla / CF goodies / Kenwood/Infinity sound system / Orion V2 AE's
1st Lt, USAF
MasterTJ is offline   Reply With Quote
Old 02-23-2011, 06:12 PM   #36
sellsellsell2000
My Ride: E46 seden
Year: 2000
Model: 323i
Transmission: Manual
Send a message via AIM to sellsellsell2000
Excellent DIY as always. Pictures with detail step by step explanations. U R the MAN!
Thank you Delmarco!
sellsellsell2000 is offline   Reply With Quote
Old 05-05-2011, 10:17 AM   #37
COTTILUVS325
My Ride: 325Ci
Here I go, it's my turn now w/ the sunroof drama. Any idea on where I can find these clips besides a dealer??? Ebay is selling a pair of lefts.
Thank you Delmarco! Awesome thread!
COTTILUVS325 is offline   Reply With Quote
Old 05-05-2011, 10:29 AM   #38
Rickna
Year: 2002
Model: 330xi
Transmission: AT
ECS Tuning or Tischer.
2001 BMW 330xi
2009 Lexus IS-F
Old 05-05-2011, 10:57 AM   #39
COTTILUVS325
My Ride: 325Ci
Thanks...just priced them out & my Atlanta dealer has them at $15 per pair. Cheaper than what I thought.
Old 05-20-2011, 10:45 AM   #40
M325er22
My Ride: 2001 325i
Wow. Ive had this problem for a while n never found a solution. Ill be doing this sooon. Thanks
Sent from my LG-P509 using Bimmer App
M325er22 is offline   Reply With Quote
